Old 09-08-2019, 11:31 PM   #99
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Originally Posted by botbs View Post
I dont have the wheels anymore.
Here is the old pic
Was that stock suspension? Looks pretty good. What size tire were you running? Probably the only wheel that I would prefer in 8.5 over 9.5 lol
Will BRZ is offline   Reply With Quote
Old 09-09-2019, 02:36 PM   #100
Racecomp Engineering
Originally Posted by timurrrr View Post
Found this:
https://wheelfront.com/cars/toyota-8...sport-tc-105x/
Front wheels are specified as 18×8.5, which I presume is +43.
Rears are 18x9.5, probably +45.
I also presume that TRD calipers are the same as PP Brembos — if someone can confirm that I'll update the top post and topic title to reflect that.
Those look like the TRD 6 piston BBK, not the OEM PP brembos.
- Andrew
Old 09-09-2019, 08:38 PM   #101
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Do you know if the dimensions are different between those two models?
Old 09-10-2019, 01:58 AM   #102
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Yes, stock suspension with 18x8.5
botbs is offline   Reply With Quote
The Following User Says Thank You to botbs For This Useful Post:
Will BRZ (09-10-2019)
Old 09-10-2019, 01:41 PM   #103
They are completely different calipers, so yes.
- Andrew
Old 09-10-2019, 04:42 PM   #104
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Oh ok, they do look kind of the same though. I'll update the top post.
Old 09-11-2019, 08:13 AM   #105
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Found this photo online.
Anyone knows what these wheels are? METHOD?
Old 09-11-2019, 06:52 PM   #106
pogofx
Drives: 2018 BRZ Limited
TSW Bathurst
Gunmetal
17x8
35mm Offset
Slightly Concave design.
Right at 40lbs mounted/balanced.
Flush fit with a little negative camber.
Wrapped here in Michelin PS4S's - 245/40/17.
pogofx is offline   Reply With Quote
The Following 3 Users Say Thank You to pogofx For This Useful Post:
Evan55 (09-20-2019), phm14 (06-04-2021), timurrrr (09-11-2019)
Old 09-20-2019, 01:16 PM   #107
Evan55
Drives: 06 Exige, 17 BRZ PP
Yes those are Method MR502
https://www.methodracewheels.com/pro...2-rally-bronze
17x8 +38
Evan55 is offline   Reply With Quote
The Following User Says Thank You to Evan55 For This Useful Post:
timurrrr (09-21-2019)
Old 09-25-2019, 07:48 PM   #108
fx35s
Drives: 2013 Subaru BRZ
I have Gramlights 57c6 in 17x9 40mm and wondering if the Subaru BRZ "OEM' Brembos that come with newer MY/trims would clear my wheel.
Anyone have access to brembo kit to check the clearance for me?
fx35s is offline   Reply With Quote
Old 09-26-2019, 07:29 PM   #109
qqzj
Drives: MDX, Camry
- Andrew
TRD 6 piston vs. PP Brembo, which is better? I guess 6>4, so TRD caliper is better? There should be a similar thread for the TRD calipers. Also, if driving on the street, can you really feel the difference made by larger, and perhaps a bit smoother, brakes? I am thinking about upgrading my stock (small) calipers to the PP calipers. Not sure whether it is worthwhile to do it. Any suggestions?
Finally, one maybe super dumb question. Is there ANY chance that some 16 inch wheels can fit over the PP calipers? Thanks.
qqzj is offline   Reply With Quote
Old 09-26-2019, 09:05 PM   #110
NaturallyAspirated
NaturallyAspirated's Avatar
Drives: 2019 BRZ w/ PP
Other than the actual piston sizes, I believe the PP Brembos have the same specs as the WRX STi Brembos. If so, then no wheels smaller than 17" will fit. If I remember correctly from my Impreza days, the only 16" wheel that MIGHT fit is a rally wheel from Braid, though I'm not sure how they pulled it off.
NaturallyAspirated is offline   Reply With Quote
The Following User Says Thank You to NaturallyAspirated For This Useful Post:
qqzj (09-26-2019)
Old 10-14-2019, 03:16 PM   #111
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Photos of how much (miles!) of clearance Titan 7 T-S5s in 17x9 +37 have:
Finally got Titan 7 T-S5 in 17x9 +37 in Satin Titanium.
I think these are the most killer looking track-worthy wheels that fit Performance Package Brembos with miles of clearance!
I've also confirmed they weight 15.8 lbs.
The Following 6 Users Say Thank You to timurrrr For This Useful Post:
Jdmuscle (10-15-2019), juenedgi (04-16-2020), Plumbus (05-31-2020), SUB-FT86 (11-01-2019), SuperTom (08-20-2025), TMF (10-15-2019)
Old 10-15-2019, 04:22 PM   #112
Jdmuscle
Drives: Supra, Viper, Z06, GT350 and GX460
That’s awesome man. Wheels look amazing.
IG: @vipraz 94 Supra Turbo // 15 Viper GT // 16 Corvette Z06 // 18 Shelby GT350 // 19 BRZ LTD // 18 GX460 Premium // 13 Vrod Muscle
Jdmuscle is offline   Reply With Quote
The Following User Says Thank You to Jdmuscle For This Useful Post:
timurrrr (10-15-2019)
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 09:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 09:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 09:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 06:15 PM
