Old 09-08-2019, 10:09 PM   #1
BBRaven
Drives: 2013 Raven Turbo
Noob owner needs help: Part 1 (PCV & BOV)
Firstly, i tried to do the most broad search on these forums for anything with keyword "PCV", and i get no results. I get no results no matter what i search, so im not sure what im doing wrong. I'm a new owner of a 2013 FRS with a SPD 400x turbo kit, trying to learn the most i can and refine this build. This car has just the turbo kit with an open flash tablet custom tune and an upgraded clutch, no other engine supporting mods.
Can i have the PCV VTA and run a dedicated vacuum line from my TIAL BOV to the IM port? My BOV is having delayed reaction, and i believe its because its T'd off of the brake booster vacuum. I used the OFT to see what the engine vacuum was and i saw 8-13, so i bought the black TIAL spring and that one caused to BOV to stay wide open.
BBRaven is offline   Reply With Quote
Old 09-10-2019, 03:26 PM   #2
Amputechture
Drives: 2014 BRZ
Yes, you can use the intake manifold as a vacuum source. You will have to use a hose adapter, probably multiple ones, to step down enough as the IM port is much much larger than the one on your BOV. I am t'd off of the brake booster with a Tial Q BOV and haven't had any issues. What do you mean by a delayed reaction, as in you shift or let off throttle and you don't hear your BOV vent right away? What value are you reading/logging to see vacuum...engine vac is read in inches of mercury (in. -Hg) these motors pull a shitload of vacuum in the -18 to -22ish neighborhood.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
Old 09-10-2019, 04:34 PM   #3
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Just a little search tip, never search anything through the forum, you will never find anything. What works for me is googling ft86club followed by your search parameters then narrow down the results to ones on the ft86club forum.
DandoX is offline   Reply With Quote
Old 09-11-2019, 06:58 PM   #4
BBRaven
By delayed reaction, i mean i hear slight compressor surge, and then a little bit of the BOV. I was reading between 8-13 with the OFT built in monitoring feature. I never thought of it, but is it possible that this car doesn't have the upgraded 3 bar MAP sensor?
Old 09-16-2019, 06:39 PM   #5
James Russels
Drives: 2013 FRS
I have this exact issue, and came here to post about it, but I'll just piggyback here since you've already explained it. I have the JDL kit, but I have an automatic transmission so instead of my BOV pulling vacuum from the brake booster line, I have it hooked up directly to the intake manifold. I was getting turbo flutter on the spring the BOV came with, so I bought a pack of two inner springs (-4 inhg and -8 inhg) and one outer spring (-15 inhg). I still get flutter with the -8 inhg spring, even though this converts to -3.92 psi and my idle vacuum shows anywhere between -6 to -8 psi. When I tried the -4 inhg spring, the BOV is open at idle. So this makes me think there is an issue with the connection between the IM and the BOV, but I've checked it multiple times and all connections are secure. Could it be that I need tubing with a larger inner diameter?
James Russels is offline   Reply With Quote
Part Diagrams / Numbers for BRZ (like RealOEM for bmw), Part Vendors vlad128 BRZ First-Gen (2012+) — General Topics 7 06-29-2018 04:05 PM
New owner, looking for part requests Roel03 Scion FR-S / Toyota 86 GT86 General Forum 16 06-06-2018 01:17 PM
FS: PART OUT Complete OEM Audio Plus Sound Solution & More! PART OUT dinoniel Audio/Visual, Electronics, Infotainment, NAV 15 06-04-2017 03:27 PM
New owner of a CPO (Certified Preowned) BRZ. Question with previous owner's audio mod tekniq BRZ First-Gen (2012+) — General Topics 2 12-05-2014 03:15 AM
Tonight: I need a Portland BRZ owner and S2000 owner! DarrenDriven Northwest 2 06-19-2012 02:40 AM
