Old 10-29-2019, 09:32 PM   #1
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Replacement rotors for BRZ PP Brembos?
After a bit of searching I'm still a bit lost as to what options us PP owners have for rotor replacements.
Are there tried and true options out there? I see OEM rotors listed for $411—something seems fishy there.
mistople is offline   Reply With Quote
Old 10-29-2019, 09:48 PM   #2
Code Monkey
Drives: Subaru BRZ
Google KNS Brakes and see what they have.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
mistople (10-29-2019)
Old 10-29-2019, 10:18 PM   #3
i8ur911
Drives: 17 BRZ Series.Yellow
PM sent
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
Old 10-30-2019, 09:16 AM   #4
Grady
Grady's Avatar
I just went through this. Not much info out there about what fits. The best info I found was on FT86speed. I ended up going with the DBA 5000 series 2 piece drilled and slotted on the front 5654GLDXS-10. DBA 4000 series slotted on rear 42656S-10.
I did find a better price on some components at other vendors. Also when I ordered the rear rotors from FT86speed I made a mistake. When I contacted their “Customer Service” I was basically told it is not our fault you made a mistake for F you! It was not the fact that they would not help it was the way they handled it. They are on my black list now.
The Following User Says Thank You to Grady For This Useful Post:
sroby (01-15-2020)
Old 10-30-2019, 09:38 AM   #5
i8ur911
StopTech makes rotors for the PP cars; blanks, drilled and slotted.
If anyone needs help or more info, feel free to PM me.
Old 10-30-2019, 09:51 AM   #6
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Rockauto.com or just search the part number.
Fronts: CENTRIC 125.47019
Rears: CENTRIC 125.47043
Please dear god don't overpay for rotors like DBA. From an engineering standpoint, you simply want high carbon content, blank (but vented) rotors. Don't believe me? Look up Formula 1 brakes and you'll see they run blanks. It's simple thermodynamics, where you want as much useful mass as possible. Besides, pads don't expel as much gas as they used to so the viability of slotted are nullified and drilled rotors? Well that's just literally unsafe for track applications. Edit: There's an argument to be had about slotted's great water-shedding ability, but useless you'll building a rally car that's not needed.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following 4 Users Say Thank You to Goingnowherefast For This Useful Post:
Horrid_Funk (10-30-2019), i8ur911 (10-30-2019), NaturallyAspirated (10-30-2019), Shizuka (11-04-2019)
Old 10-30-2019, 10:34 AM   #7
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Don't forget that with some applications, 2 piece rotors are for weight savings and are quite a bit more expensive. There are a lot of neat details baked into some rotor packages (temperature indicators for example) that while some may find them frivolous, some may like the information before settling with a setup without needing a temp sensor gun.
True that they aren't always functionally important, but customization is why cars are fun, right?
Old 10-30-2019, 10:58 AM   #8
Goingnowherefast
2 piece rotors are included when I mention blanks. You can get drilled/slotted/blank 2 pieces. While the information can be considered nice, people need to just do it right and invest in a quality pyrometer. They're like a few hundred, which is effectively the cost difference between the regular rotors and the DBA's listed. Not only can that be used to examine brake component temperatures, but it crucial to setting up a car suspension wise.
Old 10-30-2019, 11:35 AM   #9
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
To back what GNF says EE has a video saying basically Blanks are the best.
[ame]https://www.youtube.com/watch?v=78wbht355R8[/ame]
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 10-30-2019, 12:04 PM   #10
Grady
Grady's Avatar
DBA’s are not expensive.
Also F1 brakes are carbon fiber. Apples and oranges. Yes there are CF brakes that are drilled.
Old 10-30-2019, 12:11 PM   #11
Goingnowherefast
It's not apples and oranges. The laws of thermodynamics are the same. This is why we can derive tactics that work at the highest level of motorsports and make them work at a grassroots level.
Centric High Carbon content: $66 per rotor
DBA: $147 per rotor (on sale, $238 normally)
So they're actually over twice as expensive. Normally 3.5x expensive lol. You can buy a super high quality pyrometer for the money saved.
Old 10-30-2019, 12:40 PM   #12
mistople
mistople's Avatar
Thanks, these are basically what I've been looking for. Cheap and simple! Slotted/drilled looks cool, but there's no way I'm paying $600-800/axle for rotors.
Do these two part numbers specifically fit the PP brakes? It's hard to tell from the listings.
Old 10-30-2019, 12:44 PM   #13
Goingnowherefast
Yep! According to Centrics brake catalog found here: https://www.apcautotech.com/automoti...systems?page=1
The Following User Says Thank You to Goingnowherefast For This Useful Post:
mistople (10-30-2019)
Old 10-30-2019, 01:37 PM   #14
Grady
Grady's Avatar
Hey I was sold on Kangaroo paw cooling! Sounded too cool not to have!
Anyway we are done here OP stated he is looking for cheep. He will not listen to ether one of us now!
$600 Brake retrofit, Cadillac ATS brembos, STI rotors. etc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 135 12-24-2021 11:19 PM
STi Brembos, rotors, and brake lines jwbrocloud Brakes, Suspension, Chassis 5 01-09-2015 10:55 PM
04 STI Brembos, Hawk pads, 5x100 front rotors Philly758 Brakes, Suspension, Chassis 7 12-06-2013 08:55 AM
FS: 2004 STi Gold Brembos(5x100) w/Hawk Pads, Rotors, lines!~~MINTTT~~ nemesisdrift Brakes, Suspension, Chassis 25 11-22-2013 01:25 AM
2005 STI Brembos Powder Coated, Hawk HPS Pads, Stoptech Rotors and Braided Brake Line Jamifra Brakes, Suspension, Chassis 10 10-29-2013 11:31 AM
