Old 11-05-2019, 02:29 PM   #1
8inchAzN
Drives: Car
Wheel Studs part of Powertrain Warranty
One of the wheel studs (the bolt that the lug nut connects to) sheered off. I was wondering if this is part that is covered under the powertrain warranty.
8inchAzN is offline   Reply With Quote
Old 11-05-2019, 02:48 PM   #2
No. It is general warranty. If they cover it at all.
8inchAzN (11-05-2019), strat61caster (11-05-2019)
Old 11-05-2019, 03:20 PM   #3
i8ur911
Drives: 17 BRZ Series.Yellow
Yeah, wouldn't be something covered under powertrain. As @Tcoat suggested, they likely wouldn't even cover it under the "bumper to bumper" coverage....unless you have an awesome relationship with your local dealer and do all the maintenance there. Even then, it would be tough to get covered.
i8ur911 is offline   Reply With Quote
The Following User Says Thank You to i8ur911 For This Useful Post:
Tcoat (11-05-2019)
Old 11-05-2019, 07:33 PM   #4
Grady
Grady's Avatar
Yes it would be covered if there is a defect. Most likely the stud yielding is from improper maintenance. Who all has R&R'd the wheel? If only the dealer has they will probably cover it if you can prove it. If you or multiple shops have there is no way to prove who torqued the nut improperly.
I had a friends Dad that had a Honda. At about 50K miles the drain plug sheared during removal. The dealer stated it needed a new oil pan and gave him the cost. He had them pull the records and that dealer was the only place that car ever had an oil change since new. The dealer covered the pan replacement.
Old 11-05-2019, 07:48 PM   #5
i8ur911
A wheel stud is 100% not covered by powertrain coverage (I spent 10yrs working for Subaru).
With that being said, service managers can use their own discretion when it comes to approving repairs outside of warranty and that's why it can be of great benefit to have a good relationship with your local dealer.
Sent from my Pixel 3 using Tapatalk
Old 11-05-2019, 09:30 PM   #6
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Wheel studs are in fact covered by the Powertrain Warranty...See picture, item #8 (wheel stud-Subaru calls it a Hub Bolt)
See warranty guide, part #8 covered by Powertrain (indicated by the asterisk) and by Subaru Added Security Gold Extended Warranty (indicated by the G)
Subaru Service Manager 15+ years...
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 2 Users Say Thank You to Opie For This Useful Post:
8inchAzN (11-06-2019), Tcoat (11-05-2019)
Old 11-05-2019, 10:09 PM   #7
Well look at that! Either I was lied to or Canada's warranty coverage is different since they would not cover one that THEY broke off on the wife's Impreza. Said it was only covered by General.
Old 11-05-2019, 10:14 PM   #8
i8ur911
I'm blown away. Thanks for sharing.
Not sure if this has changed (haven't worked for Subaru since 2012), but I've never seen them cover a broken stud.
Old 11-05-2019, 10:26 PM   #9
Grady
Grady's Avatar
Again it comes down to is it a defective part. A defective stud would most likely yield during torque. Most broken studs are from improper torque and or corrosion. those are not covered by Subaru. I have been a Subaru service manager for 0- years!
The Following User Says Thank You to Grady For This Useful Post:
Tcoat (11-06-2019)
Old 11-05-2019, 11:32 PM   #10
Opie
Opie's Avatar
Of course, the warranty only covers defects in workmanship or materials. But they are covered.
Old 11-06-2019, 11:23 AM   #11
8inchAzN
Drives: Car
Update: So Gemini Motors Subaru refused to cover it under warranty.
They also decided to change out 2 hub bolts and charge me 2x the labour rate without communicating or getting my authorization. Won't release my car without if I didn't pay it.
Edit, I authorized them to change out 1 hub bolt and labour, but not 2
The Following User Says Thank You to 8inchAzN For This Useful Post:
Tcoat (11-06-2019)
Old 11-06-2019, 12:37 PM   #12
Opie
Opie's Avatar
Not sure if warranty coverage is the same in Canada...
Lifetime Powertrain Warranty = no mods ever? HamburgerSushi Issues | Warranty | Recalls / TSB 14 03-23-2017 11:27 AM
How is p0018 not covered under powertrain warranty....? giorgi0424 Issues | Warranty | Recalls / TSB 45 03-22-2017 04:07 PM
Experiences with Subaru Powertrain warranty? armstrom Issues | Warranty | Recalls / TSB 17 04-03-2016 01:01 AM
Headers and Powertrain Warranty? smg1138 Engine, Exhaust, Transmission 5 07-27-2015 02:27 PM
wheel studs and brake calipers part II trackjunkie Tracking / Autocross / HPDE / Drifting 5 10-05-2013 02:56 PM
