Old 06-12-2020, 01:09 PM   #1
chojuan30
Drives: 2015 frs
Rear Z32 Brakes with STI Rotors
Hello Guys, I wanted to contribute a little to the forum since I have taken so much from it. I did a front brake upgrade and wanted to upgrade the rears. My first option was the EVO calipers, but this would shift brake bias too much to the front. Then I looked at Z32 with the KNS bracket. This setup uses the stock rotor and would also lead to too much front brake bias. So, as with everything in my life, I need or want something that does not exist. Made some calculations and using the STI rotor with Z32 brakes would give me 68 and change front brake bias. This led me to make my own brake bracket. Took measurements many times and a couple of 3d printed iterations, I send the model of the bracket to a company called sendcutsend. They specialize in laser cutting metal. They are cheap and fast. I designed the bracket flat to use this company and minimize cost. The biggest hurdle was that they did not have the material thickness I needed and this is the dimension that determines the lateral offset of the caliper. So, I had to grind it to the required thickness.
Bought the caliper from offer up at $80
Powder coating was $150 ( a little too much)
Bracket was about $60 for the pair
Rotors from KNS
Braided lines
Caliper rebuild kit
A few bolts from the auto parts.
I have been driving for more than a month on a 30 mile each way Miami commute and they feel great. I will update when I take it to the track.
I will be happy to answer any question.
JDC
chojuan30 is offline   Reply With Quote
The Following User Says Thank You to chojuan30 For This Useful Post:
Tokay444 (06-18-2020)
Old 06-12-2020, 01:09 PM   #2
chojuan30
Drives: 2015 frs
Pics did not upload. I will try again
Old 06-12-2020, 10:51 PM   #3
overd0sed
Drives: 2016 FRS RS2, (sold) 2019 Raiu BRZ
What wheels are those?
overd0sed is offline   Reply With Quote
Old 06-13-2020, 04:49 PM   #4
chojuan30
Drives: 2015 frs
Rota dpt 18x8.5
Old 06-15-2020, 12:07 PM   #5
KnightRyderx2
Drives: 2014 FR-S
I have been wanting to do a brake swap for a while now. I already have Skyline/Z32 front calipers sitting in storage just waiting to be used. I have debated this for the rear as I have seen this a few times on NASIOC for the early WRXs. This is awesome that I finally see it.
What specific rotors did you use? I know it says STI but what year and if you could put a part number. Also I'm wondering about the caliper brackets and how I would get myself a set. I'm wondering if I could give them a call and tell to use your file to make a set or what.
KnightRyderx2 is offline   Reply With Quote
Old 06-17-2020, 12:39 AM   #6
kevtronzero
Drives: 2013 Subaru BRZ / 2011 Lexus ISF
Anyway you could get another pair of brackets made? I'd definitely buy them!
As for the brake lines and banjo bolts, is it specific to the BRZ or is it a conversion brake line?
kevtronzero is offline   Reply With Quote
Old 06-17-2020, 12:14 PM   #7
chojuan30
Drives: 2015 frs
the KNS part number for the rotor is DBA2656S-10. I couls provide you with the file and material I used. I was a little paranoid on the material, so I ordered them in AR-400. This is extremely hard and not very machineable, so they had to be ground to .22".
KnightRyderx2 (06-17-2020)
Old 06-17-2020, 12:23 PM   #8
chojuan30
Drives: 2015 frs
https://www.ebay.com/itm/202746517581
This is the brake lines I ordered. The banjo bolt was a little too long and had to be shortened. Like I said above I could provide the DXF file of the bracket.
and I just cket the invoice for the bracket and it was 29 for the pair
Old 06-17-2020, 12:54 PM   #9
chojuan30
Drives: 2015 frs
https://www.dropbox.com/s/7zkedy4i25..._Brkt.DXF?dl=0
Dropbox link to bracket DXF. Let me know if it works.
Old 06-17-2020, 04:05 PM   #10
KnightRyderx2
Drives: 2014 FR-S
Thanks!
Old 06-18-2020, 12:29 AM   #11
kevtronzero
Did you remove the orifice inside the caliper? Maybe that is what the banjo bolt was hitting?
Old 06-18-2020, 10:53 AM   #12
chojuan30
Drives: 2015 frs
No. how would I do that?
Old 06-18-2020, 11:20 PM   #13
kevtronzero
Use a drill bit to drill the hole of the orifice a little bigger and then use a extractor to take it out. Since the Z32 doesn't use a banjo bolt from factory, if you take the orifice out it allows you to use a banjo bolt and screw in deeper.
The Following 2 Users Say Thank You to kevtronzero For This Useful Post:
Bach415 (12-03-2024), chojuan30 (06-19-2020)
Full 4 corner stock Brakes, Brake Pads, and Rotors jflogerzi Brakes, Suspension, Chassis 4 09-22-2020 11:10 PM
OEM Brakes and Rotors and front Calipers (Used for 30K miles) Alltezza Brakes, Suspension, Chassis 0 08-29-2018 06:24 PM
OEM Calipers, brakes and rotors. 800 miles driven RUNAMUK Brakes, Suspension, Chassis 3 05-24-2013 05:04 AM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 06:20 AM
