Old 12-19-2019, 02:25 PM   #21449
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Oil change at negative 4 degrees F.
Old 12-19-2019, 02:37 PM   #21450
jflogerzi
jflogerzi's Avatar
Dedication
2013 Series 10 FRS #553
Old 12-19-2019, 02:44 PM   #21451
new2subaru
Weight Weenie
Drives: 15 FR-S
Old 12-21-2019, 01:39 PM   #21452
scottman
scottman's Avatar
Drives: 13 mt fr-s
Added some speed holes -- heat management
scottman is offline   Reply With Quote
Old 12-21-2019, 05:03 PM   #21453
The Red One
Pro Couch surfer
The Red One's Avatar
Drives: 2019 BRZ Sport-tech RS.City car:GD3
Nice slicing to get the air to move idea, any Noise or whistling detected yet?
The Red One is offline   Reply With Quote
Old 12-21-2019, 05:06 PM   #21454
Ashikabi
Ashikabi's Avatar
I'm more curious how this would affect aerodynamics since you're encouraging more air to travel under the car
Old 12-21-2019, 05:20 PM   #21455
The Red One
Pro Couch surfer
Im not a Boeing engineer, and this is not an F1 car, but to me the holes are minimal and unless he is trying for a speed record possibly wont notice any Aero effect. But should help with the Heat issue ... in 5 months when summer comes around again in his area. But you give a valid point why this was not done when they made it...
Old 12-21-2019, 05:54 PM   #21456
Ahhhh…...yes, "speed holes" or ventiPorts.
I remember those from back in the day. Yep, what went around comes around (or something like that) -
Cooled down the engine, added 10 HP and 20 MPH to the top speed -
Old 12-21-2019, 06:07 PM   #21457
The Red One
Pro Couch surfer
Back in the mid sixties my friends father who was a pilot had a Buick with the holes in the fenders, the car would sit for month while he was away, I thought they were neat till I saw close up they where Fake and closed off...
Back to that Under panel idea, I knew I saw this before ...
https://www.rallysportdirect.com/par...num-underpanel
So 15 minutes of your time saves you 300$ not bad!
Old 12-21-2019, 06:09 PM   #21458
JD001
JD001's Avatar
Drives: Subaru BRZ
I thought they were bow thrusters..
Old 12-21-2019, 06:38 PM   #21459
Well, actually not. Although Buicks are considered "land yachts", they normally don't go in the water -
Old 12-21-2019, 08:13 PM   #21460
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Actually, La Salle had them first in 1934 and they were functional.
Old 12-21-2019, 10:57 PM   #21461
scottman
scottman's Avatar
Drives: 13 mt fr-s
Most likely no noise, but I cant test it until spring.
Also picked up a clean used trd airbox today.
Old 12-23-2019, 12:54 AM   #21462
kyle116
Drives: 2015 Scion FR-S
After struggling for an entire day, woke up this morning and finished my uel Tomei header install. Couldnt get all the plastic clips to align on the floor pan but I figured that wasnt that bad
kyle116 is offline   Reply With Quote
