Old 09-07-2019, 03:59 PM   #1
frxe
Drives: 2013 Scion FR-S, Raven Black
RPM Dip - ECU?
Hi all,
I know this topic was mentioned in the forums before but I am asking for advice from you all.
I recently purchased a 2013 FRS with 38,000. It currently has 40,451 on the odo. Since owning it, I have experienced a dip in RPM’s from 500-1000 when going into 1st gear/going to neutral. I brought it to the dealership and they said they re-flashed my Ecu and the problem was solved for a few days. Recently, the dip/spike in the rpm’s has returned. I am not sure what to do as the problem keeps recurring. Should I go back to the dealer and get it fixed? Is there anything they can do? Or should I get it re-flashed by a tuner?
Thank you all.
frxe is offline   Reply With Quote
Old 09-07-2019, 04:47 PM   #2
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
I’ve had a similar issue on my 2015 BRZ. It’s an auto though, but when coming to as stop, it’ll dip down to like 550 or so and then go up. Also, I literally can’t sit in the car with the AC on because it’ll go from like 550 up to 1,100. There are a couple other little issues regarding the RPMs on my car but it’s not so constant that it becomes a serious issue. I’ve been told somethings are normal and I’ve also been told I can take it to the dealership and they’ll fix it. They did it for you for free or no?
Will BRZ is offline   Reply With Quote
The Following User Says Thank You to Will BRZ For This Useful Post:
JesseG (09-09-2019)
Old 09-07-2019, 04:48 PM   #3
Hello frxe and welcome to our friendly, helpful forum -
I am part of the friendly part, others will come along as part of the helpful part.
I'm not sure what you feel is a "problem", you would you please further explain.
Is your AC running at the time this occurs?
Others will be along soon with some possible explanations/solutions -
Old 09-07-2019, 06:49 PM   #4
Pwoods
Drives: 2013 fr-s
Mine does the same thing dips down to around 500 rpm and I feel like it might cut off. It always recovers but a little unnerving sometimes.
Pwoods is offline   Reply With Quote
The Following User Says Thank You to Pwoods For This Useful Post:
JesseG (09-08-2019)
Old 09-07-2019, 07:44 PM   #5
Will BRZ
Drives: 2015 BRZ
It’s weird and annoying. I wonder why it happens
JesseG (09-09-2019)
Old 09-07-2019, 07:56 PM   #6
^^^this, including defog/defrost mode
humfrz (09-07-2019)
Old 09-07-2019, 11:54 PM   #7
Yep, for you folks with this concern, as eluded to, the change in idle may be the engine responding to the compressor on the AC unit being turned on and off.
JesseG (09-09-2019)
Old 09-08-2019, 12:08 AM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by frxe View Post
Hi all,
Thank you all.
auto or manual?
my manual does it occasionally, i would understand an automatic doing it while the transmission puts a different load onto the motor to spin up the torque converter.
basically, it's not a problem for me as long as it don't stall.
Old 09-08-2019, 12:59 AM   #9
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
My car does it as well with the a/c or the defogger going.
i figure if it ever becomes an issue then its time to look at the IACV or do the dirty thing and just set idle to like 700 or 1000....
I had a story about that
*gets my Humrz glasses on*
So way back when I had a 2.5RS and we had done some serious modifications to the head, cam and intake and exhaust on the car, to the point i even had a special throttle body made. Now this was back when throttles had mechanical pulleys in them and return springs. wel my ported throttle body was a different unit and housing than was on the old EJ251 motor ( single slammer. I loved the valve sizes on em) it didnt have an idler control valve
So it became an issue with the ecu, I think we used a vipec V44 which was an off shoot of the Link G4 units. and setting the Idle with the accessories going like ac or defogger or even radio. Since the Throttle body was sort of, what it was we did the old hot rod thing and drilled a hole in it to "mechanically set" the idle.
now with our fancy new drive by wire/sealed units, your computer has an expected idle rpm and indicated and adjusts the throttle to match.
My old S13 had a set screw for a hard throttle stop, but it still had an IACV too. you could mess with it alot.
Anyways we drilled it out and started it up till it got hot and figured to not stall the car out while the ac was going full blast we had assumed a mechanical idle set at like 800 rpm, but we miss judged the hole and shoved a 5/64th bit to set idle, and it gave the car a 1000 rpm idle.
good think she spun up to 7600, but man it was funny sitting at stop lights and literally slipping the clutch cause you couldnt go any lower. Never had an issue with the ac though
I miss that car
Clutch Dog is offline   Reply With Quote
The Following 3 Users Say Thank You to Clutch Dog For This Useful Post:
humfrz (09-08-2019), mrderp (09-25-2019), Ultramaroon (09-26-2019)
Old 09-08-2019, 01:12 AM   #10
Every low displacement 4 cylinder car I ever had did this. Some more noticeable than others but they all did it. Not an "issue".
Old 09-08-2019, 02:31 AM   #11
So way back when ………...
Good story -
Clutch Dog (09-26-2019)
Old 09-08-2019, 03:45 AM   #12
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
My car as well, driving in mild traffic the other day I kept thinking my car was going to stall. I had the A/C on. The RPM would sometimes dip below 500
JesseG is offline   Reply With Quote
Old 09-24-2019, 06:10 PM   #13
Pwoods
Drives: 2013 fr-s
Just an update on my situation. I changed my OFT tune to stage 2 and it seems to have fixed this issue. I’ve heard that a stage 1 tune on a stock car will smooth out the idle, but I don’t know for sure.
JesseG (09-25-2019)
Old 09-24-2019, 07:41 PM   #14
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
there was nothing to fix like the crickets. if variations in idle speed bothers you guys so much, then I think y'all aren't doing enough actual driving!
HKz is offline   Reply With Quote
The Following User Says Thank You to HKz For This Useful Post:
JesseG (09-25-2019)
