Old 06-17-2020, 09:34 AM   #1
golemslord
Drives: 2014 White FRS
Gas pedal vibration ?
Hi,
I recently notice a vibration/pulsation in the gas pedal starting from a very low speed (to highway speed). It is more noticeable when just resting the foot on the pedal. When I shift it to neutral, the problem is still there. The car drives very smoothly and I do not notice any vibrations elsewhere aside from the pedal
The wheels and tires were mounted for a month or so without problems until recent weeks. I have tried installing hub centric rings but no luck in fixing the issue.
However, the vibration sometimes disappears for a very little bit when driving on very smooth pavements.
Any suggestions on what I should do? I was thinking of getting the tires balanced next in hopes of solving this mystery.
Tires are Falken Azenis FK510 with 80% tread. Both the wheels and tires are around 1 year old
EDIT: tires are balanced, car had alignment, tires rotated, wheel bearings checked with no play, brake rotors and pads changed.... And, the pulsing is still there. Ran out of solutions, probably it is what it is lol. Most likely the harsh summer tires.
Thank you
golemslord is offline   Reply With Quote
Old 06-17-2020, 10:46 AM   #2
p1l0t
p1l0t's Avatar
This is an interesting one. Following.
Old 06-17-2020, 11:28 AM   #3
sato
sato's Avatar
Drives: Dodge Patitas
Originally Posted by golemslord View Post
Hi,
Thank you
You have taken some good steps and understand your frustration. There might still be a few things worth checking, starting from cheaper to more expensive checks since you mention vibration while rolling (I assume) in neutral.
IMO, balancing is very important. I've had cars with heavy vibration, which I thought was mechanical, but due incorrect balancing (balance only on one side of the wheel). The issue can also be aggravated by tires that get damaged by potholes or tires left flat or with low tire pressure for extended periods of time during storage (might not be your case), deforming tire. You might be able to pick up wheel and or tire deformation looking at wheel/tires from different angles while they are being sped up on the balance checking machine. These issues might not be fixed by balancing alone.
You might also look into wheel bearings. They wear out slowly, which might make diagnosis difficult due to the gradual change. Bad conditions and potholes can accelerate wear and damage them in a hurry. I happily replaced my front wheel bearings around 80k, but left the rears on for nearly 120k, which was a mistake. It all starts with noise, but can easily transform into noise + vibration given the wear level. This can easily confused with tire / wheel related problems and should not be overlooked.
sato is offline   Reply With Quote
The Following 3 Users Say Thank You to sato For This Useful Post:
golemslord (06-17-2020), humfrz (06-17-2020), soundman98 (06-18-2020)
Old 06-17-2020, 04:22 PM   #4
norcalpb
norcalpb's Avatar
Well the gas pedal is purely an electronic device so it’s the floor that’s shaking and not so much your gas pedal.
I second getting a rebalance on the tires.
It could be wheel bearings, but you’d definitely be able to hear them as well.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
golemslord (06-17-2020), soundman98 (06-18-2020)
Old 06-17-2020, 06:47 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Does this get worse with sudden acceleration? Have you checked where the gas pedal connects to the firewall?
Old 06-17-2020, 06:51 PM   #6
Yep, I also suggest you have the tires balanced.
Old 06-17-2020, 07:56 PM   #7
golemslord
Nope it does not get worse with acceleration. In fact it feels better since maybe I'm pushing onto the pedal instead of resting on it, feeling less vibration
Old 06-17-2020, 09:15 PM   #8
radroach
Drives: car
Tire condition. Check your tire pressure, get it perfectly balanced.
Old 06-17-2020, 11:36 PM   #9
sato
sato's Avatar
How about at different speeds? It's the frequency of vibration higher at 70mph vs 35mph?
Old 06-18-2020, 05:30 AM   #10
golemslord
I'd say its a bit higher frequency at higher speeds
Old 06-18-2020, 05:38 AM   #11
golemslord
Now that you mention this, there's vibration in the brake pedal and clutch too if i rest my foot on there during cruise. So most likely it's the floor vibrating...but there's not much when I actually rest my foot on the floor ��
Old 06-18-2020, 06:23 AM   #12
golemslord
Just to add, there's also a slight noticable humming sound from the tires. I will have the tires balanced tomorrow and see if it fixes the issue
The Following User Says Thank You to golemslord For This Useful Post:
sato (06-18-2020)
Old 06-18-2020, 04:51 PM   #13
sato
sato's Avatar
Humming tends to point towards wheel bearings, IMO. Still, wait until wheel / tire combo is balanced. IF they allow you to, remember to observe wheels and tires while they are being checked on the machine.
Can you precise if that humming present with the previous tire, wheel combo? It's difficult since bearing noises come in gradually, unless a pothole eats one up.
Old 06-18-2020, 05:50 PM   #14
golemslord
Just had tire balance done and it has definitely made the vibrations less noticable but is still there. I guess I can stick with this and be less ocd about it lol. Maybe it's just our cars being more "road feeling" and I'm just worrying too much? Or maybe it's the summer tires
The humming I believe might be normal tire sounds and just overthinking. Is present before and after tire balance
I notice they did add more wheel weights to the front two wheels after the balance**
Cusco Pedal Install & Pedal Lateral Stiffening (Sideways Loose Pedal) BOND007_LTK DIY (Do-It-Yourself) Guides 5 05-20-2022 05:12 PM
Gas pedal vibration? Need help/solution golemslord Issues | Warranty | Recalls / TSB 3 02-21-2020 05:58 PM
New owner! Question about warranty and brake pedal vibration BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 2 12-10-2014 01:22 PM
gas pedal vibration nfaj BRZ First-Gen (2012+) — General Topics 6 09-28-2014 04:25 PM
BRZ Funny vibration on clutch pedal jason_srdet Issues | Warranty | Recalls / TSB 2 08-08-2014 09:45 PM
