#15 |
Drives: Bone stock
Sell the parts separately. I'm interested in the turbo kit and clutch and etc.... hahahha
Sent from my SM-N960U using Tapatalk |
#16 | |
Drives: Q5 + BRZ + M796
![]() ![]() I really don't feel like that was necessary. You might not be a fan of his style, nor would a majority of people, but the 86 is known for having young and flashy owners with tastes on the more extreme spectrum, so I'm sure he could sell the car for at least $12k. No need to beat on the man when he is down having blown his motor and needing to sell his car for a loss.
#17 | |
pessimistic skeptic
#18 | |
Outside of the wrap, the car looks like any other car here, so what is your point? The $4k vinyl wrap can be removed in minutes. That car is loaded with high end parts. A new, built shortblock and a rebuild for $5k, and the car is capable of being a beast. Maybe the cost for the new owner can be offset by selling a few parts like the other two sets of rims or whatever.
#19 |
Drives: Red FRS
I really just wanted to know If this particular engine the IAG Stg2 with the lower 10.0:1 compression is a reliable option and worth spending the $9,000 it well take to have it installed. James my tuner says the lower ratio is not a good idea... The internet is filled with waaay to much misinformation and I seriously regret ever looking on it for any advice on this build... I guess I just drop the money on this and hope it runs. Shop says they cant tune useing EcuTek so i dunno what im going to tune it with. Sell my ecutek and buy a OFt i guess. Or hope that the same tune from HRi before will work on the new engine
#20 | |
Look at every manufacturer on the market who has a forced induction motor. They all run lower compression. 10:1 is still high by many standards. If a tuner is balking at such a notion then perhaps it is because they don’t have experience tuning lower compression on this platform. Can they actually provide a reason why lower compression isn’t necessary? 400whp is achievable, but you will be making less than 300whp on 91. Why not have more while your building the motor and not being reliant on E85. It seems easier to tune the car for 91 and E85 with lower compression than trying to program progressive boost or boost by gear or something anyways.
#21 | |
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
You shop can’t tune using EcuTek? Is this the shop that tuned it prior to it blowing up? If that is the case I would look into a new shop/tuner. You have put a lot of money in the car. Buy used engine out of a junk yard. Look for a car that has not been modified not the lowest mileage. Take apart and put new rods/pistons/rings. Reassemble with the best of the parts you have. |
#22 | |
Drives: Red FRS
Think I will just put down the deposit on the IAg block and hope for the best. Thanks everyone... Now off to find a second job so I can pay for my totaled car, lol.
#23 | |
Drives: Whiteout FRS
It's weird that the shop have not tuned with ECUTek when it's the most used program when it comes to our platform besides OFT. Makes me doubt that shop a bit but can't judge. You can possibly have them install, then get James to e-tune it for you. Full Blown is a reputable company that made turbo kits and parts for our cars so Idk why people would say to stay away from them, when James do recommend it. Edit:Here's the link for IAG St2 Standard CR (12.5:1) https://www.iagperformance.com/IAG-S...g-eng-1210.htm |
#24 | |
Drives: 2014 BRZ Limited, Satin White Pearl
As for the tune you have from James, it is the same base tune. It will work so long as it has the same parts on the engine as before. CR won't affect the base tune. Lastly, consider my entire offer I sent to you via pm. I'm more than willing to help you out. I'm only 4 hours away. If you want to, pm me back and I'll give you my number and we can talk.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
#25 | |
#26 | |
#27 |
@Irace86.2.0. (for some reason can't quote) The thing is, we aren't seeing the whole picture of what @Conman wants from his car or what he had told to his tuner. So far, we only know two things of what he wants and those are it being a safe build and making 400 whp. His tuner might have said it might be a bad idea because if he wants the minimum or no turbo lag at all then having the standard CR helps alleviate that as much as possible. Until @Conman tells us what he wants from the car, any type of theory/build is usable.
#28 | |
If E85 was plentiful, pump gas was rarely going to happen, 400whp was the limit forever, the car never saw a track day and long commutes required fuel economy then I would totally say leave the stock compression, but in any other scenario I would say drop compression.
This quote from post 14 says it all: Quote:
| Whats my car worth? (Built engine, Turbo kit) | glorydays | FR-S / BRZ vs.... | 16 | 07-13-2019 08:55 AM |
| Built FI engine on 100 RON | Boris_Petrov | Engine, Exhaust, Transmission | 9 | 03-10-2019 04:55 AM |
| Fully built engine with big turbo in dubai TARGET 550WHP | SUB-ZERO | Forced Induction | 84 | 12-01-2014 12:34 AM |
| 9 SEC -PRECISION 6466 SUB-ZERO MOTORS FT86 CUSTOM TURBO KIT , ENGINE BUILT 600WHP+ | SUB-ZERO | Forced Induction | 44 | 07-09-2014 09:44 PM |
| What is the best turbo for a fully built engine scion frs | SUB-ZERO | Forced Induction | 41 | 09-18-2013 06:41 PM |
