Old 03-26-2020, 08:20 PM   #1
vladniko86
vladniko86's Avatar
Drives: FRS
Need insight on leak and TOB issues
Well I finally dropped my trans (67k miles) to figure out my squeak. It had gone away previously but came back. Anyways, few questions. Any ideas why it seems like oil is leaking from my left head? My oil level is staying pretty constant thru thousands of miles, maybe it's just old oil? Kind of doubt it.
Also, my input shaft cover was pretty marred up, so I have a new one of those coming aswell as the revised TOB. Should I get a new pressure plate and clutch? Not planning on keeping this setup very long (maybe another year at max), but just wondering if it'll be fine.
Lastly, in case anyone wanted to see an old vs new, you can hear the bearings inside of the old one and it spins alot. New one is nice and tight.
vladniko86 is offline   Reply With Quote
The Following User Says Thank You to vladniko86 For This Useful Post:
humfrz (03-27-2020)
Old 03-27-2020, 02:33 AM   #2
Oh, if you're not planning on keeping that car very long and the clutch isn't slipping, I'd pass on a new clutch and pressure plate.
As far as that oil residue, I wouldn't worry about it, unless it starts dripping.
Nope, ol humfrz don't worry about too much anymore.
Old 03-29-2020, 12:12 AM   #3
vladniko86
vladniko86's Avatar
Drives: FRS
Sounds about right haha thanks humfrz
humfrz (03-29-2020)
Old 03-29-2020, 07:47 AM   #4
Halo_2
Drives: 2014 MY15 86 GTS
Given the financial climate if I had to choose between one that had it clutch done or not.......definitely choosing the one with new TOB, clutch etc.
Halo_2 is offline   Reply With Quote
Old 03-29-2020, 10:38 AM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
i'm of the opinion that if it's already pulled apart, and it's not an easy task, better to just do it now than have to re-deal with it later.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
gravitylover (03-29-2020), JD001 (03-29-2020)
Old 03-29-2020, 10:59 AM   #6
HaXx
Drives: jrsc_brz
as far as i know, pressure plates dont "go bad", but clutch plates do get worn out. im sure the flywheel is fine, so id buy a slightly used / oem clutch plate on the cheap to pop in. keep the existing pressure plate.
HaXx is offline   Reply With Quote
Old 03-29-2020, 05:11 PM   #7
ls1ac
ls1ac's Avatar
Did the car ever go swimming? Looks like dirt on the input shaft cover, and rust coloring around the pressure plate.
Flywheel and pressure plate should clean up fine, find a clutch somewhere and should be good to go.
Old 03-30-2020, 12:21 AM   #8
vladniko86
vladniko86's Avatar
Drives: FRS
no, but it came from someone in detroit michigan who didnt care about it, and now lives in NY. so probably the salt
Got some insight today... Yal BRZ First-Gen (2012+) — General Topics 12 09-28-2016 07:14 PM
Need insight on a banned member Yamaha_R6 Southern California 4 11-30-2014 05:04 AM
Lexus IS300--Any insight? Ocean-Grown 86 Other Vehicles & General Automotive Discussions 4 09-10-2014 12:11 PM
RCE vs Swift: Any Insight? boredom.is.me Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 03-24-2013 09:45 PM
Insight on my first M/T Car. Veloist Other Vehicles & General Automotive Discussions 24 08-31-2012 12:58 PM
