Old 09-24-2019, 10:59 AM   #29
Grady
Grady's Avatar
Originally Posted by GrantedTaken View Post
Not that I am aware of. Who would tint a rear view mirror?
Someone who can’t figure out how to operate a self dimming mirror.
The Following 7 Users Say Thank You to Grady For This Useful Post:
extrashaky (09-24-2019), JesseG (09-24-2019), Mr.ac (11-20-2019), soundman98 (09-24-2019), tehShirt (09-24-2019), venturaII (09-24-2019), why? (09-24-2019)
Old 09-24-2019, 11:03 AM   #30
WNDSRFR
Drives: FR-S,GTI
I wanted to flip the mirror when headlights are blinding me. Owner's manual shows traditional flip type mirror. My BRZ mirror doesn't have that. There is a power button. When I press it, I don't see any difference in the mirror. What is the deal? Broken? Garbage gimmick? Tear it out and install a normal mirror? Piece of crap mirror rattles anyway, and can't even be adjusted. Literally the worst rear view mirror EVER
Shoulda bought an FR-S. It has a little lever to dim the mirror. Works great. You can also see the brake pads without removing the wheels.
The Following 2 Users Say Thank You to WNDSRFR For This Useful Post:
JesseG (09-24-2019), soundman98 (09-24-2019)
Old 09-24-2019, 11:19 AM   #31
Dake
Dake's Avatar
I think I have a solution:
In the forum's User CP, under "Settings and Options", select "Edit Ignore List". Type "GrantedTaken" into the little box and boom - no more issues! Best forum ever.
Dake is offline   Reply With Quote
The Following User Says Thank You to Dake For This Useful Post:
why? (09-24-2019)
Old 09-24-2019, 11:35 AM   #32
winstonscifi
winstonscifi's Avatar
Drives: 2015 Firestorm Red Scion FR-S
Location: Plymouth Minnesota - just west of Minneapolis
Camry is a bloated floaty piece of shit. How dare you suggest such a moronic idea.
How dare I suggest such a moronic idea? Take a look at my avatar - I AM a moron!
winstonscifi is offline   Reply With Quote
Old 09-24-2019, 12:01 PM   #33
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Auto-dimming mirrors usually have two photo sensors, one looking forward and one to the rear. The forward sensor determines the daytime\nighttime operation of the mirror by monitoring long-term ambient brightness. The darker it is outside the darker it makes the mirror.
The rear sensor is to detect headlights from behind. If the front sensor says it's nighttime (dark outside) and the rear sensor detects headlights from behind the idea is to further darken the mirror and reduce glare.
Personally I've never had an auto-dimmer that went dark enough or even close to a manual dimmer.
You can try covering the front sensor with tape of varying opacity to trick that sensor into thinking it is darker outside and dimming more. Black electrical tape would provide the most extreme dimming.
Unfortunately, even the most extreme auto-dimming doesn't seem to be as good as a manual dim. If the rear window has a dark factory tint (or more) then auto-dim might be sufficient.
As for the button on the mirror, it turns auto-dim on or off but it's a gradual process and not readily apparent.
LimitedSlip is offline   Reply With Quote
The Following User Says Thank You to LimitedSlip For This Useful Post:
JesseG (09-24-2019)
Old 09-24-2019, 12:19 PM   #34
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
I want to see what GrantedTaken comes up with next
JesseG is offline   Reply With Quote
The Following User Says Thank You to JesseG For This Useful Post:
winstonscifi (09-24-2019)
Old 09-24-2019, 12:32 PM   #35
I don't know but I will not be trying to help him again. I always give a few chances because maybe things were a misunderstanding but he has now used them all up. I mean really, he can't find the section of the owner's manual? Did it require a page turn and that was to much effort? I found it in under a minute and I don't even have a BRZ manual.
If he is trolling as a joke it isn't working (too subtle maybe?) and if he is serious then he can just go and intercourse himself from here on out.
Grady (09-24-2019), JesseG (09-24-2019), korhun (12-03-2019), soundman98 (09-24-2019), why? (09-24-2019), winstonscifi (09-24-2019)
Old 09-24-2019, 12:41 PM   #36
extrashaky
Drives: 2014 BRZ Limited
Are these things known to break? When I pressed the power on, nothing changed.
It may be disconnected. For a while people were buying the auto-dimming mirrors and mounting them in cars that didn't come with them. If yours didn't come with the Homelink mirror, whoever installed it may have not connected the power correctly.
Originally Posted by Kiske View Post
Do you by chance have window tint blocking or preventing the sensor from auto dimming when being hit by light?
I'm honestly not sure if you're a troll or really this obtuse.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
JesseG (09-24-2019), Tcoat (09-24-2019)
Old 09-24-2019, 01:21 PM   #37
JesseG
JesseG's Avatar
I’m not sure what’s worse, if this person is trolling, or that frustrated with his car. Or her car, or it’s car, I don’t want to discriminate.
Old 09-24-2019, 02:13 PM   #38
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
maybe OP is going through a rough phase in his life
HKz is offline   Reply With Quote
Old 09-24-2019, 02:15 PM   #39
Just use “snowflake” it is gender neutral.
JesseG (09-24-2019), KR-S (09-24-2019), soundman98 (09-24-2019)
Old 09-24-2019, 02:18 PM   #40
JesseG
JesseG's Avatar
Fits all types
Old 09-24-2019, 02:21 PM   #41
JesseG
JesseG's Avatar
And the poor BRZ is caught in the middle
Old 09-24-2019, 03:24 PM   #42
g e
I get what OP refers to.
When I have a pick up truck or large SUV with some of the bright headlight systems behind me, the rear view mirror shoots the rays right into the old retinas.
I adjusted the mirror to the right so that I can see a bit more than half of the rear window. Reflections way diminished.
And a bonus, the blind spot is not as bad. One still needs to be sure the outside mirrors are spread out enough. But this helps.
There. Thread over.
g e is offline   Reply With Quote
FS: OEM Rear View Mirror cammyT Interior Parts (Incl. Lighting) 2 11-22-2016 02:43 PM
FS: Homelink Rear View Mirror tundra22 Interior Parts (Incl. Lighting) 3 03-14-2015 02:57 PM
DIY JDM Rear View Mirror F1point4 DIY (Do-It-Yourself) Guides 29 12-23-2014 02:55 AM
OEM Rear View Mirror and OEM Side Mirror hanabie Cosmetic Modification (Interior/Exterior/Lighting) 2 03-28-2014 11:07 PM
Rear view Mirror pic nixeighty6 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 45 01-27-2012 06:10 PM
