#29 |
Drives: 16' BRZ
#30 |
Drives: 2014 WRB BRZ Limited
I could be wrong, but I feel like ever since this part was released in November of 2017, it said it was V3.
#31 |
Drives: 16' BRZ
So yes I must have had the V3. I promise you everyone saying the rattle doesn’t bother them either has a crazy loud exhaust or doesn’t rev out their engine or both.
#32 |
Drives: 2016 BRZ Limited, Stock
#33 |
Drives: Crapcan
#34 |
Drives: 16' BRZ
Hey, not that I don't believe you guys but I'd love to see a video from anyone of them revving the car to redline in 1st and 2nd gear with the windows up just to prove that you don't have a horrible rattle. Again not saying yours rattles but would love to see it for myself considering the amount of effort I put into trying to stop mine from rattling. The best I could do was minimize the rattle below 4K rpm.
#35 |
Just the tip
Drives: 2017 DGM BRZ
Installed my V3 last weekend, purchased from FT86speedfactory this October. This means it had the rattle "fix" kit included.
Rattles in 1, 2, 3, at 3000-3500rpm and up. Minimal rattle in 4, 5, 6 at cruising speeds. I like to downshift a lot and that is when you get some really nasty rattles... Something in the button area rattles for sure. I've only lasted a week and it's pissed me off enough that I'm going to try and wrestle in the original stock shifter this weekend. I have absolutely zero rattles or vibrations in my car otherwise (seem to have won that lottery) so this one is pretty obvious and I don't think I can live with it. |
#36 |
Drives: Crapcan
So now my shifter started rattling during normal driving. I have noticed if I reach over and push it to the side it stops. I believe this may be due to the shifter rattling against the limiting screws for 1st and 6th. I am going to pull them out and measure them and see if I can get nylon tipped ones.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Turbo (07-07-2020) |
#37 |
Drives: 2014 Subaru BRZ Limited 6spd manual
Does anyone have the dimensions in MM for the rattle fix insert? I somehow lost mine and IRP is either ignoring my messages or just not wanting to ship me another.
#38 |
Drives: Honda Insight
Checking to see if anyone has attempted any fix on the reverse button rod that connects the cable linkage?
That's where 100% of my rattle comes from. |
#39 |
Drives: Toyota GT86
It does not have a real solution, when installing the IRP it is canceling a silentblock and there will always be vibrations and noises, I sold mine and never looked back.
#40 | |
But if someone's found a solution all for the better then I don't even have to R&D it. |
#41 | |
Drives: Toyota GT86
#42 | |
The trick is to try and dampen the rod mechanism as it exits the upper rear casing area, and then dampen the whole shifter arm. I created a sort of "V" shaped bush that the shifting rod sits/slides in, wedged, on top of the large ring where the prop shaft enters the gearbox. I use a very large zip tie that creates a small amount of downward pressure to force the rod against the "V" of the bushing. That takes care of the most obnoxious rattle, but you still need to do some work above the tunnel, inside the car. I simply take lots (lots!) of fairly dense insulation foam (the sort of black foam you wrap around a roll cage for example), cut it into smallish strips, roll them tight. Then you go to town and pack/squeeze/push them into the entire cavity around the stick mechanism...so that it sort of fully/firmly encases the mechanism, as high as you can go. Of course make sure all linkages, and bolts on the shifter are as tight as possible (I use locktite blue) Its painful, but this removes about %90 of the rattle. |
| New RACING short shifter from Individual Racing Parts | Tor | Engine, Exhaust, Transmission | 161 | 12-20-2017 09:07 AM |
| TRD short shifter rattle fix | morrisonmagic | Engine, Exhaust, Transmission | 2 | 06-01-2016 11:30 AM |
| WTB: Megan Racing Cat-Delete pipe And short shifter | AZ_Racer_1 | Want-To-Buy Requests | 1 | 01-25-2015 01:54 AM |
| NonStopTuning Short Shifter, Info, Ideas, Feedback thread | NonStopTuning | Engine, Exhaust, Transmission | 5 | 10-23-2014 11:38 PM |
| kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 02:41 AM |
