#29 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
Though the OP did not ask...and I believe no one else even mentioned...
In manual mode the vehicle is gonna get worse fuel mileage. That would be the big difference. Most auto trans vehicles are designed to upshift early, boring, yet saves fuel. Last edited by ToySub1946; 04-23-2020 at 09:04 AM. |
#30 |
These trannys were great in the snow country.
Go directly from L to R or vice versa, rock the car, to get out of stuck conditions. Geezer memories...LOL |
#31 |
pessimistic skeptic
I have compared mpg. There is no difference when I shift manually for saving gas. I can also shift for performance driving, then all bets are off.
| The Following User Says Thank You to mrg666 For This Useful Post: | ToySub1946 (04-23-2020) |
#32 |
The Dictater
Drives: '13 Red Scion FRS
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | soundman98 (04-23-2020), Ultramaroon (04-23-2020) |
#33 |
Drives: Subaru BRZ Limited
serious question. Is is damaging to manually shift an automatic that doesn't have a "manual mode"? Every auto I've ever seen still has manual gear selections. Is it bad to use those to row through the gears or are they just made to hold the car in a certain gear?
#34 |
pessimistic skeptic
Unless you shift to opposite direction gear or park while the vehicle is still moving, manual gear shifting is never a problem. Automatic transmission shifts perfectly every time since the shift is actually done by the transmission itself. Just engine/transmission wear can be a problem when you hold the gear at low and drive at very high rpm for extended periods, not mentioning the waste of gas.
| The Following User Says Thank You to mrg666 For This Useful Post: | Spuds (04-23-2020) |
#35 | |
Try shifting from D to L at about 50MPH with a 64 Chev two speed Powerglide tranny and watch the show as everything locks up as the engine screams (believe me). Modern computer controlled trannies on the other hand would deal with it just fine.
#36 |
Drives: M5
#37 |
No replacement for the complacent?
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | soundman98 (04-23-2020), Spuds (04-23-2020) |
| Shifting Problem (Automatic) | FRSure | Issues | Warranty | Recalls / TSB | 61 | 05-09-2021 08:38 PM |
| Automatic Supercharged Gt86 Shifting Issue | Nawar | Forced Induction | 9 | 02-10-2019 03:25 AM |
| Automatic BRZ down shifting | eric2523 | Engine, Exhaust, Transmission | 12 | 08-20-2015 07:30 AM |
| Automatic Transmission Kick/Choke when shifting gears | Tech Gremlin | Engine, Exhaust, Transmission | 13 | 06-16-2015 02:54 AM |
| Paddle shifting automatic downshift | FR-YES | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-06-2012 10:18 AM |
