Old 08-08-2019, 08:47 AM   #85
livingasleep
Drives: 2018 Subaru BRZ Sport-Tech RS
Originally Posted by indlinx View Post
XXR 550 18X8.75 +36 wheels fit
Lol this is my car, you saw these pics on Facebook?
livingasleep is offline   Reply With Quote
Old 08-09-2019, 06:57 PM   #86
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by spicyricecake View Post
Originally Posted by ohmikegoodness View Post
These look sharp!
I've noticed you have PP Brembos.
Can you please confirm these are TE37 18x9.5 +40 and they fit PP Brembos with no spacers?
Old 08-10-2019, 03:13 PM   #87
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
Originally Posted by timurrrr View Post
These look sharp!
Yep, they fit
spicyricecake is offline   Reply With Quote
The Following User Says Thank You to spicyricecake For This Useful Post:
timurrrr (08-10-2019)
Old 08-11-2019, 09:40 AM   #88
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
According to this page,
Rota Titan 17x9 +42 5x100 "requres 3mm spacers to clear STI Brembos".
Old 08-12-2019, 04:03 PM   #89
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
This week I should have another addition to the list hopefully. They are JNC030 wheels(Work Kiwami lookalikes) in 17x9 +30 with a deep concave face. The spokes sit a whole inch further than my 17x9 RPF1 +35 but I wonder how wide does the barrel need to be to clear as I'm guessing most 17x9 have a 15 inch barrel especially with the step lip.
SUB-FT86 is offline   Reply With Quote
Old 08-13-2019, 03:01 PM   #90
ohmikegoodness
Drives: 2018 Crystal White Pearl BRZ
These look sharp!
THANKS! They will fit without spacers, however you will need coilovers.
ohmikegoodness is offline   Reply With Quote
Old 08-17-2019, 07:18 AM   #91
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Found this:
https://wheelfront.com/cars/toyota-8...sport-tc-105x/
Front wheels are specified as 18×8.5, which I presume is +43.
Rears are 18x9.5, probably +45.
These are TRD calipers though, that have different dimensions from PP Brembos.
Old 08-21-2019, 08:28 AM   #92
SUB-FT86
86 Member
https://i.imgur.com/i2Gj0YW.jpg
For some reason it won't let me direct post but these are JNC030 17x9 +30 offset. I have like 15mm of clearance at the closest spot.
https://i.imgur.com/kSbbyLU.jpg
https://i.imgur.com/Ki3nxEB.jpg
https://i.imgur.com/yB5T3WQ.jpg
https://i.imgur.com/IFZgGIE.jpg
The Following 2 Users Say Thank You to SUB-FT86 For This Useful Post:
timurrrr (08-21-2019), TMF (08-21-2019)
Old 08-21-2019, 12:40 PM   #93
RayRay88
Drives: 2017 86 860 Special Edition
Those wheels look really good, any chance you have the weight of the wheels?
RayRay88 is offline   Reply With Quote
Old 08-21-2019, 04:31 PM   #94
SUB-FT86
86 Member
They were 43lbs on a scale with some 23lb AS tires I bought with it. So I would say 20lbs flat.
Old 08-26-2019, 11:00 AM   #95
Mball19
Drives: Toyota 86 TRD/SE
Konig Backbone 17x7.5 +45 offset will fit. The spokes and barrel barely clear the Brembos. 245/40 tires have a small gap between the spring perch.
Mball19 is offline   Reply With Quote
Old 08-26-2019, 02:29 PM   #96
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
How much in mm is "barely"? Would you suggest using a 3mm spacer, and if so, would it help with the barrel clearance?
Can you please post pictures?
Old 08-26-2019, 05:01 PM   #97
Mball19
How much in mm is "barely"? Would you suggest using a 3mm spacer, and if so, would it help with the barrel clearance? There is 3-4mm between the caliper and spokes. The spacer wouldn't help the barrel clearance. The weights on 2 of the wheels rub the front calipers, so they are going on the back.
I will when I put them back on the car. They are my autocrossing wheels.
Old 09-05-2019, 01:01 PM   #98
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Forgot to update as I've had these on for a little over a couple weeks now. But just a final confirmation that these wheels fit very nicely.
Konig Hypergram @ 18x8.5 +38 offset
Tires: General G-MAX AS-05 @ 235/40R18
Total weight of wheel and tire combo came out at about 39.6 lbs.
Clearance is just a little more than the stock PP wheels on the front of the caliper, and much more all around as these are 18's vs 17's.
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
timurrrr (09-06-2019)
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 09:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 09:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 09:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 06:15 PM
