CSG Mike, gramicci101, grant86, GrimmSpeed, JDLAutoDesign, JRitt, KCMachine, King Tut, MillersOilsUS, PERRIN, phastafrican, Racecomp Engineering, Raceseng, Roadcone, Sportsguy83, UltramarineLuck, VerusEric, Wonderbar, Xero-Limit
Old 11-30-2019, 04:30 PM   #2129
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I like the red one
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
ATL BRZ (11-30-2019)
Old 11-30-2019, 04:52 PM   #2130
Milhouse86
Noob
Milhouse86's Avatar
Drives: 13' FRS, 13' F150, 17' A4, 69' 442
Another vote for red. Damn that's a nice car! Keep it up!
And Congratulations on the new baby! This is a super fun time of year for newborns. Enjoy
Sent from my Pixel 2 XL using Tapatalk
-2013 FRS/Black (Motor Blown/Under Construction)
http://www.ft86club.com/forums/showthread.php?t=135599
-1979 Trans AM/Black (Sold) -1969 Olds 442/Orange with white racing stripes - 2017 Audi A4/Black
Milhouse86 is offline   Reply With Quote
The Following User Says Thank You to Milhouse86 For This Useful Post:
Old 12-02-2019, 09:33 PM   #2131
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by TeutonicShift89 View Post
I think one criticism I've heard of the morimoto lights is that the LED daytime running strip is considerably dimmer and less visible in the day time than the factory boomerangs.
Any word on this?
Also, I thought HID had superior output than LED: https://www.ft86club.com/forums/show...&postcount=172
I like the 5yr warranty offered by the Retrofit Source. Definitely be the store I would get them from.
The HIDs will have more focus for down road visibility and more of a hot spot up close because of it. HIDs can still be blinding from far away if someone lacks a projector or doesn’t aim it correctly. This is evidence enough that HIDs generally are brighter.
LED should have a more saturated/brighter look for up close, but it fails to match HIDs for down road illumination. They tend to be more obnoxious to oncoming drivers, but that is mostly up close because they intensity dissipates quickly.
The ideal situation would be HID projector headlights and LED projector fog lights because there would be down road visibility and up close full saturation at a low height, so there is less chance of blinding oncoming traffic.
Old 12-27-2019, 12:25 AM   #2132
StormFalcon
Drives: N/A
I've been looking through this thread and searching for 30 minutes to no avail. Where'd you get that front crash bar? It looks sick with the front grill off. Also, have you had issues with crap flying up into your intercooler and cooling setup with the grill off?
StormFalcon is offline   Reply With Quote
Old 12-27-2019, 12:46 AM   #2133
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
It's a JDL crash bar, I ordered it with my turbo kit.
No issues with debris so far but I'm also not driving behind other cars on dirty or unpaved roads. There's been a few leaves that made their way in but they're easy to grab. I'd say there's no more risk for small debris getting in than with the oem grille piece present since it's got pretty large openings anyways, not a finer mesh like the FR-S
Old 12-27-2019, 11:34 AM   #2134
StormFalcon
Drives: N/A
Ahh thank you that makes sense now. On a side note, do you have an Instagram page for this build?
The Following User Says Thank You to StormFalcon For This Useful Post:
ATL BRZ (12-27-2019)
Old 12-27-2019, 11:41 AM   #2135
ATL BRZ
ATL BRZ's Avatar
https://www.instagram.com/86senpai/
Old 12-27-2019, 12:45 PM   #2136
StormFalcon
Drives: N/A
Followed.
I think I prefer the brown background over the red. Keeps the focus on the car in my opinion
ATL BRZ (12-28-2019)
Old 01-18-2020, 08:34 PM   #2137
ATL BRZ
ATL BRZ's Avatar
I've been needing to get something more sturdy for my Verus splitter chassis mounts on the JDL front bar. I'd previously used 250lb tensile strength industrial zip ties and was never satisfied with them even though they held my body weight on the leading edge fine. These new clamp mounts are perfect and only $16 👌
The Following 5 Users Say Thank You to ATL BRZ For This Useful Post:
Copy (12-19-2020), kevaughan (02-17-2020), Lonewolf (12-21-2020), Takumi788 (12-19-2020), ybotspawn (04-30-2022)
Old 04-24-2020, 10:54 PM   #2138
ATL BRZ
ATL BRZ's Avatar
Spare package arrived from a friend doing an LS swap. Every engine sensor, OCV, and Fensport underdrive water pump and alternator pulleys. Got a longer belt on the way. These pulleys will slow down the water pump which tends to cavitate, and the alternator which doesn't need to spin so fast to produce the needed amps at sustained high RPM on track. Will also theoretically pick up a couple HP but that's not the point.
The Following 3 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (04-26-2020), ka-titties (04-27-2020), Lonewolf (12-21-2020)
Old 12-18-2020, 10:16 PM   #2139
ATL BRZ
ATL BRZ's Avatar
Finally back on the rollers today for a custom flexfuel tune from DBW Motorsports . Results exceeded expectations! 367whp/322wtq on E76 @ 14psi and 306/267 on pump 93 with the 9psi wastegate spring!
Big gains over the baseline. It made 304whp and 255wtq on E85 on the same 9psi spring back in 2017 with the stock engine! Exceeded that on pump gas this time!
Final numbers!
This car is truly violent now in the midrange. Can't wait to get some more miles on it soon!
Code Monkey (12-19-2020), Copy (12-19-2020), Evil Rocky (01-10-2021), Pat (12-19-2020), Stonehorsw (07-27-2021)
Old 12-19-2020, 05:25 PM   #2140
Copy
Copy's Avatar
Drives: GR Corolla CE
Beautiful car!
IG: grcwicks
Copy is offline   Reply With Quote
The Following User Says Thank You to Copy For This Useful Post:
ATL BRZ (12-19-2020)
Old 12-19-2020, 06:43 PM   #2141
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Is your redline 7k to fight oil pressure loss? Or for another reason? (Dyno not reading rpm properly? Me not reading dyno graph properly?)
Edit- or maybe the turbo just falls off and it's pointless to push higher for your gearing needs
Old 12-19-2020, 10:19 PM   #2142
ATL BRZ
ATL BRZ's Avatar
Its 7400rpm and yeah it just falls off around 7000 because the compressor is right at its 400lb/min output which is around 400 crank hp.
The Following User Says Thank You to ATL BRZ For This Useful Post:
DarkPira7e (12-19-2020)
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 04:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 01:46 PM
