Old 04-27-2020, 10:33 PM   #1
Rogue.86
Drives: Black
Turbo Frs CEL
So this is my first post but I have a Jdl turbo FRS tuned via Ecutek and I got a check engine light for the first after having the car turbo’d for 4 months and the engine codes were P0171 and P1171 I contacted my tuner and he said more than likely it’s the AFR and O2 sensors or the maf. So I decided in the mean time to Clear the CEL codes with my OFT and now my car is having really bad throttle response and feels like there’s no boost at all could that be that the OFT messed with the ECU? I know it was a stupid mistake to use the OFT to do that.
Rogue.86 is offline   Reply With Quote
Old 04-27-2020, 10:38 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Check for exhaust leaks at your header. Check for leaks at the evap solenoid under the intake manifold (straight under it, directly in line with the a/compressor)
Check all your intercooler piping. Also, datalog and post the logs here using datazap. Your tuner cannot help you if he's remote; find someone in person who can help resolve them. It's likely the car has no throttle response because it's yanking timing due to your fuel trims
Old 04-27-2020, 10:39 PM   #3
p1l0t
p1l0t's Avatar
It sounds like it's in limp mode. Usually that's when you have a code still though not after you erase them. I would scan again and make sure you have no codes still.
Old 04-28-2020, 05:28 PM   #4
Rogue.86
Drives: Black
Okay I will do all that and see what’s up thank you for the advice
Old 04-29-2020, 04:35 AM   #5
tomm.brz
Drives: brz 2017 hksv2
do you have logs? can you do them
Old 04-30-2020, 11:20 PM   #6
jflogerzi
jflogerzi's Avatar
Also use ecutek. Did you buy the full kit with cable or Bluetooth? You can clear codes with either.
2013 Series 10 FRS #553
Old 05-02-2020, 10:44 PM   #7
snowtaipan
snowtaipan's Avatar
Drives: '17 BRZ Series Yellow Edelbrock SC
What year? You sure it's P1171, I'm not seeing that listed.
I am working through P0170 P0171 P117B for my supercharged 2017 BRZ.
This should link you to the manual for TS-ing
https://demos.starbase7.net/t3Portal..._rm_index.html
Definitely agree with logging. If you haven't used datazap it's amazing.
snowtaipan is offline   Reply With Quote
cel, check engine light, jdl turbo, p0171, p1171
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
Bren5279's Full turbo partout (JDL uel turbo, Greddy Evo 3, AEM gauges, + More) VA bren5279 Engine, Exhaust, Bolt-Ons 69 06-29-2015 10:56 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
