Old 03-19-2020, 12:31 PM   #15
It's not an 85' Civic.
FIFY
NoHaveMSG (03-19-2020)
Old 03-19-2020, 04:42 PM   #16
coconutboy
coconutboy's Avatar
Drives: 2015 White BRZ Aozora
Update:
There was black soot on the gaskets.
My guy said the gaskets aren't that good even though they came with the header.
Hes working on the car now.
Will give update later
Sent from my SM-G950W using Tapatalk
coconutboy is offline   Reply With Quote
Old 03-19-2020, 05:16 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by coconutboy View Post
Update:
Check the flanges for flatness. Flanges can be warped, or can warp when hot.
Old 03-19-2020, 06:46 PM   #18
coconutboy
coconutboy's Avatar
Update:
No more smell unless coming to a stop or reversing! (This is expected)
Thanks to everyone that commented.
Mechanic put some gasket sealant on the headers to block, headers to overpipe and overpipe to fp.
Seemed to have worked.
He also plugged the sound tube with silicone.
Looks like this problem is solved.
Thanks 86 fam
The Following User Says Thank You to coconutboy For This Useful Post:
bcj (03-20-2020)
Old 03-22-2020, 11:20 PM   #19
coconutboy
coconutboy's Avatar
Update...
Smell vaugely came back into cabin.
If it was originally 7/10 on how strong the smell was, it is now 3/10.
I'm starting to think the A/C MAY have something to do with this.
I also notice the I smell the fumes while driving with my windows down.
Even at 60 + km/h.
Pretty frustrated and annoyed.
Old 03-22-2020, 11:45 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Update...
Even at 60 + km/h.
Check the flanges for flatness. Sounds like putting ultra copper on the gaskets didn't work.
Old 03-22-2020, 11:54 PM   #21
coconutboy
coconutboy's Avatar
I honestly might switch to my oem fp.
I have this stupid fluttering sound other people have when they have the same header as me
They said stock fp gets rid of it.
It should get rid of smell too.
Just no snap crackle and pops
Old 03-23-2020, 09:14 AM   #22
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
https://www.amazon.com/Remflex-6005-.../dp/B00B2HMF7G
https://www.amazon.com/Remflex-RF16-.../dp/B000TLL7JS
I know the 6005 is correct but double check the 16-000 just to make sure it'll fit (it should). I have a cheap OP with warped flanges and the remflex gaskets sealed it up. Don't overtorque, it only asks for 20 ft. lbs.
MCTeeJ is offline   Reply With Quote
The Following User Says Thank You to MCTeeJ For This Useful Post:
NoHaveMSG (03-23-2020)
Old 03-23-2020, 11:07 AM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Remflex gaskets are excellent. Never bothered to look to see if they made any that fit our cars.
MCTeeJ (03-23-2020)
Old 03-23-2020, 11:36 AM   #24
Need to stop trying to fix the symptoms and fix the problem. Fix it right stop throwing bandaids at it.
Old 03-29-2020, 01:31 AM   #25
coconutboy
coconutboy's Avatar
Update: fumes came back temporarily, but when I changed my cabin filter (it was originally filllltthhhyyy) all smell gone. No fumes no nothing anymore. Wish I didnt sell my fp (((
Old 05-03-2020, 01:19 AM   #26
coconutboy
coconutboy's Avatar
Update. After going back to stock I had no fume smell. Bought the invidia high flow fp and smell is back ONLY when windows are rolled down. Happens when I'm on highway too. Idk how it makes any sense. When the motor is being pushed it gets stronger, but not clue how it gets into the cabin at speeds higher than 40 kmh
Old 05-05-2020, 12:41 PM   #27
ML
ML's Avatar
Drives: 13 White MT FR-S
I have this issue as well. Completely striped interior, no HVAC, catless header/fp. I felt like I almost had CO poisoning after driving with the windows down for an hour straight. About to start looking for leaks this week, and we could compare notes.
Old 05-05-2020, 12:50 PM   #28
ML
ML's Avatar
also, atleast for me, this could be it:
when driving, exhaust fumes get trapped in a turbulance behind the car. with open windows, you get a low pressure condition inside the car = exhaust fumes get sucked inside through the "leaking" trunk gasket.
Chirping in Cabin DaBoBo21 Issues | Warranty | Recalls / TSB 33 11-14-2019 04:31 AM
Exhaust Fumes/Smell Question/Opinions Mr.Impreza Engine, Exhaust, Transmission 5 05-19-2016 10:57 AM
New Turbo Install = Car Fumes?? xuimod Forced Induction 49 04-28-2015 04:21 PM
Fumes coming out from the vent? Moss Scion FR-S / Toyota 86 GT86 General Forum 22 10-11-2013 01:31 PM
Cabin Dome/Map LED Anthonytpt Cosmetic Modification (Interior/Exterior/Lighting) 3 01-30-2013 08:31 PM
