Old 07-22-2012, 12:35 PM   #15
catharsis
Drives: honda civic si 08
The rev limiter is there to keep you from damaging the engine. Many people have already explained what it does. Anyways hitting it for a few seconds doesn't hurt anything. Now if you try to be ken block and bounce off the rev limiter constantly like you're doing gymkhana you're gonna damage something. Hitting rev limit is fine, what you should be worried about is down shifting and over reving the motor. That is very dangerous.
catharsis is offline   Reply With Quote
Old 07-22-2012, 08:34 PM   #16
mike2100
mike2100's Avatar
Drives: 23 BRZ
Originally Posted by Snoopyalien24 View Post
Oh yeah, my fault. But still, that could help ?
Only if you're aware. Otherwise the flashing triangle is just an ignored suggestion.
mike2100 is offline   Reply With Quote
Old 07-22-2012, 10:49 PM   #17
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Originally Posted by catharsis View Post
.... Hitting rev limit is fine, what you should be worried about is down shifting and over reving the motor. That is very dangerous.
Yup... I think every manual driver has accidentally done it at least once in their life... smart ones put the clutch back in ASAP!
Kwaziekeller is offline   Reply With Quote
Old 07-23-2012, 12:13 AM   #18
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I did it before I rebuilt the engine in my other car (it wasnt rebuilt due to this ). Went from 5th to 2nd at ~70mph - I was aiming for 4th, but had been driving my brothers car that week leading up to it and his transmission was like driving a tractor. I caught it when the rpms just crested 7k rpm, and I nearly shit myself. I babied the car for about a week straight just to make sure there were no issues.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 07-23-2012, 01:42 AM   #19
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I've hit the limiter a few times in this car so far. It is a very soft limiter compared to other cars I've driven. You hardly notice that you have hit it at all.
FrX is offline   Reply With Quote
Old 07-23-2012, 02:06 AM   #20
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
Basically, yeah. I had just put the near-solid engine mounts on my Si and it was shifting like butter after that. So good that well.. I didn't feel any resistance from 3->2 instead of 3->4 @ 72mph. Unexpectedly, I was thrown into the windshield pretty much and saw the needle bounce past 9k (ScanGauge recorded ~9400 rpm) before I clutched back in very, VERY quickly.
Did a compression test and everything was fine, damn K20 was a tank! I've been told it can take up to about 10k rpm on the factory internals. Phew...
As for the limiter, you could bounce off it all day and the car would be fine (within reason). It's just not very smart to because it's not beneficial to you to sit on it. Sure, hit it and quit it (shift) sometimes, but you're better off shifting before it. I have my shift light set to 6600 (buzzer on) so by the time the light comes on, I'll have a good second to shift before fuel cut. Obviously, I usually shift far before this but it's just based on feel/style/hearing the engine. Some days I like winding her up to 5k and beyond, other days I go for economy at 3k-4k. Sadly, I can't shift before 3k without feeling like a granny.
eriktherod is offline   Reply With Quote
Old 07-23-2012, 02:20 AM   #21
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Does anyone else that has the buzzer turned on have trouble hearing it? Its very faint and I need to listen really closely. The engine noise nearly drowns it out.
Parting out HERE
Old 07-23-2012, 02:46 AM   #22
inz
Drives: GTi-R
Just to clarify, I was originally making a need for speed reference about the light and the perfect shift...
inz is offline   Reply With Quote
Old 07-23-2012, 02:50 AM   #23
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
LOL.. read mine... (This was back in 2001) I was racing a friend and went from 3rd @90 mph to 2nd trying to go to fourth ... it wasn't pretty. The car revved to 10k something. It was a single cam civic. I put it in neutral too late. Engine stalled. It would never again turn on. When it was taken apart, two pistons MELTED , valves where nowhere to be found just an amazing mess. My friends could not believe it wasn't running NOS. Also, I still can't believe how a Rod didn't fly out.
Old 07-23-2012, 06:10 AM   #24
mike2100
mike2100's Avatar
Drives: 23 BRZ
I am so glad I decided to buy my FR-S new and not wait to buy used.
Old 07-23-2012, 05:22 PM   #25
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Parting out HERE
Old 07-23-2012, 06:27 PM   #26
EsoBOFH
Senior Hoonigan
EsoBOFH's Avatar
Drives: 2016 Hot Lava 6MT FR-S
The rev-limiter in this car is extremely soft... it doesn't feel like "hitting a wall" at all - in fact it seems designed for hoonigans to just allow the car to sit softly on redline without going over. It's fantastic.
You can literally sit there, throttle to the floor, doing donuts all day and the limiter just keeps the engine in a happy place.. it doesn't bounce off and cut out like most cars.
That said, I haven't tested this at the high end, where the limiter is being cut out due to vehicle speed (rather than engine speed).. someone mentioned this was like hitting a wall, but I can't verify personally.
EsoBOFH is offline   Reply With Quote
Old 07-23-2012, 06:29 PM   #27
EsoBOFH
Senior Hoonigan
EsoBOFH's Avatar
Ditto.. have never heard it, and i have it turned on... *shrug* guess it's too quiet..
Old 07-23-2012, 06:46 PM   #28
SkullWorks
Drives: SSM LT MT BRZ
Originally Posted by inz View Post
It is not a spark cut, unless you run a missfire system... Which you're not. Because you're missing a TARBO.
The car doesn't pull the hardest near redline. That is stupid. Cars aren't built from factory with peak torque at 8000RPM. After all - these are street cars. Cars travel FASTER at 8000 rpm than they would at say, 6000rpm. But power is not torque. And torque is what puts you back in your seat.
The only difference between 4000rpm and 8000rpm is about 4000rpm. The engine does all the same things. Rev limit protects the head from things like valve float.
Also, of you look carefully, there is a light on the dashboard that flashes when you make a "perfect shift" and you will get a little boost in acceleration...
Sooooooo much win I almost cried....
Bravo sir Bravo,
makes me want to play need for speed
RedLine Tuning Hood Quick Lift tonystewart Cosmetic Modification (Interior/Exterior/Lighting) 4 12-15-2012 12:28 PM
Fr-s vs. Saturn Sky Redline - would your rather Gabriel FR-S / BRZ vs.... 7 06-07-2012 12:57 AM
Reaching QC trueno86power Other Vehicles & General Automotive Discussions 4 11-06-2011 06:45 PM
Engine 7500rpm redline KiingDavid Engine, Exhaust, Transmission 20 03-13-2011 07:04 PM
