Old 12-18-2019, 11:59 AM   #1
Alpha86
Drives: 2013 Firestorm Red FRS
2014 Heads On A 2013
As the title states, has anyone tried to use newer heads on an older block? I have a 2013 that was affected by the recall and apparently the springs aren't the only thing that's garbage about the valvetrain. I don't want to risk a dropped valve or breaking a rocker arm, both of which should be solved with a 2014/2015 head. So are they backwards compatible?
Alpha86 is offline   Reply With Quote
The Following User Says Thank You to Alpha86 For This Useful Post:
solidsnake11 (12-18-2019)
Old 12-18-2019, 12:13 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
@solidsnake11 is your guy for this type of info.
Old 12-18-2019, 03:39 PM   #3
The 14 and 15 will be completely compatible with the 13.
Alpha86 (12-18-2019), solidsnake11 (12-18-2019)
Old 12-18-2019, 07:09 PM   #4
BlueLine
Drives: 2013 Rally Blue w/Bronze wheels MT
Not to hijack your thread, throw stones, or flame you but shouldn’t this be in the engine sub rather than engine swap?
Vyse | How fast can you afford to go | Etc...
BlueLine is offline   Reply With Quote
Old 12-19-2019, 05:21 AM   #5
Zer0
Drives: 2015 frs
So when my swap is done I suppose since its supercharged I will post it up in the forced induction section. After all its supercharged.
Zer0 is offline   Reply With Quote
Old 12-19-2019, 08:28 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I think you should post it in the cosmetic section since it is for show
solidsnake11 (12-19-2019)
Old 12-19-2019, 08:44 AM   #7
Zer0
Drives: 2015 frs
I wish it would look good enough for a show. Highly unlikely though. This shit is built for charmin it's all about the go. Lol
Old 12-19-2019, 09:30 AM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
LOL. Can't wait to see that monster done. You got more in your engine and trans then I have in my whole car
Old 12-19-2019, 09:47 AM   #9
Zer0
Drives: 2015 frs
Thanks. I work to much, so it's going to be a while. I just enjoy working on machines. I started the build to kill time, but it also has murdered my bank acount. Anyway hope this guy gets his heads straight.
Old 12-19-2019, 10:15 AM   #10
Alpha86
Originally Posted by solidsnake11 View Post
14+ Camshafts may be different?
If I'm doing head/valve work, its probably getting an aftermarket cam anyways to take advantage of a higher redline.
Zer0 (12-19-2019)
Old 12-19-2019, 10:18 AM   #11
Alpha86
Was considering, I figured it fit here because its replacing half of an engine with non-stock parts. If any mod wants to move it, that's totally fair.
Old 01-10-2020, 12:26 PM   #12
fika84
fika84's Avatar
I can vouch for this as I have 2014 heads on my 2013. It was straight forward and everything is running just fine!
If you're buying your 2014 heads used, you may want to invest in new cam gears depending on the condition.. If the 2014 engine had metal shavings in it I wouldn't reuse the cam gears. You could try and clean them but it's not very simple!
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Alpha86 (01-10-2020)
Old 01-10-2020, 12:43 PM   #13
tomm.brz
Drives: brz 2017 hksv2
the heads are the same
in 2014 they changed the rocker arms and the cams, but the heads are the same
from August 2016 (my2017) they changed the Cam Intake RH (the one that has the lobe for the fuel pump, and all the 16 valves, making them longer
Old 01-11-2020, 02:51 AM   #14
tomm.brz
ops, yes you are right 2014+ the made valves longer
MY17+ they changed again the code of the valves because they made them buffed for less friction
TRD Carbon Fiber Fender Fins Scion FR-S 2013-2014 / Subaru BRZ 2013-2014 RallySport Direct Exterior Parts - Lighting 73 07-31-2015 11:39 AM
Cosworth Stage 1.1-1.3 Power Package BRZ 2013-2014 / FR-S 2013-2014 With Videos! RallySport Direct Engine, Exhaust, Bolt-Ons 104 07-02-2015 10:10 AM
APR Front Bumper Canards Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 RallySport Direct Exterior Parts - The Rest 0 01-14-2014 11:17 AM
GTSpec Rear Subframe Reinforcement Panels Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 RallySport Direct Brakes, Suspension, Chassis 0 01-08-2014 12:32 PM
Injector Dynamics Fuel Injectors 1300cc Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 RallySport Direct Engine, Exhaust, Bolt-Ons 0 01-07-2014 12:13 PM
