Drives: 2015 Scion FRS
Automatic shifting yay or nay?
Is it damaging to an automatic FRS to be consistently in "manual mode" ? I use it for my commute every day because it's a lot of fun but recently thought about potential damage. Anyone have insight? I spend about 10-15 minutes of my commute on really fun winding roads.
Purchased 12/2019 2015 FRS-Automatic 13,500 odometer Stock 25 mile commute round trip Sent from my PH-1 using Tapatalk |
#2 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
why would manual mode change anything? it is still a computer shifting..the only potential damage I could see would be going into manual mode straight away and banging the limiter before your engine has a chance to warm up but keep in mind it is no different than keeping it in automatic mode and going full throttle, the computer will keep it in lower gear and go to redline.. so in short, after it is up to operating temp, the mode should not make a single difference when you have an automatic trans and you ain't doing any damage to the engine..more wear perhaps, but if you aren't putting extra wear then you're doin it wrong.
| The Following 5 Users Say Thank You to HKz For This Useful Post: | humfrz (04-22-2020), soundman98 (04-22-2020), Spuds (04-22-2020), Tcoat (04-22-2020), why? (04-23-2020) |
#3 |
pessimistic skeptic
There is absolutely no problem with manual shifting. I always drive in manual mode.
| The Following User Says Thank You to mrg666 For This Useful Post: | why? (04-23-2020) |
#4 |
Drives: 2017 toyota 86
Potentially more damaging not using it
#5 |
What HKz said.
#6 |
Auto mode likes to lug the engine in certain scenarios, manually downshifting in anticipation when you know it’s going to lug will be better for your engine, if its a scenario that lasts long enough to where it will auto up shift again after manually downshifting and lug the engine putting it into manual mode for the duration of the scenario to hold the gear will be better for the engine.
#7 |
The Dictater
Drives: '13 Red Scion FRS
The car will be fine, you will be better.
With practice, you might be able to get a real transmission if your own one day! (That was a joke, the classic AT vs MT arguments entertain me). |
| The Following User Says Thank You to Spuds For This Useful Post: | soundman98 (04-22-2020) |
#8 | |
pessimistic skeptic
#9 |
Pavement Grey
yeahhh........no
Its designed to shift gears....its not gonna break. And even still the computer will prevent you from doing something stupid like downshift to the wrong gear and overrev the engine |
| The Following User Says Thank You to Sasquachulator For This Useful Post: | guitarman (04-22-2020) |
#10 | |
Drives: 2016 Scion FR-S
The other problem I sometimes seem to have is when I switch back and forth and "forget" that I am in manual mode-until I'm redlining in 1st and looking like an idiot. Maybe I should just keep it Manual-mode all the time. Maybe I'm just going senile....hard to say
| The Following User Says Thank You to guitarman For This Useful Post: | Dadhawk (04-23-2020) |
#11 |
Thank you all for the responses. My mind is put at ease. Time to go have some fun.
#12 |
I disagree with most of the above comments because, in fact, we don't have enough information to determine whether or not there are any relevant functional differences between the two modes.
But it doesn't really matter because, by now, we would likely have seen failures that could be attributed to using one mode over the other. That was how the design flaw in the first gen five-speed hondamatic transmission was discovered. The manual mode was more aggressive in its timing and didn't wait sufficiently for rev match. The root cause was actually insufficient cooling of the - iirc - third gear brake band but they went with a firmware patch at first.
#13 |
And just like that... paranoia
#14 | |
The Dictater
But also bullshit.
| The Following 4 Users Say Thank You to Spuds For This Useful Post: |
| Shifting Problem (Automatic) | FRSure | Issues | Warranty | Recalls / TSB | 61 | 05-09-2021 08:38 PM |
| Automatic Supercharged Gt86 Shifting Issue | Nawar | Forced Induction | 9 | 02-10-2019 03:25 AM |
| Automatic BRZ down shifting | eric2523 | Engine, Exhaust, Transmission | 12 | 08-20-2015 07:30 AM |
| Automatic Transmission Kick/Choke when shifting gears | Tech Gremlin | Engine, Exhaust, Transmission | 13 | 06-16-2015 02:54 AM |
| Paddle shifting automatic downshift | FR-YES | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-06-2012 10:18 AM |
