Old 09-18-2019, 11:51 AM   #8667
brybot
Drives: 13 DGM BRZ 6MT
Still wanting to sell:
Raceseng 72.5mm pulley for Sprintex 210 (will include smaller idler pulley if wanted) - $100
Sprintex 210 Intercooler kit (never installed, includes blanking plugs for IC or non-IC setups) - $850
Moto East / Xero Limit flex fuel kit with evap ECU plug and gauge - $420
Willing to ship!
brybot is offline   Reply With Quote
Old 09-18-2019, 10:32 PM   #8668
jhalagian
Drives: 2015 brz
Originally Posted by tzbang View Post
If I go straight to the 72mm pulley do I need a different belt or is the standard belt that comes in the kit ok?
The standard belt is the recommended size for that pulley. You’re good to go K061015
jhalagian is offline   Reply With Quote
Old 09-19-2019, 02:13 AM   #8669
kev0
Drives: '14
If i'm running extremely lean and rich (lean for first 7 minutes of driving, then incredibly rich), but my AFR stays at around 14.xx, would it be a problem? I'd assume that it is a problem but my AFR's are stoic.
kev0 is offline   Reply With Quote
Old 09-19-2019, 10:09 AM   #8670
jflogerzi
jflogerzi's Avatar
Lean under normal throttle or WOT? How you measuring this? Fuel trims...
2013 Series 10 FRS #553
Old 09-19-2019, 10:16 AM   #8671
kev0
Drives: '14
Lean when idling. 30% Fuel trims until after about 7 minutes of warming up, then my fuel trims drop to about -20% under normal throttle. Fuel trims are never lean after the warm up, only rich.
Old 09-19-2019, 06:55 PM   #8672
tzbang
Drives: 2013 GT86
Sorry a couple more questions.. just trying to scout all the information before I start installation.
1. I see some people replace the plastic connections at the back for brass. How necessary is it to do this? I mean, should I do this before I do the install? Are they prone to leaking or breaking or something?
2. Does the 72mm pulley need a smaller idler pulley?
3. The instructions say not to start up the car without a tune. But it would be good to be able to start it up and make sure all the belts etc are aligned properly etc before getting it to a tuner.
- I was originally hoping I could get some sort of base tune, perhaps using my OFT just so I could nurse it to the tuners as I don't have anything to pull a car trailer with. Do most people buy an EcuTek license and cable and an e-tune and then take their car to the tuner (or just e-tune)?
tzbang is offline   Reply With Quote
Old 09-22-2019, 08:02 AM   #8673
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
1: Not necessary. You might have a very small amount of leakage possibly with the plastic ones, but it shouldn't be bad enough to change the tuning.
2: No
3: You can start it and idle it. I would not drive it.
Not sure about the tuner scene in NZ but we have e-tuned these around the world. A lot of work went into getting it right. The high compression coupled with high temps and instant boost is something that took a long time to iron out.
Xero-Limit is offline   Reply With Quote
Old 09-22-2019, 03:00 PM   #8674
kev0
Drives: '14
2: No
Hey Mike, I've sent a reply to one of your emails and got this email back a few days later. Not sure why it didn't go through but I sent another one in case. Just thought that you should know.
Old 09-23-2019, 10:13 PM   #8675
tzbang
Drives: 2013 GT86
2: No
Hmm that's a very good point. There are plenty of Ecutek master tuners here. But not that many supercharged 86's.. (there are some). Maybe I would actually be better off with an e-tune from someone who has the experience behind them.
Old 09-23-2019, 10:50 PM   #8676
jflogerzi
jflogerzi's Avatar
Can't go wrong with Mike @Xero-Limit he will take care of you and if very affordable
Old 09-23-2019, 11:19 PM   #8677
tzbang
Drives: 2013 GT86
As I understand it I can buy a bluetooth Ecutek so I can flash a tune on with my iPhone is that correct? That would be useful as I don't have a PC laptop (only Mac).
Old 09-23-2019, 11:41 PM   #8678
kev0
Drives: '14
Can't flash tunes with iPhone even if you have the bluetooth dongle. I have the same kit. I just use Bootcamp on my Mac to flash tunes.
Old 09-25-2019, 01:38 AM   #8679
tzbang
Drives: 2013 GT86
Ok now I have a MAP sensor question.. from what I have read earlier the Sprintex setup needs to use the OEM sensor. But on the Delicious Tuning site they say that you must use their 11psi MAP sensor?
Does everyone still run the OEM sensor and what tunes are everyone using?
I'm a bit unsure which way to go, trailer the car down to a local Ecutek tuner and pay for them to tune it on the dyno. Still have to pay for the Ecutek license and dyno-time. I'm unsure how much experience they've had with these SC kits.. I doubt it would be much.
Or e-tune
Xero-limit, their package is $849
DT, their package is $1095
(+75 for the TJ Hunt Especial - Crackle and Pop I have no idea what that is..)
Old 09-25-2019, 01:40 AM   #8680
jflogerzi
jflogerzi's Avatar
Etune for sure. I am using stock map sensor... And using the 72mm pulley without issues
You can't go wrong with either. Both are solid tuners for this kit.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
