Drives: Scion FR-S
Help!!! LOST Wheel Lock Key
I lost the key to my locking lug nuts and need help figuring out which key to get! I bought a key, but it was too small. I’m trying to remove the wheels so I can replace the brake pads ASAP. I have a buyer waiting for the car!! Any help is appreciated thanks!
UPDATE: Thanks everyone! I took it to my local wheel shop and they were able to remove them! Last edited by isaiah990; 06-04-2020 at 02:51 AM. |
#2 |
Just sell the car.
Sent from my SM-G975U using Tapatalk |
#3 |
Drives: Scion FR-S
Hahahaha I’m actually the one buying it, I just posted for the owner, any help is greatly appreciated!!
#4 |
You might consider taking the car into an automotive shop, maybe they can rattle it off.
Bubba says he can take it off with a cold chisel and a BFH -
#5 |
Any tire shop will have something to work.
#6 |
ProCrastinationConsultant
tire shops usually have 2 immediate methods of removal.
1. they rummage through a random box of assorted wheel locks that have gone missing under mysterious circumstances over the years until they find the one that works. 2. they keep a bunch of high quality full-replacement-warranty sockets on hand. they beat the nearest size on with a hammer, and then impact it off, discarding the lug, and warrantying the socket for next time. or, if you're me, you buy aluminum lug nuts because they look pretty, they seize onto the studs due to the miracle of galvanic corrosion, and the only way out is to use an air hammer with a splitter end, and split the lug off, like splitting wood... i actually sold the car before doing anything with it.
| The Following User Says Thank You to soundman98 For This Useful Post: | p1l0t (06-03-2020) |
#7 |
Rust bucket enthusiast
In the old days, we had to weld a nut to the end!
Really though, bring it to a shop with the intent to buy new ones |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | soundman98 (06-03-2020) |
#8 |
There is a set of tools for removing stripped nuts or bolts. They look like sockets but are meant to be tapped on and then wrenched off. The only possible problem could be the tool wall thickness as these are deep set.
| The Following User Says Thank You to ls1ac For This Useful Post: | soundman98 (06-03-2020) |
| I just lost 1 pcs of adhesive weight on the wheel | mitama | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 07-31-2019 04:52 PM |
| East Bay NorCal: OEM Wheels, free wheel lock set and wheel totes | akacinna | Wheels and Tires | 2 | 05-07-2018 01:53 AM |
| Help! Lost Wheel Lock Key | DonAngeloDM | Northern California | 4 | 04-28-2016 03:10 AM |
| Lost wheel lock nut - what to do next? | Trikle | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-17-2015 01:55 PM |
| Wheel lock on only one per wheel: unbalanced? | stocktc1 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 03-24-2013 12:37 PM |
