#211 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
PROcede ESC User Software!
Remove the connection to the phantom controller. You can modify the map to read full throttle at any location of your choosing, just change the square you are in to 100 on the procede map. Turn car on and read the procede voltage. Read the voltage on the wire you removed from the phantom and any ground. Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#212 | |
Drives: Asphalt FRS 2014
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
#213 | |
heres mine https://drive.google.com/open?id=0B1...G43aUtZTFBNOTQ
#214 |
Also if the map above doesnt work, PM me... I may have a solution.
#215 | |
. By the way, your map is ...sporty. I like it!
| The Following User Says Thank You to j_Zer0 For This Useful Post: | Sojhinn (07-15-2017) |
#216 | |
Good to hear! 4.7 v should be full boost . But just make sure you don't go all the way to the right on full throttle.... But if you are happy don't mess with it... I've had issues with remapping the throttle on the procedes Sent from my iPhone using Tapatalk
#217 |
Drives: GT86 2013
Sorry for necroposting, but I just installed a Phantom and Procede and would like to know what Procede maps you guys are using. Thanks!
#218 | |
Drives: SWP BRZ
Send "keen as" a private message requesting a copy of his version of a "Sojhinn" Proceed tune. It's really excellent. ESC feeds in around 2000 rpm when under load so you don't have to change down as often, and is smooth throughout the rev range. Totally transforms the car. |
#219 | |
Drives: GT86 2013
Thanks! I have been collection tunes from the forums and I have found "SOJHINNrev2" and "sojhinnrev4". Is it one of these you refer to? I found the rev2 good. It's very similar to OFT's "Sport Throttle" tune. However, I found the rev4 a bit to conservative. The ESC almost never went 100% at low engine revs (where it makes the most boost). |
#220 | |
Drives: SWP BRZ
No, "keen as" started with one of sojhinn's proceed tunes. He went through a number of variations before finalizing. I'm sure he would be happy to send you a copy to try. |
| The Following User Says Thank You to Gums For This Useful Post: | mrjj (05-15-2020) |
#221 | |
Drives: 86 GT MT
https://drive.google.com/file/d/0Bwi...ew?usp=sharing |
| The Following User Says Thank You to keen as For This Useful Post: | mrjj (05-19-2020) |
| What does your user name mean? | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 355 | 05-01-2016 09:52 AM |
| OFT: New firmware and new user software | Shiv@Openflash | Software Tuning | 9 | 10-15-2014 03:45 PM |
| EcuTek End User/Retail Tuning Software Release! | Dustin@Dynosty | Forced Induction | 27 | 12-19-2013 10:17 AM |
| user tags | scottmcphee | Site Announcements / Questions / Issues | 3 | 04-11-2013 04:15 PM |
| User name | trueno86power | Site Announcements / Questions / Issues | 7 | 11-28-2012 01:48 AM |
