Old 04-27-2020, 10:09 AM   #15
antoniogghaleb
Drives: Subaru BRZ
Thank you everyone for all the extremely helpful responses, just one last question, would I have to change the oil viscosity after supercharging too?
antoniogghaleb is offline   Reply With Quote
Old 04-27-2020, 12:29 PM   #16
86TOYO2k17
Drives: 2017 toyota 86
Depends on what your oil temps are.
If your average oil temp is 20F higher than before going up a weight would be good, if you have an oil cooler and its the same temperature as before and wasn’t a problem before then there is no point. You could swap to heavier weight oil just for when you go to the track. Or swap to heavier weight in summer.
The engine was designed for a specific viscosity. Going up in weight when temps are not increased means you will be running with a thicker viscosity than was intended/designed. Not the end of the world going up to the next weight. But temps determine viscosity and weight needed.
Old 04-27-2020, 12:52 PM   #17
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Hood vents and oil cooler are all I would suggest for cheap. Only one of my catch cans never really collects anything. No overheating or ridiculous oil temps on track even in New Orleans summer. Although I run a tune from Zach as the stock Edelbrock I initially received was terrible. tldr; oil cooler, vented hood, better tires.
B T is offline   Reply With Quote
Old 04-27-2020, 07:10 PM   #18
CSG Mike
CSG Mike's Avatar
Originally Posted by HaXx View Post
What purpose do hood vents serve? Do they help keep the compressors temperature down?
reduces under-hood pressure, enhancing airflow through your cooling stack, which ultimately also reduces charge temperature.
The Edelbrock is an air-pump, not an air-compressor.
HaXx (04-27-2020)
Old 04-27-2020, 07:10 PM   #19
CSG Mike
CSG Mike's Avatar
Unless you're also changing your engine's tolerances and oil flow passages, no.
Old 06-03-2020, 02:25 PM   #20
antoniogghaleb
Drives: Subaru BRZ
How much power do you think I'd be at with a Delicious D Box + Tune and a jdl uel header on pump gas? (With the supercharger of course)
Old 07-24-2020, 05:53 PM   #21
ArrrBussiere
ArrrBussiere's Avatar
Drives: 2014 Subaru BRZ SC & 2018 Tacoma
275-ish (give or take)
ArrrBussiere is offline   Reply With Quote
Turbo supporting mods mooseonskates Forced Induction 58 02-24-2020 11:04 AM
WTB Turbo and supporting mods OzzyGT86 Want-To-Buy Requests 2 08-26-2017 07:14 PM
E85, what are the best supporting mods? ProjectMidnight86 Engine, Exhaust, Transmission 9 06-25-2016 03:56 PM
What supporting Mods do you REALLY need? Adrian002 Forced Induction 27 05-09-2015 09:27 PM
Supporting Mods Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 02-21-2012 06:33 PM
