Old 11-15-2019, 03:26 AM   #15
kishi23
Drives: TOYOTA GT86 2014
Originally Posted by Will BRZ View Post
Open up your hood and have somebody else start your car. Peek in there with a flashlight and see if you are able to see anything. Checking the under panels/splash guards when the rattle is most noticeable (cold starts) might be your best bet. Good luck hope it's nothing serious.
It happens only when revving the card or on drive. Cold start without gas throttle doesn't replicate the sound.
kishi23 is offline   Reply With Quote
Old 11-15-2019, 03:27 AM   #16
kishi23
Originally Posted by Clutch Dog View Post
rattling that isnt heat shields?
pulley? belt? tensioner? do you have one of those stupid grimmspeed tooltray things? are you missing a bolt?
This what I am suspecting, a pulley or tensioner something is lose or need to replace, btw ill check them today. if I found the culprit.
Old 11-15-2019, 04:16 PM   #17
Cup_Ah_Joee
Drives: 2016 Raven Black FR-S
Does your engine sound louder at all? Thats the noise I would get when the nut started backing out where my exhaust connects to the front pipe before it eventually came off and got super loud. Its worth checking since its pretty simple to view from under the car
Cup_Ah_Joee is offline   Reply With Quote
Old 11-15-2019, 08:23 PM   #18
Cubix
Cubix's Avatar
Drives: 2015 FR-S
Sounds like my intake (K&N drop in)
Cubix is offline   Reply With Quote
Old 11-16-2019, 12:19 AM   #19
kishi23
It doesnt, sound is very consistent from cold start till driving.
Old 11-16-2019, 12:20 AM   #20
kishi23
Got a stock intake...
Old 01-22-2026, 01:16 AM   #21
brettito
Drives: Silver 2018 BRZ w/ Performance Pkg
Did you ever find out what was causing this?
brettito is offline   Reply With Quote
FRS 2015 Cold Start Sound. Feronous Engine, Exhaust, Transmission 16 07-10-2018 10:04 PM
Grind sound on Cold start japes Issues | Warranty | Recalls / TSB 12 07-07-2016 08:58 PM
Q300/Slight rattling sound on cold startup ikkomaji22 Engine, Exhaust, Transmission 1 11-15-2014 06:44 AM
Rattle sound on cold start Frs32907 Issues | Warranty | Recalls / TSB 0 07-12-2014 10:36 AM
rattle sound cold start marky Issues | Warranty | Recalls / TSB 1 03-24-2014 06:16 PM
