Old 04-07-2020, 12:16 AM   #1
ftpwny
Drives: 2013 Subaru BRZ
Flash back to stock for valve spring recall?
I'm currently running the catted FT86SF header along with an OFT tune and thinking about doing the valve spring recall so I can avoid paying for labor to change the spark plugs and to reseal a leaky timing chain cover.
Do I need to flash back to stock before bringing it in?
ftpwny is offline   Reply With Quote
Old 04-07-2020, 02:04 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
Yes. Dealers aren't very happy if their scan tools don't work
Old 04-07-2020, 02:16 AM   #3
Lantanafrs2
Drives: 2013 frs red
Well if you're not running ecutek you're obviously not interested in making a 200hp car run like a 200hp car. I wouldn't be surprised if the dealer scolds you for using a shitty oft tune. Lol jk
Lantanafrs2 is offline   Reply With Quote
Old 04-07-2020, 02:50 AM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
FYI they will still charge you the same for any job that is not related to the recall. Just a heads up. It may or may not be lower. Not sure how much of penis your dealership is.
Old 04-07-2020, 09:42 AM   #5
gravitylover
I'm running a stage 1 tune, have been for 2 years, and didn't flash to stock before I brought it in. Not only was it NOT a problem the tech said he dialed in one or two things that he felt the parameters were off. He's pretty hip to these things though which helped, I wouldn't count on it being that way at all dealerships but I don't htink you need to worry about it.
Valve float after valve spring recall mswbrz Issues | Warranty | Recalls / TSB 5 11-22-2019 08:03 PM
Not doing the Valve Spring Recall? arnie0000 Issues | Warranty | Recalls / TSB 30 08-06-2019 06:24 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 04:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
