Old 09-03-2019, 03:59 AM   #1
Alastor
Alastor's Avatar
Drives: Toyota gt86 my19
radio stations problem
Good Morning
Well, I recently installed a Pioneer avh-z9200 dab on my Toyota gt86 and installed this radio cable.
https://www.google.com/search?q=metr...-mobile&ie=UTF -8 # imgrc = IOqf8d0qx1akZM:
I tried to search for stations and just found 1 or 2, I disassembled it again, I looked at the wiring and everything is in place, I did the test with the radio out of the hole and found more stations listening correctly to the local station, when I reinstalled the radio in its The gap remained the same as before and the local station listened badly as if you were many kilometers away from the city.
Therefore, I deduce that it is not a problem with the radio but with the wiring. How do I find another compatible cable? Will it be defective? This cable is recommended by some colleagues in this forum. My GT86 is European.
Thank you
Alastor is offline   Reply With Quote
Old 09-08-2019, 12:58 AM   #2
greencounty
greencounty's Avatar
AF/FM antenna amp
There's an AM/FM antenna amplifier that's on pin 8 of the 10-pin connector. This pin needs to have 12v on it from the blue wire on Pioneer or you won't get AM/FM reception.
Garage:
2013 BRZ Limited 6MT - Galaxy Blue
1994 Ford Probe GT 5MT - Red(some would argue pink)
1969 Mustang Fastback 4MT - Royal Maroon
greencounty is offline   Reply With Quote
DVD in radio problem. Covo_86 Electronics | Audio | NAV | Infotainment 1 05-07-2014 11:33 AM
HD RADIO problem in los angeles SliverBrz Electronics | Audio | NAV | Infotainment 10 09-21-2013 11:38 PM
Noticeably low and sharp volume with AM radio stations with stock BRZ radio tracerit Electronics | Audio | NAV | Infotainment 0 07-24-2013 03:38 AM
Sorry - This Radio Sucks - Bespoke doesn't get my 5 favorite stations...Antenna..? JohnnyNight Electronics | Audio | NAV | Infotainment 4 10-15-2012 05:26 AM
radio problem FT86R Great Lakes 3 09-21-2012 04:08 PM
