#63393 | |
| The Following 5 Users Say Thank You to Ultramaroon For This Useful Post: | DarkPira7e (11-26-2019), hpanju (11-26-2019), humfrz (11-26-2019), JD001 (11-26-2019), spike021 (11-26-2019) |
#63394 |
| The Following User Says Thank You to humfrz For This Useful Post: | spike021 (11-26-2019) |
#63395 | |
![]() No problem unless the snow builds up on the roof - ![]() ![]() humfrz |
#63396 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | ScoobsMcGee (11-26-2019) |
#63397 | ||
Interviews in this industry are just part of a larger, broken system. I’m not sure there’s an easy way to fix it. Many people have had a plethora of discussions on it with no widely acceptable solution. I think part of the problem is actually rather simple. It lies in the subjectivity of the testing environment that people and companies put their candidates into. Usually questions and problems are left up to individual interviewers to decide on - with only a basic list of bullet points of the areas to focus on. That means there’s never any real baseline. And because of that, X, Y, and Z people might think some question they ask is “easy” when realistically, their notion of something being “easy” can differ wildly from someone else’s. And not only that, but in the interview setting it can be even more complex. It’s easy for an interviewer to spend a couple hours on one day deciding a problem and trying it themselves to know if they think it’s right for an interview candidate to attempt to solve during an interview. But then once the candidate is asked said question, they have typically 45 minutes in which to answer it. And at the same time, they’re expected in many cases to yield multiple answers. A first pass answer that is inefficient but still provides correct results, and then a more efficient second answer that could be either a modified version of the first answer’s algorithm or a completely different one. And while this is all happening, rather than the candidate have space to think it through on their own, they have to relate it to the interviewer who they’ve likely never met before. Don’t get me wrong, a lot of things in there are incredibly useful on the job. Being personable, being able to communicate and ask questions for clarification, etc. But doing this in an interview environment for a software engineering job can just be such a disaster if the candidate just doesn’t do well in that environment. So a common thing these days is that people who would likely do just fine in the day to day of the job they’re interviewing for get rejected for trivial, subjective reasons and then there are those who are great at rote memorization and pressurized testing who ace the interview but wind up not being good enough at the actual job once they’re hired. But the current tech software industry has decided these forms of false negatives and false positives are worth the risk because there’s “no better way.” Anywho that turned into a bit of a late night rant. Sorry hehe.
Instagram: @spike.grc
#63398 |
Famous Potatoes
Drives: '15 ultramarine
| The Following User Says Thank You to Sapphireho For This Useful Post: | ScoobsMcGee (11-26-2019) |
#63399 | |
Famous Potatoes
And just as I thought, my secret tv room upstairs was originally all attic. Second owner did that. We are 4th owners since it was built in 1988. Also found out my POS hot tub is from 1988. Amazing it still works at all. |
#63400 |
Famous Potatoes
Had a bad truck day yesterday. The wife and I went shopping for our thanksgiving goodies and truck #2 was making funny noises. Sounds like one of the belt driven accessories is starting to having bearing problems or something. Crap.
So later in the day I take truck #1 out, get to Home depot and the check engine light comes on. Code 420. Ok, that's cool. I don't have a smog check for 2 more years. I'll deal with that one later. Cleared code. Hopefully just a hiccup. |
#63401 |
Rust bucket enthusiast
Alarm went off this morning. I had no idea why, so I dismissed it and went back to sleep. Woke up at 6:10. Thought to myself "huh, the sun is coming up"
I showed up to work 40 minutes later with mismatched socks, no coffee, and full bed head. For some reason, I thought it was a day off. Maybe my mind is trying to tell me something? |
| The Following 6 Users Say Thank You to DarkPira7e For This Useful Post: | NoHaveMSG (11-26-2019), ScoobsMcGee (11-26-2019), soundman98 (11-26-2019), Spuds (11-26-2019), Tcoat (11-26-2019), Ultramaroon (11-26-2019) |
#63402 | |
Clock doesn't go off. I wake up in a panic since I have 20 minutes to get to work. Leap out of bed throw on whatever clothes are nearby and dash out the door. Drive like a maniac to get to work luckily the traffic is abnormally light. Pull into an empty parking lot and wonder what the hell is going on. It is Sunday.
| The Following 6 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (11-26-2019), DarkPira7e (11-26-2019), NoHaveMSG (11-26-2019), ScoobsMcGee (11-26-2019), soundman98 (11-26-2019), spike021 (11-26-2019) |
#63403 | |
Damn that's crazy...
Drives: 2015 BRZ
| The Following 4 Users Say Thank You to Will BRZ For This Useful Post: |
#63404 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | Spuds (11-26-2019) |
#63405 | |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Tcoat (11-26-2019) |
#63406 | |
The one time I did it was about 25 years ago when I was just starting down my carrier path. I knew the security guard saw me pull in and since I didn't want to look like a fool I signed in and went straight to my office to "finish something up". Once I got to the office I figured I was now trapped for an hour or so and decided to finish up a project while I had no interruptions. Took me a little over an hour and then I left. Monday the boss comes in and asks why I was there on a Sunday. Told him I just wanted to get things wrapped up and had some time to kill. He was very impressed and for my "dedication" I got a really good review that year.
| The Following User Says Thank You to Tcoat For This Useful Post: | DarkPira7e (11-26-2019) |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 08:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 11:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 11:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 06:18 AM |
