Old 05-13-2020, 02:15 AM   #113
soundman98
ProCrastinationConsultant
soundman98's Avatar
Yeah, I've never liked the concept of using a metal tubing with a highly pressurized gas as an electrical grounding point
Old 05-13-2020, 03:06 AM   #114
soundman98 (05-13-2020)
Old 05-13-2020, 03:13 AM   #115
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I'm still on my factory battery. DOM 06/2013
mine's got to be pretty close to that same age.
Mine lasted 2 years and was weak within the first year of purchase. Perhaps the Panasonics dont like heat? I took the car to the track within the first month in +110 ambient temps.
Intent > Content
Old 05-13-2020, 03:45 AM   #116
Like @RZNT4R said, all lead acid batteries don't deal well with heat. My battery used a lot of water the first few years. It's probably time for me to check it again.
https://parts.toyota.com/go/genuine-...batteries.html
solidONE (05-13-2020), soundman98 (05-13-2020)
Old 05-13-2020, 06:51 PM   #117
DarkSunrise
DarkSunrise's Avatar
110F ambient temps is hot! I've tracked mine plenty of times in humid 90-95F temps and my OEM Panasonic lasted 8 years.
2022 BRZ Build
2013 FR-S Build
Old 05-13-2020, 11:29 PM   #118
radroach
Drives: car
The last time I started on the Panasonic battery it was so low (but had enough juice to turn over), the starter turned over once and then the whole car paused for 2 seconds and then compression started at like 1 rpm.
Old 05-14-2020, 12:27 PM   #119
solidONE
solidONE's Avatar
Wow.. So you're still on the original. I'm sure our cars ave similar build dates. Sprayed white by the same robots and most importantly the same batch of batteries.
Intent > Content
Old 05-14-2020, 01:43 PM   #120
DarkSunrise
Haha my paint robot must have been having a bad day based on the color mismatch between panels.
Yeah I replaced my OEM battery about a month ago. 8 yrs is the longest I've had any factory battery last on any of my cars, but it was starting to struggle especially on e85 cold starts.
2022 BRZ Build
2013 FR-S Build
Old 05-14-2020, 02:13 PM   #121
solidONE
solidONE's Avatar
I'm surprised this battery can last more than 3 years. Any special maintenance beside topping the acid?
I made sure my Panasonic was completely dead before I replaced it.. cause i had no choice but to lol
Our robot was not good at matching bumper to quarter panel paint..
Intent > Content
Old 05-14-2020, 02:24 PM   #122
DarkSunrise
I actually never really messed with the battery until it came time to replace it, other than hook it to a tender when I wasn't going to be using it for more than a couple of weeks.
Yeah the bumper color match is horrible. Looks like a poor aftermarket job.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
solidONE (05-14-2020)
Old 05-14-2020, 02:37 PM   #123
solidONE
solidONE's Avatar
So random.. randomly good for you, but randomly bad for me.
Intent > Content
Old 05-14-2020, 05:06 PM   #124
mrg666
pessimistic skeptic
mrg666's Avatar
It has been some time since I posted here and two winters passed. I am still driving with Braille 21 without any problems. I will buy just buy the same again when replacement needed.
Old 05-16-2020, 02:01 PM   #125
phm14
Loves the Smell of Track
phm14's Avatar
Drives: '13 86
Originally Posted by ls1ac View Post
Unusually inexpensive good warrantee, Walmart. (three year save your recipe)
I used to run Optimas, and could get 6-7 years out of one in SE Texas heat. Would have never considered a Walmart battery, regardless of warranty. If you're remote back country, or your wife/family is counting on that battery to start the vehicle in a parking lot, the warranty ain't gonna get anybody home. Last October, the Wifes' 2015 4Runner oem battery finally succumbed to the Texas heat and short duration trips. It had been several years since I had bought a new battery, so I let my inner "research nerd" out and looked at Optima 1st. Didn't like what I found, so I start reading battery threads on forums like Yotatec and BITOG, and Excide comes up as the last battery company with US production and recycling, and they are one of the best availble in the US retail auto market. Turns out Walmart sells a quality Excide, rebranded. I can't recall the label, but it was the top of their in house range, $150 for the 4Runner. Walmart sells a range from different makers. The cheap ones likely fail 2-3 times more frequently than a battery that could be expected to live ~6 years plus in my environment. IIRC, a serial # starting with "E" or "EP" denotes an Excide product. I'm no expert, but if you want max battery life, it could't hurt to deep charge it with a good charger evry 6-12 months, depending on your application. The 4Runner isn't here ATM, but I think this is the battery I bought (will verify later): https://www.walmart.com/ip/EverStart...-24F/949625841
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD
http://www.ft86club.com/forums/showthread.php?t=7934
phm14 is offline   Reply With Quote
Old 05-22-2020, 03:36 AM   #126
ogada
Drives: bmw m3
best battery for daily driver
The problem with small light-weight batteries is they usually put out relatively low cold-cranking amps. This problem is magnified when you put the battery way back in the back and the current has to travel 15+ feet to get to the starter and alternator.
Just how heavy is the battery you were running before, and how soft are your rear springs? I can't tell any noticeable difference in ride height in the rear of my car between having my sub box and spare tire in vs. having them out (probably 80 lbs. total), and I only have stock ITR rear springs. Going by spring rate, it should only be about 1/4" difference in ride height at the most.
When I had 450 lb/in GC rear springs, there certainly was no discernable difference, as 80 lbs. would only compress the rear springs less than 1/8" on each side.
you can check this deepcyclebatterypros for some best battery list
ogada is offline   Reply With Quote
New to me daily driver.. 95 M3. Dave-ROR Other Vehicles & General Automotive Discussions 58 07-17-2014 03:05 AM
Is your FR-S your daily driver? Drive Scion FR-S / Toyota 86 GT86 General Forum 136 02-10-2014 10:10 AM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-16-2012 12:48 AM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) — General Topics 80 03-22-2012 10:50 AM
The daily driver KiingDavid CANADA 25 02-06-2012 02:14 PM
