#15 |
Drives: 2016 Scion FR-S
Just to echo what everyone else is saying, my FRS does the same thing, with the AC on at idle. It almost feels like the engine will die sometimes the RPMs drop so low. I’ve gotten used to it. The twins have a ton of “character” that’s for sure.
![]() Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to JesseG For This Useful Post: | Griever423 (06-28-2020) |
#16 |
Drives: brz 2017 hksv2
>my17 in europe are the worst
also ots v4 based on euro tune have quite a shitty idle |
#17 |
Drives: 2017 BRZ PP
Will the idle continue to dip after you come to a stop? Mine mostly isn't even when I'm coming to a stop, rather when I have been sitting still for a couple seconds.
#18 |
Rust bucket enthusiast
I raised my idle to 950rpm and the a/c doesn't bother the car anymore. Even a clutch in from 6000rpm letting it sink all the way down, it doesn't stumbled to catch. It hesitates a little when idling, but nothing like the stumble it had when the idle rpm were at 650-700
#19 |
Drives: FR-S,GTI
In 6 years my engine has stalled just once because of this. Stopped at a traffic light, the idle dipped really low and the engine stalled. Started the car right up and had a CEL. Oh shit! My car is broken!
Went home and cleared the code with OFT. I forget what the code was. I think it was something about the vacuum. Turns out it was just a hiccup and hasn't happened again. (Hasn't stalled, that is, it still dips all the time.) |
#20 |
Drives: 2017 BRZ PP
#21 |
Drives: FR-S,GTI
Turn off the radio and listen. When the car is idling and you hear a click, that click is the AC compressor turning on. The idle dip always coincides with that click.
#22 |
Drives: 2017 BRZ PP
#23 | |
TRACKBREAD
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | DarkPira7e (06-24-2020) |
#24 | |
Drives: 2017 BRZ PP
In the video link I posted in the OP, I turned all the HVAC controls off to try an make sure the A/C was not causing the problem, plus I can't the click of the compressor kicking on. (maybe its extremely quiet?) |
#25 | |
Drives: Crapcan
600 RPM idle is too low. I bumped mine to 950 as well since coming off the track, or driving the car on a sprited back road oil pressure was extremely low.
#26 | |
Drives: FR-S,GTI
#27 |
#28 |
i successfully put 760rpm as hot idle in my tunes, but the real very rock steady is at 900rpm
| Intermittent will not start | 333Matt | Issues | Warranty | Recalls / TSB | 11 | 10-24-2019 09:03 PM |
| Flashing and Intermittent CEL - HELP | MugsBRZ | Issues | Warranty | Recalls / TSB | 7 | 10-19-2016 12:56 PM |
| Intermittent Over Heating | Deep Six | Issues | Warranty | Recalls / TSB | 6 | 12-16-2014 10:22 AM |
| Canadian Intermittent RPM dip? | VirUzxZ | CANADA | 23 | 06-24-2014 03:16 PM |
| Acceleration Lag - Intermittent | donnyk | CANADA | 6 | 07-18-2013 12:53 AM |
