#70183 | |
The new one (with fuses) worked fine for a while, till the rats started chewing through the knob and tubing wiring in the house. So I put pennies behind the fuses, that fried those rodents real good. |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#70184 | |
Don't ya'll have to get permits to mess with gas lines? Re-venting the water heater - you do have new batteries in your CO detectors? Yep, I don't mess with gas anymore, since I had a gas hot water blow up in my face back in the day. That's all fer now -
| The Following User Says Thank You to humfrz For This Useful Post: | soundman98 (05-23-2020) |
#70185 | |
Famous Potatoes
Drives: '15 ultramarine
I would be more worried about venting. |
| The Following User Says Thank You to Sapphireho For This Useful Post: | soundman98 (05-23-2020) |
#70186 |
Famous Potatoes
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | humfrz (05-24-2020), soundman98 (05-23-2020) |
#70187 | |
bah dum chish Sent from my SM-G975U using Tapatalk |
| The Following 2 Users Say Thank You to p1l0t For This Useful Post: | humfrz (05-23-2020), soundman98 (05-23-2020) |
#70188 |
Drives: car
Bought a bunch of whiteline parts, positive traction kit and the subframe inserts. Already have the transmission insert.
I am on stock tire size 215's with fresh Firestone Indy 500's. Will tightening up the rear end overload the stock tire size? |
#70189 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Pinch it up a bit, then see how much it wobbles?
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | Ultramaroon (05-23-2020) |
#70190 |
Site Moderator
Drives: ichi 86 Project
Marking up the rear diffuser... trying to figure out best area to tie em in. Front part, I could use rear sway bar (where chassis & sway meet). Rear... not fully sure, but I’ll prob need 2 in the middle, 1 on each side to hold em down.
| The Following 2 Users Say Thank You to ichitaka05 For This Useful Post: | NoHaveMSG (05-23-2020), Ultramaroon (05-23-2020) |
#70191 | |
Depends on the pressure. Look it up. Save yourself a lot of grief by agreeing. If you don't, I'll enlighten you after my Saturday, long nap. ZZZZZZZZZZZZZZ |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | p1l0t (05-23-2020), soundman98 (05-23-2020) |
#70192 | |
Iffen you need some help with duck tape and baling wire techniques, I'll get Bubba on the horn.
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | ichitaka05 (05-23-2020), soundman98 (05-23-2020) |
#70193 | |
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#70194 | |
![]() Of course, Idaho may be different - do they have building codes in Idaho? - ![]() Is it ma nap time yet?
#70195 | ||||
ProCrastinationConsultant
in the process, learned one of my neighbors has been asking everyone else on the block if they've seen me. apparently she thought i died. her reasoning was because i haven't done anything with my landscaping(despite the fact that i've waved to her twice while mowing the lawn). she's a little, um, interesting. but a nice lady anyways... Quote:
according to my retired neighbor expert, it's the proper way to finish the surface, besides getting a vinyl sealant, which isn't really worth it to me. it's a 4" thick pad(on the heavy side of 4-4.5") on 5-10" of triple-compacted crushed rock. if it moves, i've got much bigger issues. like militant ants. Quote:
![]() yes, i keep the CO with new batteries, even hold the test button every once in a while to make sure it still hurts my ears. i'm planning on loading up on soapy water, and will be checking, rechecking, rerechecking and rererechecking everything. did my dryer a while back. still checking for leaks just in case! Quote:
https://cleanfit.com/blue_monster_in...l#sealant_ptfe the shutoff and all the fittings appear to all be in place. there's a union between the shutoff and the water heater, so i shouldn't even need to do anything upstream of the shutoff. i read the manual! 55' max vent distance, currently 44' with bend extension calc, 1/8" rise over 10'. crooked pipes are easy. it's making them straight that gets difficult!
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
#70196 | |
Drives: Crapcan
Don’t. It’s a pain in the ass to mount it to the sway bar. Make a bracket.
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 08:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 11:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 11:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 06:18 AM |
