Old 05-23-2020, 05:03 AM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Differential Had Water
So I just changed differential fluids, and when i did, color was a very off-white cream which probably meant water ingress in the past when i drove through some floodwater.
In hindsight i forgot that maybe I should have flushed it first with extra fluid but I forgot to.
So i just have two concerns:
Will not flushing again basically contaminate my new diff oil and harm my differential?
And i noticed my diff drain plug surface area was covered completely in metal powder. Ive been driving like this for about 7,000 miles. Was this a sign of significant damage?
leevanf is offline   Reply With Quote
Old 05-23-2020, 04:21 PM   #2
Iron powder on the drain plug is normal. Magnet is there to collect the wear particles over the life of the diff.
I'd drive, drain, and refill for good measure. If the diff doesn't leak or growl, drive on happily.
Dave-ROR (05-24-2020), Spuds (05-24-2020)
Old 05-23-2020, 06:18 PM   #3
ls1ac
ls1ac's Avatar
As said change the fluid then check after 500mi. if still has white, do it again.
If it starts to clunk on and off throttle then there is a problem.
The Following User Says Thank You to ls1ac For This Useful Post:
Old 05-23-2020, 11:19 PM   #4
leevanf
leevanf's Avatar
Thanks! Must be getting paranoid because i was running it this way for a good 9 months or more
Old 05-24-2020, 01:35 AM   #5
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I would do a flush, or use junk diff oil and change it several times over a month until the oil coming out looks water free then put in the good oil. The water probably caused extra wear, but what can you do about that now?
Old 05-24-2020, 03:07 AM   #6
Shit, that's a long time. At least be prepared for the possibility of early failure. Keep listening to it and consider obtaining a spare from a salvage donor.
Old 05-24-2020, 06:58 AM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
Poor fucking design.. much like the brake calipers... I mean if the car is going to a country where floods are common you'd think that designer would install the diff away from the possible flood level.. stick it on the roof..
The Following 5 Users Say Thank You to JD001 For This Useful Post:
Dave-ROR (05-24-2020), Opie (05-26-2020), Silviacrazed (05-24-2020), soundman98 (05-24-2020), Spuds (05-24-2020)
Old 05-24-2020, 02:25 PM   #8
extrashaky
Pft. Differentials can go a long time with water in them. It's not good for them, but it's not like water in an engine. Just change the diff oil and drive.
The Following User Says Thank You to extrashaky For This Useful Post:
Tcoat (05-24-2020)
Old 05-24-2020, 03:46 PM   #9
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
cooling the diff quickly..ie quenching it in water, tends to suck water up the vent.
you might extend the vent line if standing water is typical. (transmission also.)
thomasmryan is offline   Reply With Quote
The Following 2 Users Say Thank You to thomasmryan For This Useful Post:
soundman98 (05-24-2020), Ultramaroon (05-24-2020)
Old 05-24-2020, 05:32 PM   #10
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I too would fill with fresh oil, drive a couple hundred miles, drain, lather, rinse, repeat until it comes out clean.
Old 05-24-2020, 07:13 PM   #11
Leaky check valve, or just weeping through seals under vacuum?
My diff makes a nice sucking sound when I remove the fill plug.
Old 05-24-2020, 07:28 PM   #12
soundman98
ProCrastinationConsultant
soundman98's Avatar
wouldn't a thorough diff flush service do the same thing without the massive time sink of hundreds of miles of driving?
Old 05-24-2020, 10:31 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
This. Change it again for sure. Or just disassemble, clean it and lube it back up and just let it rip.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-25-2020, 07:19 AM   #14
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I've never seen a diff flush service. I didn't know they existed, but yea, sounds good.
Ultramaroon (05-25-2020)
Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover mav1178 Engine, Exhaust, Transmission 5 02-11-2021 02:20 PM
Is my differential about done? LotsaMiles Engine, Exhaust, Transmission 14 07-30-2019 10:31 AM
WTB: Differential ArCha Canada Classifieds 3 02-27-2018 02:09 PM
WTB : Differential ebphoto Want-To-Buy Requests 2 06-19-2016 02:46 AM
Anyone have a differential pop yet? slicktop Engine, Exhaust, Transmission 6 02-26-2014 09:22 PM
