Old 09-05-2019, 10:16 PM   #1
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
What are some good speed bleeders that you guys recommend?
So I'm looking at switching to stainless steel speed bleeders to make flushing the brakes easier. What bleeders do you guys recommend?
Ryan GT86 is offline   Reply With Quote
Old 09-05-2019, 10:19 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Just get this and the appropriate master cylinder adaptor. Way faster.
https://www.amazon.com/Motive-Produc...51780138&psc=1
Old 09-08-2019, 01:40 AM   #3
FeRS
bruh
FeRS's Avatar
Drives: Raven 2015 FRS
This is what I use:http://store-speedbleeder-com.3dcart...eder_p_48.html
They work great. The motive gravity bleeder always seemed big and clumsy to me.
FeRS is offline   Reply With Quote
Old 09-09-2019, 01:26 AM   #4
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Ditto. That's what I use and it's as easy and effective as brake bleeding gets.
BlueWhelan is offline   Reply With Quote
Old 09-09-2019, 07:41 PM   #5
JCW 86
JCW 86's Avatar
Drives: 2013 Raven FR-S
https://www.turnermotorsport.com/p-1...-simple-bleed/
This is what I recommend. Pretty much does exactly what a speed bleeder does except the check valve is a part of the bottle and you keep your stock bleeders. It also has a magnet that you use to attach the bottle to the rotor.
JCW 86 is offline   Reply With Quote
The Following User Says Thank You to JCW 86 For This Useful Post:
JEFFSTYLE (10-19-2021)
WTB: Speed Bleeders KDad2 Want-To-Buy Requests 1 06-16-2018 09:55 AM
DIY - Stainless Steel Lines - Speed Bleeders - Fluid Bleed/Flush F1point4 DIY (Do-It-Yourself) Guides 99 08-24-2017 07:05 PM
What would you guys recommend for an aggressive and sharp exhaust, but not annoyingly iStanley Engine, Exhaust, Transmission 39 08-13-2015 11:15 PM
GTA Speed Bleeders? FLYFISHR CANADA 0 06-24-2014 12:51 AM
Speed Bleeders - long term reliability amram Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 05-14-2014 08:32 PM
