Old 12-13-2019, 10:55 PM   #239
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Originally Posted by timurrrr View Post
During my recent track day at Laguna Seca I've noticed I'm bottoming out the suspension at the exit curb in T6 when driving with a coach. The coach says it's probably the right rear. It wasn't bottoming out when driving solo later and taking the same line/speed.
I think I also occasionally bottom out the fronts when going over rough seams in pavement on highways.
I presume adding a bit of preload, and then turning the bottom bracket by the same amount should give me the dampers a bit of extra room to with with under compression? Please advise. Note that my setup is a tad higher than the recommended height, so I don't think I'll be bottoming out the body if I do so
It's pretty difficult to "bottom out" this system due to its inherent design. Looking forward to watch the video and also find out a few other details including damper settings, alignment, tire pressure, and cornering load. Thank you!
CounterSpace Garage is offline   Reply With Quote
Old 01-02-2020, 10:16 PM   #240
AngelGT86Racer
AngelGT86Racer's Avatar
Drives: 2013 FR-S, 2007 Acura TL 5AT
I ordered a set for myself right around Christmas. The CSG site says this next batch is due for March 2019. I'm guessing that's meant to say March 2020?
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build
YouTube: Angel Christov
AngelGT86Racer is offline   Reply With Quote
Old 01-17-2020, 12:51 PM   #241
CounterSpace Garage
It's definitely 2020 and brain farted when we updated the backorder ETA. Our apologies!
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
AngelGT86Racer (01-17-2020)
Old 01-17-2020, 01:20 PM   #242
Petah78
Drives: 2022 BRZ sport-tech
Are these rebuildable? I hear Tein Flex is not rebuildable. If they are serviceable, how much is the service?
Thanks.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 01-17-2020, 01:25 PM   #243
churchx
churchx's Avatar
Drives: 2014 GT86
Flex A are rebuildable (unlike Flex Z, that should be similar to A, minus rebuildability and minus hydraulic bumpstops), but as these are not off the shelve A-s, i guess you need to work with CSG, if you want to rebuild as in to restore like new or if you want to revalve, based on their current, CSG customized, valving.
Old 01-17-2020, 01:34 PM   #244
CounterSpace Garage
Thanks.
Yes. These can be serviced. Rates vary based on condition of the system and we've seen some rebuilds (standard FLA serviced to CSG Spec or standard SRC serviced to CSG Spec) that looked horrible (a few had accidents and decided to get their systems serviced, etc.). Hence why it's difficult to provide a general cost.
You are correct. Valving is specialized to our requirements. CSG FLA is serviced in TEIN USA. Please work with CSG to get the system serviced. Depending on backlog of work and how much servicing is required, we've seen systems turnaround in a few days and some required a month (because of how many parts required replacement). Average has been around 1-2 weeks and we've only had to send 1 kit in for servicing in the last 2-3 years.
Old 01-24-2020, 12:43 AM   #245
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
What's the preset/recommended ride height drop on these?
Ryan GT86 is offline   Reply With Quote
Old 01-24-2020, 04:26 PM   #246
CSG Mike
CSG Mike's Avatar
All of the recommended settings and measurements are in the manual; the manual included is specific to the CSG Flex A.
You'll be at about a -1.4" drop.
Old 01-25-2020, 03:56 AM   #247
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Here it is!
with just T6s from the session when I heard the issue.
Interestingly, I can't hear anything unusual on the video. Will keep an eye on that next time I'm at Laguna... Not unlikely that it will be during one of the 86DRIVE Challenge events
I'm now wondering if perhaps the sound was happening in some other corner, will revisit the whole footage some day.
Damper settings: 5 clicks from full stiff everywhere
Alignment: maxed in the front (-3.1), stock in the rear (-1.7ish in the right)
Tire pressure: ~32 psi hot if I remember correctly
Cornering load: please explain how can I get it? The car was corner balanced after installing coilovers.
Old 01-26-2020, 10:01 PM   #248
Ryan GT86
Ryan GT86's Avatar
If I'm just going by a 1.25 inch drop in the front with OEM sways and LCAs for the front. Will I need shorter endlinks?
EDIT: Should I get endlinks for the front and rear? If so, which ones? I'm getting conflicting information.
Old 01-30-2020, 08:20 PM   #249
CounterSpace Garage
Here it is!
Didn't hear the noise in this clip. Can you describe it? Check all the bolts, collars, and such to make sure everything is tight. Measure everything again and follow the manual.
Old 01-30-2020, 08:21 PM   #250
CounterSpace Garage
Believe it or not, most CSG FLA users use OEM endlinks without any problems. A set of rear LCAs is beneficial if you're looking to have some specific camber settings dialed in.
Old 01-30-2020, 08:56 PM   #251
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Yeah, I'm surprised there's nothing in the video.
If I remember correctly, the sound was similar to what I get when driving over a rough lateral ridge/pothole on a highway, i.e. just a hard boom.
Checked, everything's fine.
Speaking of endlinks, is that expected that I'm rubbing a hole in the frame with my end link at full lock? This is camber maxed out on the top hats, measured at -3.1.
Any workarounds other than dialing the camber off?
Old 01-30-2020, 10:15 PM   #252
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Lower profile end link, check out racer x.
Could also add camber bolts and dial out the camber plates, but might as well get the links and more camber as well.
ineedyourdiddly
timurrrr (02-11-2020)
WTB Tein Flex Z HachiRo Want-To-Buy Requests 1 09-19-2016 02:13 PM
tein flex z mclovin85 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-14-2016 07:27 PM
TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day CounterSpace Garage Groupbuys 47 02-18-2016 01:33 AM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 10:33 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 02:10 PM
