go_a_way1
Old 05-01-2020, 07:28 PM   #5475
CSG Mike
CSG Mike's Avatar
Originally Posted by stacyu18 View Post
for anyone thinking about installing the c38 supercharger by yourself let me tell you that it is no easy process. I work on cars for a living and know what i am doing but to the normal person it will be a bitch. the best thing to do is break it down into days.day 1 take off the tires,fender wells,the under cover then the bumper.day 2 install the super charger. day 3 install the inter cooler and piping for me this was the most time consuming job due to the fact you had to make sure that the piping was set well enough that you could fit your headlights in and make sure that you have a screw gun or electric screwdriver and tape measure this will help a hell of alot. day 4 install the oil cooler and lines. day 5 install the tune check all hoses for leaks make sure that nothing is going to rub the fans or engine to burn anything and take car for test drive. day 6 if all is good and car is not leaking reinstall the bumper,fender wells,under cover and make sure that you didn't forget anything. some people may just say or take it to a shop to have done,well you can do that also but a extra 1000 dollars is a lot to some people.so i hope this help some people out. good luck on your adventure if you do it yourself.BTW each day maybe up to 3 hours.
The first time will always be the toughest! The first time I attempted an installation, it took me about 12 hours.
HachiRokuX (05-17-2020)
Old 05-09-2020, 12:02 PM   #5476
mrhemi
Just started the install on my 2013 day before yesterday. Taking my time, put in a few hours each day. Lots of down time due to the "plague", so no rush. About half way through the install with no issues so far. I have a bad back so utilizing a four post lift for the work. That makes a world of difference on the body (mine).
mrhemi is offline   Reply With Quote
Old 05-14-2020, 11:49 PM   #5477
mrhemi
Finished the install this afternoon. Started up ran for 15-20 min. to check for leaks. Test drive tomorrow weather permitting. Took me about 12 hours total over a few days.
The Following 2 Users Say Thank You to mrhemi For This Useful Post:
CSG Mike (05-15-2020), sroby (05-24-2020)
Old 05-15-2020, 06:52 PM   #5478
peaches
Drives: '14 BRZ Limited
Finally ordered the dedicated oil cooler from CSG, have all the other pieces ready.
peaches is offline   Reply With Quote
The Following User Says Thank You to peaches For This Useful Post:
Old 05-17-2020, 10:39 AM   #5479
mrhemi
Went for about a 100 mile shake down cruise after the JRSC install. All good. No issues or leaks apparent. BRZ is a blast to drive now. Also painted the scuffs on the bottom of the front fascia with truck bed liner while it was off for the supercharger install. Topped it off with ProTeck skid plates as well.
CSG Mike (05-18-2020), HachiRokuX (05-23-2020)
Old 05-23-2020, 07:43 PM   #5480
fatoni
if you get the carb sc and then later decide to go with a custom tune, how will governing bodies ever be able to tell?
Drive upgrades. Don't buy them.
Old 05-23-2020, 08:58 PM   #5481
peaches
Finally took some time to install the dedicated oil cooler. No pictures of that as most of you know it but wanted to share a couple of things.
@ML shared a few tips to help with the temp issues, I was able to do 2 of them: reflective tape on the pipes and a custom piece to help direct the airflow better. I tried to do the cold air intake he mentioned but the coupler was too big to fit in the opening so I left it out. It's a 3" U coupler + a filter. If someone wants these parts, let me know. I think the radiator I have doesn't provide enough clearance.
@ML what radiator do you have?
As for the custom pieces, they're made out of Polyethylene. You can see with a flashlight how much space is left after having the stock piece around the IC pipe. Air is definitively leaking through there and not going through the cores.
After cutting the foam to fit you can see the difference (yes, the flashlight is still shinning).
Every little bit counts, the air has nowhere else to go but through the cores. View from the outside:
And the other side:
After the foam
Haven't been able to start her up, the stupid adapter for the oil filter won't come loose from the old sandwich plate so I need to get a new one. The adapter for this kit is thermostatic while the adapter from the DROC is not.
If someone wants to try this, I have Polyethylene left. Send me a PM and I'll ship it to you.
The Following 5 Users Say Thank You to peaches For This Useful Post:
alphasaur (06-11-2020), BatStig (01-17-2024), CSG Mike (05-24-2020), mrg666 (05-24-2020), tfp (05-27-2020)
Old 05-23-2020, 09:08 PM   #5482
jflogerzi
jflogerzi's Avatar
And the other side:
After the foam
You went from the dual oil/rad to a dedicated one correct?
2013 Series 10 FRS #553
Old 05-24-2020, 12:30 AM   #5483
sroby
Drives: 2015 Firestorm 08/05/15
Stuck thermostatic oil cooler plate
And the other side:
After the foam
Peaches tech tip to try: As a retired Air Force F-15, C-130 and Aerospace Ground Equipment mechanic, when we would have to change a nose gear bearing set. We would pack the spindle in dry ice for 20 to 30 mins. It constricts the metal or alloy (shrinks it ever so slightly). Light tap with a mallet and they pop right off the spindle. That’s per tech data.
I realize this is not an aircraft nose gear bearing set, however I have used this technique on my lawnmower shaft before in trying to get the collar off. It has worked every time. Maybe give this a try I’ll bet it will release. Especially as the O-ring shrinks as well. Hope this helps. Steve
I forgot. Publix grocery store sells dry ice. If not. Throw that sucker in your freezer for about an hour. Positive results will occur.
sroby is offline   Reply With Quote
The Following 2 Users Say Thank You to sroby For This Useful Post:
Old 05-24-2020, 06:35 AM   #5484
CSG Mike
CSG Mike's Avatar
Even just normal ice in a ziploc bag will cause noticeable shrinking
@peaches fantastic work!
sroby (05-26-2020)
Old 05-24-2020, 08:13 AM   #5485
peaches
Yes, that's what I have. I removed those lines and capped the ends of the radiator.
Old 05-24-2020, 08:14 AM   #5486
peaches
I ended up getting a replacement piece from a friend, took me over an hour to re-route the lines so they wouldn't be kinked. Going to run it for a while and makes sure there are no leaks, then I'll go for a ride and log some temps.
Old 05-24-2020, 11:47 AM   #5487
ML
ML's Avatar
Drives: 13 White MT FR-S
@peaches I have a Koyo rad.
Old 05-24-2020, 12:08 PM   #5488
jflogerzi
jflogerzi's Avatar
Good to know that's an option in the future if need be
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
