Old 08-29-2019, 12:20 PM   #169
Racecomp Engineering
Originally Posted by Velisma View Post
@Racecomp Engineering
Okay, so I just installed these today. Very easy, straight forward install BUT... I did notice a slight manufacture defect. I don't think it's a biggie but wanted to make sure just in case. The passenger front coilover top slotted mounting points for the hubs isn't the same as the driver side. Top driver side bolt installed back same as stock but I had to flip the passenger side stepped bolt the other way in order to insert it. It's all torqued to spec and I don't see it being a big deal but just wanted to be sure. Thoughts?
This is a standard thing with KWs for this platform. Weird, but not a big deal.
- Andrew
Old 08-29-2019, 09:12 PM   #170
KevBRZ
Drives: 15BRZ
alignment issue
So I got the SS1s installed and got an alignment done but haven't had a chance to drive it much so plan to do a review at a later date but so far they are great with ride comfort but anyhow, if i have the slot on the strut maxed out on both sides with crash bolts, what would be the reason that the top would need alot more adjusted on one side than the other to get alot of negative camber? ie like -3.0 camber, would it be a subframe issue, or something bent on the car?? The adjustment on one side is just about maxed out on top on the other side is was barely was moved.
KevBRZ is offline   Reply With Quote
Old 08-29-2019, 10:00 PM   #171
Send me a pm and we can work through this issue. Myles is working at the track all weekend but I'll be able to help. Could be a bent lower control arm or an alignment shop mistake (or both).
- Andrew
KevBRZ (08-29-2019)
Old 09-03-2019, 01:06 PM   #172
CatDaddysBBQ
Drives: '13 FR-S
I had a weird summer (well up to this point) where I really didn't get a chance to drive the car more than street use as much as usual. SO, I JUST did my first autocross last weekend after having the SS1 coilovers on since april or so.
They were great! I think better for autoX than track use if that makes sense. Track use was 'good' but for autoX I coudln't ask for more.
Started with settings dead center (I knew i wouldn't want them ANY softer than that). Car was fine, but a bit wallowy. Put them up a few clicks all around (probably around 15/19) and it was better. Then put them to full stiff up front and while they were still good, it was more nervous over ripples in pavement so backed them back off to 16/19 and left it the rest of the day. Rears were a bit softer around 14-5 out of 19.
Car was planted, had traction ALL the time and was well behaved and predictable. Won my class and was 3 seconds faster than my friend who's FRS is similar to my OLD setup before I bought these coilovers. We used to be MUCH closer comparatively, so that's my imprecise but pretty reliable meter that these have vastly improved my autoX results.
CatDaddysBBQ is offline   Reply With Quote
The Following 4 Users Say Thank You to CatDaddysBBQ For This Useful Post:
Aluma007 (10-02-2019), jflogerzi (10-16-2019), KevBRZ (09-07-2019), Racecomp Engineering (09-03-2019)
Old 10-02-2019, 11:06 PM   #173
KevBRZ
Drives: 15BRZ
re: SS1 Autox
Ok, i got my first event on the SS1s, since i am rusty it did take me 6 runs and 3 fun runs to get the car down on times and i felt like my last run wasn't leaving a whole lot left on the table. With the Perrin 22mb set on soft up front, and -3 ish camber up front and -2.2 in the rear with slight toe in, i felt like the car was fairly neutral with a slight bit of understeer at the limits, i ended up having to stiffen the fronts to about 80% stiff and rears around 50-60% with 32 psi up front and 30 rear, i was really happy with how the car handled, i just need to learn how to drive it better at this point! I am very happy with daily driving on these, i actually feel like they are better than the stock set up, and seem so far that they are gonna work well for auto x.
The Following 4 Users Say Thank You to KevBRZ For This Useful Post:
Aluma007 (10-02-2019), cueball89 (10-03-2019), jflogerzi (10-16-2019), Racecomp Engineering (10-03-2019)
Old 12-06-2019, 08:16 PM   #174
Infinity
Drives: 2016 Scion FR-S
Just got my set of SS1s. After reading this thread it looks like factory camber bolts are the way to go. How many should I get? Are they needed front and rear?
Infinity is offline   Reply With Quote
Old 12-06-2019, 09:58 PM   #175
Decep
Drives: 2013 FR-S Series 10
You get 2, one for each front corner.
As for the rear, you might want rear lower control arms to dial in the camber. My car had almost a degree of cross camber which isn't ideal. Fairly common on this platform due to sloppy factory tolerances
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following 2 Users Say Thank You to Decep For This Useful Post:
Infinity (12-06-2019), Racecomp Engineering (12-07-2019)
Old 12-07-2019, 11:39 AM   #176
Decep covered it well. Two bolts total for the front (1 each side). Rear adjustable LCAs helpful to dial in the rear. I can set you up if you pm me. The part numbers for the front bolts I think are in this thread or we have some in the shop.
- Andrew
Old 12-07-2019, 03:39 PM   #177
KevBRZ
Drives: 15BRZ
You are gonna love the SS1s, really happy with mine and Racecomp engineering has been great for info and help!! and i recommend rear camber arms also to get a more even setup unless u get lucky out of the box with the lowering.
The Following User Says Thank You to KevBRZ For This Useful Post:
Old 12-13-2019, 09:33 PM   #178
Infinity
We recommend using only the OEM bolts (including the OEM "crash" bolt) in the slotted upper hole. Don't use an eccentric in the upper hole.
- Andrew
Does this mean its fine to use an eccentric in the lower hole?
Old 12-14-2019, 06:08 PM   #179
Yes it's fine.
- Andrew
Old 04-22-2020, 02:01 PM   #180
TeamBadger
Drives: 2016 Brz Limited
How much leeway does the valving allow for when it comes to adjusting spring rates? Could the consumer get away with something like a 50lb/in increase ?
TeamBadger is offline   Reply With Quote
Old 04-22-2020, 02:33 PM   #181
Yes absolutely. I've gone as soft as 4 kg/mm front and rear (224 lbs/in) and as stiff as 7 kg/mm (392 lbs/in) front and rear on my own SS1s.
- Andrew
Old 04-22-2020, 02:59 PM   #182
TeamBadger
Awesome, I'll be picking up a set for my daily driver/ STX BRZ.
The Following User Says Thank You to TeamBadger For This Useful Post:
Racecomp Engineering (04-22-2020)
SuperStreet ToyoTires Meals N' Wheels Meet at Edgie's in Milpitas - photos & videos PMok Northern California 5 02-09-2015 06:26 AM
-0.5 for RaceComp Engineering wrxneffect User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-04-2014 05:21 PM
Mackin FR-S Superstreet Cover Evasive Tuned! Out Now!!! Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 18 12-07-2013 11:20 PM
Racecomp Engineering industrial User/Vendor/Sponsor Reviews, Feedback, Comments 0 05-02-2013 05:17 PM
Racecomp website down? Mikepage Off-Topic Lounge [WARNING: NO POLITICS] 8 04-22-2013 04:12 PM
