| Engine Swaps Discussion of engine swaps. |
Drives: brz
K24 swap pics, It runs off the BRZ brain!!! Video on page 4&7. VVT enabled now!
This thread has been Censored
| The Following 3 Users Say Thank You to solidsnake11 For This Useful Post: |
#2 |
Rust bucket enthusiast
I'm super excited to see this!
| The Following User Says Thank You to DarkPira7e For This Useful Post: | solidsnake11 (02-23-2020) |
#3 |
Drives: 13 White MT FR-S
Finally got tired of the fa20 piling issues?
| The Following User Says Thank You to ML For This Useful Post: | solidsnake11 (02-23-2020) |
#4 |
Drives: Q5 + BRZ + M796
So you didn't prepare the surfaces by removing paint? Did you remove the oil at least? Did you use a shielding gas on the inside of the pan? Considering the pan isn't structural and doesn't see high forces or pressures, you might be fine. Pics of the inside of the pan?
#5 |
I would just be concerned with porosity on an oil container, but like I said, there is minimal risk of weld fracture from load, pressure, heat cycles, etc, so I’m sure your pressure test will work out.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | solidsnake11 (02-23-2020) |
#6 |
Drives: '14 fr-s \\ 6mt \\ white
| The Following User Says Thank You to Grawlix For This Useful Post: | solidsnake11 (02-23-2020) |
#7 | |
That Guy
Drives: 2013 asphalt FRS MT
| The Following User Says Thank You to Calum For This Useful Post: | solidsnake11 (02-19-2020) |
#8 |
Drives: BRZ, WRX
Great work!
| The Following User Says Thank You to DIY For This Useful Post: | solidsnake11 (02-19-2020) |
#9 |
#10 |
So will you pass inspection if you get it working with the stock ecu? Or are you just track only these days? NC sucks for engine swaps on newer cars.
| The Following User Says Thank You to ML For This Useful Post: | solidsnake11 (02-19-2020) |
#11 |
You're a mad man. Keep up the good work! FOR SCIENCE!
| The Following 2 Users Say Thank You to fika84 For This Useful Post: | sato (04-14-2020), solidsnake11 (02-19-2020) |
#12 |
| The Following User Says Thank You to Grawlix For This Useful Post: | solidsnake11 (02-19-2020) |
#13 | |
Giving up VTEC? I can't imagine the stock BRZ ECU can handle swapping cam profiles.
| The Following User Says Thank You to wparsons For This Useful Post: | solidsnake11 (02-19-2020) |
#14 |
| The Following User Says Thank You to Ashikabi For This Useful Post: | solidsnake11 (02-19-2020) |
| Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 856 | 06-14-2018 03:53 PM |
| BRZ headlight swap to Monogram Series *UPDATE:10/12/14 w/ Pics* | JDis3 | Cosmetic Modification (Interior/Exterior/Lighting) | 31 | 04-12-2015 06:31 PM |
| ADVAN GT 18" Concave Face ** Actual Wheels Pics and Weight Pics | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 11-21-2014 12:16 AM |
| Release Series 1.0 FR-S & FT-1 Pics from NYIAS (Warning: iPhone Pics) | TM | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 26 | 04-30-2014 04:31 PM |
| More stock pics. My Raven FR-S with graffitti background. Sick Pics | Hardrock4445 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 11-12-2012 12:29 AM |
