Old 01-26-2020, 07:22 AM   #1
Howaitoguru
Howaitoguru's Avatar
Drives: 2016 Subaru BRZ
Recaro heat retrofit.
Does anyone know how difficult it would be to take the heaters out of the OEM BRZ seats and put them into some Recaro Buckets or SP3’s? I assume the wiring harness would stay intact so I figure it should be fairly easy but I wanted to see if anyone did this.
Howaitoguru is offline   Reply With Quote
Old 01-26-2020, 05:56 PM   #2
p1l0t
p1l0t's Avatar
You're going to literally set your own ass on fire if you mess this up.
The Following 2 Users Say Thank You to p1l0t For This Useful Post:
Howaitoguru (01-26-2020), SkyeHack (01-26-2020)
Old 01-26-2020, 06:01 PM   #3
Howaitoguru
Lmao. I’m an electrician so I’m not worried about an electrical fire. I’m more so concerned with getting it just right so that it’s not too hot.
The Following User Says Thank You to Howaitoguru For This Useful Post:
p1l0t (01-26-2020)
Old 01-26-2020, 07:38 PM   #4
redhalo
Drives: MY20 Hakone Toyota 86
I mean, you being an electrician makes you more qualified to tell us how difficult this is, right? Sounds like your the one in the best position to do the leg work for the community.
redhalo is offline   Reply With Quote
Old 01-27-2020, 12:10 AM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
do you know what a hog ring is, and why i never want to deal with them?
Howaitoguru (01-27-2020)
Old 01-27-2020, 10:49 AM   #6
TRAKRAVN
Drives: 2015 Scion FRS - Raven
That make special pliers for them so it’s not too bad.
I would just get an after market electric heater/cooler and put the pad underneath the Recaro fabric above the foam. Then use the new switches or see if they are compatible with the OEM switches.
https://katzkin.com/degreez/
I’m sure they can make something to fit the recaro.
TRAKRAVN is offline   Reply With Quote
The Following User Says Thank You to TRAKRAVN For This Useful Post:
Old 01-27-2020, 11:04 AM   #7
Howaitoguru
Probably some insulated coil that puts off a lot of heat. But I’ve never heard of one
Old 01-27-2020, 09:29 PM   #8
soundman98
soundman98's Avatar
you're in trouble.
get a quote from a local upholstery shop.
sharpsicle (01-28-2020)
Old 01-27-2020, 09:31 PM   #9
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Hog rings are the fastners used that hold the seat cover too the seats.
Id start by looking at oem recaros from the wrx ot mr evo x that are already made with heating elements in them. Then, it is just a matter of wiring them up to the oem brz's switches.
FS (1) Set of Recaro Sliders Desai_N Interior Parts (Incl. Lighting) 0 08-17-2019 11:03 AM
FS: Recaro spg and sr III DavidBob Interior Parts (Incl. Lighting) 3 06-29-2016 02:38 PM
WTB: Recaro SPG whathedunk Want-To-Buy Requests 0 03-14-2014 07:37 PM
List of plug & play Recaro seats compatible w/heat function? [Cyanide] Cosmetic Modification (Interior/Exterior/Lighting) 0 12-11-2012 12:50 AM
Recaro seats? bc_106 Scion FR-S / Toyota 86 GT86 General Forum 35 09-20-2011 07:50 PM
