#29 | |
The dampers can be serviced by Ohlins service centres fairly easily (I’m told)... |
#30 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Like the Hot Lava / Creamsicle bar colorway.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | grumpysnapper (03-30-2020) |
#31 | |
Drives: FR-S Whiteout
Well done, mate! ![]() With similar goals, I've taken a different approach due to obvious budget constraints. Thankfully I'm not too uncomfortable with taking things apart and half decent with a wrench and micrometer. One of the most interesting piston design from ohlins is the high frequency piston. The design is pretty ingenious how damping pressure can go limp only at high frequencies or when the shaft is changing direction of motion. It's produces "negative-stiction". But the cost of just the pistons, you can probably get a pretty decent set of off the shelf pre-built complete coilover damper kit for similar price. That only makes me wonder about them more. lol I can respect that they want to keep he information confidential, but my guess is that they utilized this high frequency piston inside your shocks.
Intent > Content
cowardice is the mother of cruelty. |
| The Following User Says Thank You to solidONE For This Useful Post: | grumpysnapper (03-30-2020) |
#32 |
Drives: Subaru BRZ
Given crazy high Australian import duties on car parts, folks in the US could get these Ohlins for maybe $10k-12k?
#33 |
Drives: 2014 GT86
No. While cost very probably similar to one you quoted, but not due reason of cheaper importing, rather price itself being such, if there is no extra R&D cost, that grumpysnapper already paid for.
IIRC most common rally coilover sets cost somewhere in 7-15K range, be it built from Ohlins or Reiger or whatever parts bin. Actually don't most top vendors built-to-order custom sets cost at least 7K? What would put me off most though, are very short maintenance/rehaul intervals that i've heard on real rally shocks. Like every 1K miles or after each heavy race and such. Though of course if one won't actually abuse it to rally-ish multi meter jumps, cutting across ditch, going at 150-200kmh over rocky road, that should keep wear less .. still probably expected mileage less then that of OE like shocks. Yes, rally suspension allows to do wonders and seems magic like .. but not sure it's that good for long mileage daily driving role (even price aside). With no budget limits for top-notch suspension for daily driving (or "normal" track) i'd rather think something like CSG Penskes (which also each is custom made/valved/sprung IIRC). |
| The Following User Says Thank You to churchx For This Useful Post: | soundman98 (03-29-2020) |
#34 |
ProCrastinationConsultant
that's a good point. i'm curious to hear about what the road-going service intervals would be
#35 | |
The reality of stress and wear in even hard road use has almost no real equivalence with high end competition rallying... where a rebuild is advised at around 350km for an extremely rough dirt rally up to about 1000km on ok tarmac. It’s also good to bare in mind that these dampers already have a much higher quality of sealing against internal damage than is ‘ normal’. As Leo explained to me, they should effectively last a lifetime... but it’s maintaining them at their %100 peak which is what takes commitment.... which is relevant to any discussion about dampers cheap or expensive, custom or off the shelf. I suspect most dampers are actually way less than ‘fresh’ after 2 years. We don’t have salt on our roads, so I don’t know of the normal effects of salt on any dampers. |
| The Following User Says Thank You to grumpysnapper For This Useful Post: | soundman98 (03-30-2020) |
#36 |
Drives: 2014 GT86
I'm just passing what i've been told in one local shop that services several local rallyist (and rallycross) cars. Of course i was interested to chat about the goodies like ohlins rally dampers or APR radical brakes and other car porn that i saw on those installed
.Otherwise, if anything, rally dampers should be of much stronger construction. Heck, one can see it even in your pics vs R&T ones, much thicker bodies, attachment points of heavy welded plates with extra ribs and such. If Leo told that they will last for you, then i guess indeed that those short servicing intervals that surprised me, attributes to real hardcore competition rallying, and they should last well if not abused to THAT extent. Then again, rally race tires also are worth only for one race too. Such driving & wear differs slightly from "normal"
| The Following User Says Thank You to churchx For This Useful Post: | grumpysnapper (03-30-2020) |
#37 | |
The other thing to really keep in mind is that these dampers are only a Group N type standard (but without the full travel they should have!).... the proper WRC grades of damper suspension would make my dampers look and feel like toys. Group N had/has a semblance of road car reality... WRC has almost zero. Real top level WRC suspension can run to 40K per corner (!!)...and replaced a couple of times per day... Daily use of WRC suspension would be a challenge, to say the least. I cant begin to image the abilities of legit WRC suspension.... |
| The Following 2 Users Say Thank You to grumpysnapper For This Useful Post: | solidONE (03-30-2020), soundman98 (03-30-2020) |
#38 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Damn - now I'll have to lysol my keyboard and monitor again.
![]() My hope is the Xida option the folks at 949 are marinating will get close to this. I can't really afford those, much less these, but you have channeled my exact thinking in your goals and execution. A little more travel, precision wheel control, good ride quality. These are this real world driver's holy trinity.
Slow is smooth, and smooth is fast
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | grumpysnapper (03-30-2020) |
#39 |
Rears fitted, showing position of canister, and clearances.
| The Following 6 Users Say Thank You to grumpysnapper For This Useful Post: | daskaman (03-31-2020), Racecomp Engineering (03-31-2020), scottman (03-31-2020), solidONE (03-31-2020), soundman98 (03-31-2020), surfwaxsmitty (04-06-2020) |
#40 |
Fronts complete and fitted.
| The Following 6 Users Say Thank You to grumpysnapper For This Useful Post: | asdf (04-01-2020), Code Monkey (03-31-2020), daskaman (03-31-2020), Racecomp Engineering (03-31-2020), scottman (03-31-2020), surfwaxsmitty (04-06-2020) |
#41 |
Drives: 13 mt fr-s
My pants got tighter
| The Following 2 Users Say Thank You to scottman For This Useful Post: | grumpysnapper (03-31-2020), soundman98 (03-31-2020) |
#42 |
I'm trying very hard not to ask about the specs...
I would see if I can do some kind of clear heat shrink or wrap on the canisters and shock socks, at least for the front strut. Gotta protect that beautiful finish.
Intent > Content
| The Following User Says Thank You to solidONE For This Useful Post: | grumpysnapper (04-02-2020) |
| Ohlins TTX/TPX Group N rally adapted for BRZ | grumpysnapper | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-27-2020 10:09 AM |
| JRP-Suspenson Group buy! KW,Ohlins,HSD,Cusco,SPC-NOW FREE SHIPPING! | Stav | Canada Classifieds | 33 | 05-16-2015 11:51 AM |
| *GROUP BUY: JUST IN RALLY ARMOR MUDFLAPS!* | genometuning | Groupbuys | 585 | 01-15-2015 07:08 PM |
| Ohlins group buy | aruxe | CANADA | 1 | 05-22-2014 04:36 PM |
| Group B rally awesomeness | MtnDrvr86 | Other Vehicles & General Automotive Discussions | 0 | 11-08-2011 06:05 PM |
