Old 09-30-2019, 09:17 PM   #29
Oh, we best hesh up, or he will not share his up coming exposé -
"More on this later as I'm working up a big expose."
Old 09-30-2019, 09:40 PM   #30
OOPS
https://www.ft86club.com/forums/show...=119376&page=2
humfrz (09-30-2019)
Old 09-30-2019, 11:22 PM   #31
ermax
ermax's Avatar
Not to mention topping up their oil at 12,400 miles when the service interval is 7,500 miles.
You sure he wasn’t just saying he has been measuring over the past 12400 he’s owned the car? He didn’t necessary say he changes it at 12400. Seems you guys are being a bit harsh on this guy.
The Following User Says Thank You to ermax For This Useful Post:
humfrz (09-30-2019)
Old 09-30-2019, 11:46 PM   #32
Maybe so, maybe so, - us.
Old 09-30-2019, 11:53 PM   #33
norcalpb
norcalpb's Avatar
Ever since I bought an external oil cooler I haven't had a loss in oil level inbetween oil changes. For the 100,000 miles before the cooler, I would top it off every 3k miles. When I'd check it after 3k miles it would be at 40% whereas "full" is 50%. If you are running those oil temperatures, on a windy road, I'd personally be at 60%.
I lose a couple ounces of coolant due to evaporation every month or so. I think coolant is water based. I wrapped the coolant reservoir hose in electrical tape to make it air tight but I was told that was a bad idea so I took it off. That seemed to help somewhat with evaporation but who knows.
It seems you are running the car really hard so you should have an oil cooler by now. I think 220F is a target for most people when it comes to efficiently beating the shit your engine like it seems you are. Could be burning oil but I'm not 100% sure how that happens relative to oil temperature.
Old 10-01-2019, 12:09 AM   #34
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Car hasn't burned a drop that I can tell since I bought it. On my way to 48k miles, just a bit over 3k miles on the current oil (about 1.5 months old), and the level is still where it was when I did the oil change.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 10-01-2019, 01:20 AM   #35
soundman98
ProCrastinationConsultant
soundman98's Avatar
I just change the oil every 500 miles. There's a rest stop up the way, so i just take what i need from the overnight parked trucks.
And peeing in the coolant tank has completely stopped any antifreeze usage
Old 10-01-2019, 03:06 AM   #36
OK, smarty, what IS the boiling point of pee?
soundman98 (10-01-2019)
Old 10-01-2019, 03:09 AM   #37
Originally Posted by Overdrive View Post
Car hasn't burned a drop that I can't tell since I bought it. On my way to 48k miles, just a bit over 3k miles on the current oil (about 1.5 months old), and the level is still where it was when I did the oil change.
With THAT dipstick, how could you tell?
Old 10-01-2019, 06:53 AM   #38
He has 27,000 miles on the car. Not sure how he figured the 12400 and it is an irrelevant number based upon the change interval. Wouldn't have been hard on him at all if he said it once but he resurrected 8 5 year old threads to say it.
Old 10-01-2019, 11:52 AM   #39
Overdrive
Sittin' Sideways
Overdrive's Avatar
Yeah, well, my silly autocorrect typo aside, I know where I filled the level to, and I follow their whole witchcraft procedure for checking it, that whole level surface wait five minutes and blah blah. If it has burned anything, it's not enough to be a significant amount on the stick. And if it ever does, as long as it's in between the notches we're good, right?
-O/D
2016 FR-S, Hot Lava
The Following 2 Users Say Thank You to Overdrive For This Useful Post:
humfrz (10-01-2019), Tcoat (10-01-2019)
Old 10-01-2019, 12:23 PM   #40
Ya, I was just funnen at trying to "read the dipstick" on these cars. Seems like 5 people could read the dipstick and come up with 5 different readings.
Yep, keep in between the holes -
Overdrive (10-01-2019)
Old 10-01-2019, 12:44 PM   #41
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you drive the car hard oil pressure starts to drop out around the middle of the notches. Always good to keep this motor topped off.
Old 10-01-2019, 12:46 PM   #42
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
He necro'd 10 threads. 8 with the exact same post and two more with part of the original post. Burn him at the stake.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
norcalpb (10-01-2019), soundman98 (10-01-2019)
Oil Consumption? smbstyle Tracking / Autocross / HPDE / Drifting 42 10-08-2019 05:50 PM
Fuel consumption figures too PuGZoR AUSTRALIA 25 02-16-2014 06:36 PM
86 / BRZ Oil Consumption ZZT86 AUSTRALIA 1 04-29-2013 09:53 PM
Tyre Pressures/Fuel Consumption Vic_RSA AFRICA 11 12-11-2012 02:20 PM
Weight, fuel consumption and 0-100. Loki556 AUSTRALIA 15 07-16-2012 10:06 PM
