Old 10-01-2019, 12:20 AM   #21281
rookietopro_frs
rookietopro_frs's Avatar
Drives: 2013 Scion FRS
Finishing up this turbo install , can't wait to get everything finished.
[ame]https://www.youtube.com/watch?v=BXd8jGwKr5U&t=121s[/ame]
rookietopro_frs is offline   Reply With Quote
Old 10-01-2019, 04:45 PM   #21282
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Installed BRZ headlights and Verus front splitter:
spitsnaugle is offline   Reply With Quote
Old 10-01-2019, 05:36 PM   #21283
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
BRZ headlights with the FRS bumper looks pretty good!
That engine though..
-Sam
eastendraceshop is offline   Reply With Quote
Old 10-01-2019, 08:47 PM   #21284
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Did you have to do any work on the harness to get the car to play nice with the BRZ lights, or did you just plug and play it as best as you could? I thought the two cars had different harnesses since the FRS uses the high beams as DRLs instead of dedicated lights, aling with the added turn signal.
Just curious.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 10-01-2019, 09:00 PM   #21285
spitsnaugle
-Sam
Thanks, I think the BRZ headlights are a nice subtle change without going overly black-on-black. I added Diode dynamics controllers to the LED bars in them too.
I depinned the 6-pin female connector, inserted the female pins into a 8pin connector that matched the BRZ headlight. Works great, though the ballasts are buzzing louder than I expected.
8 pin connector: 90980-10897
Nice youtube video on how to:
[ame]https://www.youtube.com/watch?v=Pfl3tNA_pJI[/ame]
I added a pin and wire to use the turn signals, but havent hooked it up, not sure if I'll use it or not.
Old 10-01-2019, 11:25 PM   #21286
Overdrive
Sittin' Sideways
Overdrive's Avatar
Good to hear. I've been wanting to put BRZ headlights on the car (if for nothing else to at least gain another signal lamp that people can actually see), so at least I know it's easily accomplished with some parts and a little electrician elbow grease.
-O/D
2016 FR-S, Hot Lava
Old 10-02-2019, 01:33 PM   #21287
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Do those bumps on that pad mess with your foot placement, @MJones_RB?
It takes some getting used to, I'm used to my feet just sort of sliding around when shifting, which is why the floor mats have worn so fast. At the very least this will teach me some foot discipline.
MJones_RB is offline   Reply With Quote
Old 10-02-2019, 01:34 PM   #21288
MJones_RB
MJones_RB's Avatar
Dang, MJones_RB, do you drive with mountain climbing spikes strapped onto your boots -
If that plate don't work, Bubba suggests this:
That would work, too!
It's a combination of sloppy footwork on my part and cheap OEM mats. It happened on my Integra, too, but took a lot longer.
Old 10-03-2019, 10:55 AM   #21289
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
After two weeks of letting the ceramic cure, I did a ONR wash and topped it with their coating designed sealant.
Gahd damn.
Old 10-03-2019, 10:56 AM   #21290
RToyo86
RToyo86's Avatar
A nice solution. Have you looked around for another OE set? I've seen a ton of locals telling them cheap unused.
Old 10-03-2019, 01:27 PM   #21291
MJones_RB
MJones_RB's Avatar
Yeah but it would be silly to buy a whole new set when the other 3 are in perfect shape. I thought about the all-weather mats that Scion originally sold.
Old 10-04-2019, 06:31 PM   #21292
Decep
Drives: 2013 FR-S Series 10
My headlights were starting to look cloudy and faded so i tried out a cheap fix. https://www.amazon.com/3M-Quick-Head.../dp/B079QL8BYK
3m clearcoat wipes with a 3000 grit sanding disc. Results are good! Mine werent pitted or anything just cloudy so the 3k disc was plenty. The wipes are kind of hard to apply 100% uniformly. But they look nearly brand new now.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 10-04-2019, 07:53 PM   #21293
Yea, I need to do that as well. Slowly creeping down from the top.
Old 10-04-2019, 11:23 PM   #21294
Decep
Mine started there too.
First tried plast-x polish, which works fine, and then topping with synthetic sealant. Didn't last more than a month.
Then tried plast-x again and then meguiar's clear coat spray for headlights. Looked like crap/cloudy and i must have missed the top since it came back after about a month.
So far this has been the best looking result but i'll keep an eye on it to see how long it lasts.
RCE SS-1 Coilovers
Corsa Catback
