#43 |
Drives: stanced
#45 |
My bet ecu or the custom reverse light. But it sounds like what happened to me with my wife's ford flex. Positive terminal connector was completely corroded. Replaced it but some how the ground was not on tight enough or cleaned... It almost as if the car was in theft mode. Lights came on but no crank and no start. Cleaned it a bit more and tightened down car fired right up... When it was not starting my Bluetooth obo2 code reader was not working. After no issues.
2013 Series 10 FRS #553
#46 | |
Drives: stanced
#47 |
Drives: stanced
My car is still not starting and the next available day for my shop to look at it is next week. Are there any certain fuses that I should be checking in particular? Here a list of my current symptoms: car not starting, tail lights & reverse lights not working (only when I lock or unlock the car they flash), radio doesn’t work, air conditioning and heater don’t work, windows don’t roll up or down, parking lights don’t come on with headlights but they flash with the key just like the tail lights and reverse light, windshield wipers don’t work, car doesn’t shift into neutral or drive without me using the shift bypass button. Any and all input would be helpful, thanks.
#48 | |
Drives: 4wd zooks
Don't rely on just looking at them , because fuses can appear fine when actually open circuit from just being old. |
#49 | |
#50 | |
Drives: stanced
#51 | |
Drives: stanced
#52 |
I would think that a previous owner that would remove the muffler and put in a custom backup light may have done many other changes that are not easily seen. Many will remove other custom goodies to sell, leaving partial parts installed.
It could be time for a dealer to check it over. You may otherwise be chasing problems for ever. A good shop that has a lot of experience with this kind of modified cars would also be a good choice, but it will cost either way. From your posts it would seem you have limited experience with custom cars, might be a good idea to find a club with knowledgeable people to help you. Most car nuts are willing to help and teach if you will listen. I know you just want it fixed and start playing, Buying a used car that is modified is always a risk. Did you buy privately or through a dealer? |
#53 | |
humfrz |
#54 |
Drives: stanced
THANK YOU ALL FOR YOUR INPUT! I apologize if you were under the impression that the car was modified before I bought it. The car was very much stock and straight out of the factory when I bought it. I was the one who had the muffler taken off and the fourth brake light installed. At this point and after what you have recommended, I am going to give Scion a call and see if they have any one that would be able to take a look at my car. Thanks again!
| The Following User Says Thank You to Flunoir For This Useful Post: | humfrz (11-02-2019) |
#55 | |
Drives: stanced
#56 | |
There was a time when I could diagnose any problem with an automobile engine and fix it. However, as they have come to be more complex, sometimes it's best to take it to a specialist for a fix. ![]() humfrz |
| 2013 FRS Engine Died | Jamesallen45 | Issues | Warranty | Recalls / TSB | 24 | 05-31-2018 05:30 PM |
| Beatrush Catless Equal Length Exhaust Manifold Subaru BRZ 2013-2015 / Scion FR-S 2013 | RallySport Direct | Engine, Exhaust, Bolt-Ons | 21 | 06-03-2015 03:21 PM |
| Takeda Intake System; Stage 2 Wrinkle Black; PRO 5R; Scion FR-S 2013 H4-2.0L TM-2013 | AMPLIFIED MOTORSPORT | Engine, Exhaust, Bolt-Ons | 16 | 10-03-2012 09:03 PM |
| 2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast | Zgrinch | Scion FR-S / Toyota 86 GT86 General Forum | 124 | 02-21-2012 03:43 AM |
