Old 09-17-2019, 01:55 PM   #3725
tony_r
tony_r's Avatar
Drives: '15 STX
Seems to me like you need to work with the rear end more and not the front. Try stiffening it and then changing the rake angle.
The car doesn't trail well, imo. Need to be soft with it and have a softer brake compound.
tony_r is offline   Reply With Quote
The Following User Says Thank You to tony_r For This Useful Post:
strat61caster (09-17-2019)
Old 09-17-2019, 02:05 PM   #3726
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Originally Posted by Lincoln Logs View Post
It will depend on the course, but I'd wager the 255 is going to be more advantageous than not. I've driven some 13-16 cars the same day as my 17 and there is a big advantage to less shifts.
well i was talking to some people last week and non of them run 255 but they dont have 17+. someone said that 255 contact but i dont seem to be having an issue but then again i dont have REs yet. im just trying to figure out what im going to get this winter
Old 09-17-2019, 02:10 PM   #3727
CoolHandMoss
Drives: 2013 FRS
Originally Posted by steverife View Post
I haven't started with STX suspension yet, so this is just general....
Where is your front toe? I feel like toe out causes mid-corner push.
Also, what happens when you stiffen the front bar or spring?
Also, is this solely inspired by Lincoln? Or does the car generally handle that way?
Front toe is 0. Rear toe is slightly in.
Tried the bar stiffer at a local even before nats and it was no good. Softened it some immediately. Ended up softening it much more at nats with some improvement.
It is based mostly off of Lincoln. The long courses there really brought out the weaknesses I think. Generally at local events I was getting some push on certain turns but usually just one or two turns on a given course. At nats there were just a lot of those turns. Basically, the more I have to turn the wheel, the more it pushes, which is to be expected.
CoolHandMoss is offline   Reply With Quote
Old 09-17-2019, 10:11 PM   #3728
H1C
Drives: 2014 FR-S MT
This is another reason why I was not fond of 7+ degrees of caster when I had adjustable front LCAs. With 4 degrees of static camber and 7 degrees of caster, your front wheels will cut increasingly sharply diagonally into the pavement the more steering input you give. With that much camber and caster, the effect is akin to an alpine skiier digging their edges into the snow. Your contact patch becomes more compromised the more you have to turn the steering wheel.
If you're not willing or able to experiment with something closer to OEM caster, I would try taking a wider arc through tighter corners to minimize steering input.
H1C is offline   Reply With Quote
The Following User Says Thank You to H1C For This Useful Post:
Racecomp Engineering (09-20-2019)
Old 09-17-2019, 10:34 PM   #3729
CoolHandMoss
Drives: 2013 FRS
No dialing the caster back was another option I had considered. I just hadn't thought that one degree was enough to make much difference either way so it was toward the end of the list. Though, maybe the better option would be to keep the caster and dial in less camber to improve straight line braking?
Old 09-17-2019, 10:40 PM   #3730
H1C
I found the difference between 6 degrees and anything 7 or higher pretty noticeable, in terms of steering self-centering force and the jacking up of the inside rear in tighter corners due to the cutting effect if I turned the wheel too much. The difference between 6 and 6.5 degrees maybe not so much.
For me, I'd prefer to keep the camber and dial back the caster, but I don't run as much camber as you (3.8), so I haven't found it to affect braking performance enough for me to want to dial it back.
In any case, good luck man -- I hope you can sort out this understeer issue.
Old 09-17-2019, 11:02 PM   #3731
CoolHandMoss
Drives: 2013 FRS
Thanks for the input. I will try dialing back the caster.
Old 09-19-2019, 10:49 PM   #3732
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Does adding more negative camber on the front throw the toe off significantly? I thought it would but someone recently told me that it doesnt on these cars.
I have coilovers and camber plates. Thinking about trying a bit more to see if i like it.
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 09-20-2019, 01:03 AM   #3733
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yes it changes enough where I would adjust the toe back to zero, I've done it and not noticed the toe change as a driver but in hindsight, imho a set of $60 toe plates is worth the investment to periodically check your alignment anyway and adding a few ticks of camber and zeroing out the toe diy is a worthy experiment between spending the money to put it on a rack
ineedyourdiddly
bmacfrs (09-20-2019)
Old 09-20-2019, 08:16 AM   #3734
cueball89
Drives: 15 Impreza
Using toe plates I have a 6mm difference in toe from maximum negative camber to minimum negative camber when adjusted at the camber plate. YMMV.
cueball89 is offline   Reply With Quote
The Following 2 Users Say Thank You to cueball89 For This Useful Post:
bmacfrs (09-20-2019), strat61caster (09-20-2019)
Old 09-20-2019, 10:41 AM   #3735
I like caster, but as mentioned 7* with -4.1* of camber is quite a bit.
"As much caster as possible" has been a popular way to go on the internets but a motorsports engineer would tell you that caster is course dependent.
- Andrew
CoolHandMoss (09-20-2019), H1C (09-20-2019)
Old 09-20-2019, 10:33 PM   #3736
H1C
- Andrew
I think the internets may also be overlooking the vehicle context for high caster settings: usually it's heavy German cars with 0 negative camber and little or no ability to add more from the factory that come with 7 or 8 degrees of caster. It's the only way those cars can get turned in to a corner. On a car as light and nimble as ours, and given the ability to add adequate negative camber via plates or slotted struts, I find the factory caster to be plenty.
The Following 2 Users Say Thank You to H1C For This Useful Post:
DocWalt (09-21-2019), Racecomp Engineering (09-21-2019)
Old 09-21-2019, 12:00 PM   #3737
I think the internets may also be overlooking...
Yeeeeah that'll happen.
- Andrew
Old 09-21-2019, 03:36 PM   #3738
CoolHandMoss
Drives: 2013 FRS
- Andrew
Coincidentally, caster is one element of my setup that was set based directly on the advice of a reputable motorsports engineer. I think he was thinking more about optimizing behavior on track though. The car does handle very well on track!
I'm going to bring the caster back to OE before the next event and bring the rear toe to 0 also.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
