| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#4173 |
Drives: 2013 BRZ WRB
Thanks for your help! So I wouldn't notice any performance or handling differences between these tires that are only slightly different in size?
| The Following User Says Thank You to JimmyBoy For This Useful Post: | Vital (12-02-2019) |
#4174 | |
Something something
Drives: 2017 BRZ (Vortech), 1993 R32 GT-R
Sounds like my only option is to get coilovers or run 245 tires then. I guess I might as well run coilovers since the Toyo Tires I'm getting with are very good already. |
| The Following User Says Thank You to Suzuyans For This Useful Post: | Vital (12-02-2019) |
#4175 | |
Damn that's crazy...
Drives: 2015 BRZ
Slightly different can actually improve performance and handling as long as you can get a lighter than stock wheel and a 225 tire. You would be reducing weight and increasing grip. |
#4176 |
Something something
Alright cool. I'll look into running 5mm spacers for the time being since it's very minimal.
Thanks! Will handling be affected if I just had 5MM spacers to the front and not the rear? From what I heard, the back clears just fine. Otherwise coilovers first to me. This is pretty much the last peace of mind I need. |
#4177 | |
Drives: 2015 BRZ
| The Following User Says Thank You to Vital For This Useful Post: | Leonardo (12-02-2019) |
#4178 | |
Country Boy 4 Life
I agree with @Vital. Adding a 5mm spacer, that needs extended studs, adds cost and labor. And, with out any room to add negative camber, it will poke 5mm more. A 3mm would be better, if it is needed. A 18x9.5 +32 = 17x7 +0 offset. This is setup (18x9.5 +32) will poke like a stock wheel with a 64mm spacer. if a 30mm spacer is needed to make a stock wheel flush in the front, then your new wheel will poke 34mm. I would just get a 245/35/18 front tire for your +35 offset 18x9.5 wheels. YOu can run a 255/35 in the rear. This small stagger won't change your cars feel that much at all. Then, later, after you get coils, you can add a bunch of negative camber, and matching front tires. Or get coils first, it is something to contemplate...
I LIKE TIRES! |
#4179 |
Got some 18x9.5 +35 wheels. What is the widest tire I can run? I have coilovers with adjustable camber in the front and rear. I wouldn't mind running a meatier 40 tire vs a 35 too. But if I need to run a 35 too be able to squeeze a 255 in there that's fine.
Should I get the fenders rolled regardless with a 9.5 wide wheel? Sent from my Pixel XL using Tapatalk |
#4180 | |
Drives: Black 2013 frs
#4181 | |
Drives: 2015 BRZ
| The Following User Says Thank You to Vital For This Useful Post: | Leonardo (12-03-2019) |
#4182 |
Any need to roll the fender with that 255/35 ? I guess I just think about a 40 tire providing a little more protection from harsh road conditions, potholes etc
#4183 |
Drives: 2015 BRZ
No i dont think you need to roll fenders for that spec wheel. That size has become pretty common these days. Although it will depend on how low you are though...
#4184 |
Something something
Turns out the tires I got were bad sadly. Two were torn.
I'm on stock suspension as before but. Does 245/35/18 Nankang NS-25 rub with 18x9.5 wheels on stock suspension? I keep hearing different answers about it. Option Lab R716s. |
#4185 |
Please delete
#4186 |
Drives: Subaru Brz - WRB
Will 17 x8.5 +30 fit on stock suspension? I know it'll poke a bit, but I want to ensure before pulling the trigger on a purchase.
If it does, what tire sizes would you recommend to limit any potential for rubbing? Last edited by equachie; 01-17-2020 at 01:33 PM. Reason: Additional question |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
