| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#2465 |
Drives: FRS
Finally got everything mounted. Wish it wasn't night so I could take some proper pictures. Anyways this thing feels like a boat in the rear and I think it has to do with these funky control arms I bought to camber the rear in
https://rover.ebay.com/rover/0/0/0?m...2F172482094142 Anyways I'll align it and figure it out Avid av20 +38 18x9.5 Michelin Sport AS3+ 245/35 Front 275/35 Rear ![]() ![]() Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to vladniko86 For This Useful Post: | Leonardo (11-26-2019) |
#2466 |
Drives: FRS
Those guys on eBay are just reselling these guys.
https://www.privatelabelmfg.com/prod...pw-rlca-sf.htm I'm thinking of putting the bigger bushings on instead of the small swiveling one with the black extensions. Also probably not a bad idea to get toe arms as one of mine is almost seized Sent from my iPhone using Tapatalk |
#2467 |
Drives: 2015 BRZ
It feels like a boat because you paired heavy wheels which are pretty wide with wide tires and on top of that its staggered...
#2469 |
Drives: FRS
So I did my alignment today and figured out what the boat feeling / oversteer was about. Had .30 and .45 toe out from my new control arms. Made them .1 toe in and it feels so much better!
| The Following 2 Users Say Thank You to vladniko86 For This Useful Post: | Leonardo (11-27-2019), StraightOuttaCanadaEh (11-27-2019) |
#2470 |
Drives: Red 86
Can someone pls advise me if I can put 245/45R17 without fuckin my gearing ratio coz I cant seem to find 245/40R17 where I live. My wheel size ia 17×9 +38
Sent from my SM-G975F using Tapatalk |
#2471 | |
Country Boy 4 Life
215/45/17 is 24.6" diameter (stock size) 225/45/17 is 25.0" diameter +1.6% 235/45/17 is 25.3" diameter +2.8% 255/40/17 is 25.0" diameter +1.6% 245/45/17 is 25.7" diameter +4.5% For size comparison, in the pics above of the 275/35/18 on the rear has a diameter of 25.6" I have seen a few guys run a 245/45/17 without rubbing on a 17X9 +38. (rubbing will also depend on how much you are lowered) It will change your gearing though. For DD, I don't think it would be that bad. For track, 245/45/17 is not ideal.
I LIKE TIRES! |
| The Following 4 Users Say Thank You to Leonardo For This Useful Post: |
#2472 |
Drives: 2013 SCION FR-S
adding some pics of my 2013s newly member
17x9. 245/40. +40 -- sweet spot no rubbing or fender roll, TANABE REVEL COILS ✌ ![]() ![]() ![]()
IG: @k1rkky
2013 FR-S ARGENTO |
| The Following 3 Users Say Thank You to FRSK1RK For This Useful Post: |
#2473 |
Drives: BMW E30, 2014 FR-S
17x9 +35 Enkei RPF1
255/40 Firehawk Indy 500 tires. Tein Flex A coilovers, -2.55 camber in the front, -1.25 in the rear.
| The Following User Says Thank You to kevaughan For This Useful Post: | JD001 (04-24-2020) |
#2474 |
@rayhere
^ Hello fellow Torontonian.
Current setup is 17x9.5 +36 TE37SL vs. 17x9.5 +45 TE37 Saga with 3mm spacers last year. Both sets wrapped in 255/40 and -3.3F/-2.4R for camber. The Sagas rubbed at full lock but no issues with the SLs. Concavity is much better on the SLs and makes the Sagas look flat in comparison. ![]()
#2477 |
Drives: 2016 Scion FRS Halo
I have the 18x8.5 +35 with 245/35. I think the 245/40 17s like that probably a little better ride still looks good especially if you drop it over an inch.. so props I like it. I don't really want to drop mine over inch because I don't want that much neg camber in the back and toe in. I don't want LCA and links in the back at this time. So my 18s look a little better in that scenario, but they don't ride as good and tires are more expensive
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 06:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 07:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 01:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 02:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 04:05 PM |
