Old 09-21-2019, 02:52 PM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
17x8 +42, 225 or 215. Will I need to roll fenders?
Just making sure before I install, thanks!
leevanf is offline   Reply With Quote
Old 09-21-2019, 03:13 PM   #2
Tristor
Tristor's Avatar
That's nearly an OEM optioned size, however at +42 offset it won't be flush. +42 is perfect flush offset for 17x9 on stock suspension, for 17x8 you'll want +38 or you'll want to run a 4mm slip spacer.
You do not need to roll the fenders... you'll want a 225/40R17 tire.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
strat61caster (09-21-2019)
Old 09-21-2019, 04:11 PM   #3
86TOYO2k17
Drives: 2017 toyota 86
225/45R17* is barely bigger then stock.
225/40 is way too small diameter. 245/40 is nearly stock diameter.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
mrg666 (09-21-2019), strat61caster (09-21-2019)
Old 09-21-2019, 05:13 PM   #4
Tristor
Tristor's Avatar
You're correct, I had a wire crossed. It should be 225/45R17 on 17x8 wheels.
FS: Authentic Rocket Bunny V1 Rear fenders and Front Fenders BRAND NEW MixaL8R Exterior Parts (Aero, Lighting, Etc.) 11 10-22-2018 02:17 PM
StudioRSR 4-point bolt in Roll Cage / Roll Bar StudioRSR_Ben Tracking / Autocross / HPDE / Drifting 0 06-28-2018 09:26 PM
Show us your Custom Roll Cage or Roll Bar and Harness Setup Black Tire Tracking / Autocross / HPDE / Drifting 27 02-13-2015 09:59 PM
feeler CA: trade seibon CF fenders for stock red fenders Alliedforces86 Exterior Parts (Aero, Lighting, Etc.) 11 08-08-2013 01:03 PM
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 05:44 PM
