Old 11-13-2019, 07:57 PM   #43
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by 86MLR View Post
What's a "eco light"
the little upshift triangle. it's always telling me i'm doing something wrong, or otherwise, letting me know i'm in gear.
86MLR (11-13-2019)
Old 11-13-2019, 08:03 PM   #44
Originally Posted by highway7 View Post
Decade"s" is an exaggeration, but I have family cars whom the coolant has never been touched in 13 years and the level is perfectly fine. While with this car, I find myself topping up the coolant every 9 months or so.
Not sure that adding a few ounces ever 9 months is frequent nor an issue. I have had family cars that needed it added every couple
Of months and they were normal. Different cars have different needs and that does not make them problems.
Old 11-14-2019, 06:28 PM   #45
qqzj
Drives: MDX, Camry
Originally Posted by Busybee View Post
Hi,
I have a 2019 limited and 14000 miles. Last month I just checked some of the liquids and realized that the coolant level was at min (cold). After driving from Boston to NY the level gets close to max (is normal when the car is heated)
Today I checked before turning on (cold) and the level was way below the min. I did drive just 5 miles and it was just close to min. It’s scares me but never had this in my previous cars. I always check the ground for any leaks (coolant oil etc) and never saw a leak.
This car has been used only for my weekly Boston - NY trips and has the 14K miles. Never pushed the car and regularly drive 60-70 MPH.
I wonder if the decrease of the coolant is normal. I had my 6K and 12K Checks at the Subaru dealer and they also did not mention anything regarding this.
I can get the oem Subaru coolant and put a little in. Just wanted to ask if there is anything to worry about.
If topping it, should I add it on a heated (and after how long driving) car?
Thanks
The same happened to me before. I added OEM coolant once and never need to replenish again. My theory is that Subaru doesn't properly burp the coolant well before shipping the cars. Lazy bastard. I never needed to spend $30 on coolant prematurely before.
Sent from my Pixel 3 XL using Tapatalk
qqzj is offline   Reply With Quote
The Following User Says Thank You to qqzj For This Useful Post:
Busybee (11-15-2019)
Old 11-14-2019, 06:37 PM   #46
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I just use the little round red light to tell me when to shift...
The Following User Says Thank You to Spuds For This Useful Post:
soundman98 (11-16-2019)
Old 11-14-2019, 07:20 PM   #47
mrhayes1
Drives: 2013 Scion FRS white
You should check your coolant at consistent times. Check it the morning before you drive when the car is cool. The coolant level should always be the same. You may have to add a bit of coolant every once in a while (every few months maybe ?? but that's it).
I live in AZ where it is dry and hot as hell and have only added coolant a handful of times of the past 5 years. If you are loosing coolant significantly enough to where it is noticeable over a short period of time that is not normal despite what anyone tells you.
mrhayes1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mrhayes1 For This Useful Post:
Busybee (11-23-2019), sato (10-29-2021)
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 09:21 PM
Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install The Sentinel Engine, Exhaust, Transmission 92 03-09-2015 06:20 PM
first time running Slick tires... Pedal dance or normal 5sec trac off? dejxx Tracking / Autocross / HPDE / Drifting 6 11-16-2014 05:07 PM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 04:17 PM
