Old 04-23-2020, 10:16 PM   #1
TeeJayHoward
Drives: 2019 BRZ Limited
Schematic for power window switch?
The FSM doesn't appear to show the internal workings of the power window switch itself. Does anyone have a circuit diagram for the switch? (And, while I'm at it, for the motor?)
Note that I am NOT looking for the below photo:
I want something that looks more like this:
And yes, I know that it's a far more complex component. What I want to know is, how does it work? Where is the limit switch located - In the motor or in the switch? Does the motor handle auto up/down functionality, or is it in the switch? Does the motor have complicated enough circuitry that it's pulling in a data feed a la LIN (or even CAN) bus, or is it some sort of dual half-bridge setup?
And, for no real reason other than it's nearly impossible to find pictures of the window switch circuitry online, here's a few pics of the inside of one of the switches:
edit: Oh, and anyone know what SN1/SN2 stands for in the FSM diagram?
TeeJayHoward is offline   Reply With Quote
Old 04-24-2020, 12:23 AM   #2
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Best of luck on that. I'm interested if you will get any hits on that. Typically, as it's not a serviceable component, they don't release information on how it's manufactured.
sharpsicle is offline   Reply With Quote
The Following User Says Thank You to sharpsicle For This Useful Post:
soundman98 (04-24-2020)
Removing Window Switch Plate AD55 Cosmetic Modification (Interior/Exterior/Lighting) 5 06-25-2019 10:37 PM
Drivers window switch flashing - does nothing? STS-V Issues | Warranty | Recalls / TSB 4 08-11-2014 09:42 AM
Anyone have this window switch accent? BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 8 08-20-2013 05:29 PM
FRS/BRZ BRUSHED SATIN POWER WINDOW SWITCH TRIM zetaproducts.net Interior Parts (Incl. Lighting) 28 05-14-2013 10:32 AM
Window switch lights? Narcoden Scion FR-S / Toyota 86 GT86 General Forum 4 05-01-2013 08:17 PM
