CSG Mike, gramicci101, grant86, GrimmSpeed, JDLAutoDesign, JRitt, KCMachine, King Tut, MillersOilsUS, PERRIN, phastafrican, Racecomp Engineering, Raceseng, Roadcone, Sportsguy83, UltramarineLuck, VerusEric, Wonderbar, Xero-Limit
Old 07-28-2019, 01:55 PM   #2115
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
7 years of ownership today.
The Following 7 Users Say Thank You to ATL BRZ For This Useful Post:
DaBoBo21 (07-28-2019), Dave-ROR (11-19-2019), DocWalt (07-29-2019), jflogerzi (07-29-2019), MCTeeJ (07-29-2019), Teseo (10-04-2021), WC-BRZ (07-28-2019)
Old 07-28-2019, 03:36 PM   #2116
WC-BRZ
Drives: Black BRZ
Awesome! Congrats on coming so far...always wanted to come back to this thread to check in how the mazworx short block is holding up? How many miles on the new block so far?
WC-BRZ is offline   Reply With Quote
Old 08-15-2019, 10:42 AM   #2117
ATL BRZ
ATL BRZ's Avatar
It's got around 500 miles on it so far. The engine itself runs great and I've had no mechanical issues with it since installing it, however it has had small oil leaks in common locations on the bottom of the timing cover and cam cover since I got it back in. I attempted to patch them with sealant more than a few times, but they've persisted.
The car is currently at Atlanta Speed Company to have the leaks addressed. It's just kept me from driving the car a lot since the timing cover leak is very slowly dripping on one of the manifold runners and I noticed the wrap smoking a little bit once the engine is fully warmed up. Not willing to risk anything, and I don't have the time nor the resources (shop equipment) anymore to address it myself.
The Following User Says Thank You to ATL BRZ For This Useful Post:
WC-BRZ (08-15-2019)
Old 10-29-2019, 04:29 PM   #2118
ATL BRZ
ATL BRZ's Avatar
Long awaited update.
Been a crazy year with starting a family and now taking care of my newborn son who entered this world at the end of August. The car has been up at Atlanta Speed Company since July occupying their interior storage while we waited for a good time for them to tear into it.
Over the last couple weeks, the professionals at ASC took my engine out and fully disassembled it.
This is what they found. As evidenced below, Mazworx did not assemble and seal my engine correctly. NSFL Warning.
Sealant noodles all up in the oil pickup screen.
Sealant where it does not belong in the oil passages in both heads.
Not pictured: At least one of the Supertech valve seals was not seated correctly and likely causing the smoking on cold starts that I was experiencing.
No sealant where it belongs on the corners of the headgaskets as directed by the service manual. Was sweating oil there too just wasn't enough to drip.
Intake cam sprocket detent plate which fell off upon inspection. This was originally causing slow response codes on the driver's intake bank on my first few drives. I thought it may have been the 40 weight engine oil I had in the sump, so I changed it out for some 20 weight, which made the codes go away once I got the oil good and hot on a summer afternoon. Thought that was the end of it and whatever small blockage was causing the AVCS on that bank to be unresponsive was cleared up. I understand the sprockets rely on a specific oil pressure which is controlled by the OCVs in front of them. I also know that the detent plates on early builds are known to become dislodged from where they are initially pressed in and allow too much oil pressure through them and cause the same family of cam response codes to be triggered. When Mazworx was assembling the engine, I reached out and asked if they could pull the sprockets off an inspect them to ensure the plates were securely in place. They said it was not possible with the cams still in the carriers and they normally just leave them in place when rebuilding these engines. I watched the tech at ASC remove the sprockets from my cams while still in the carriers in about 10 seconds by simply removing the 3 bolts securing them to the ends of the cams.
The sleeves, bores, pistons and rods all appeared to be ok and I had no indication otherwise during the break-in miles I put on the engine. Mazworx did all of the machine work on my original case halves and timing cover to install the sleeves and Reimax high capacity oil pump. That all looked good to us.
I emailed Mark Mazurowski, the owner at Mazworx, on 10/11, the day I went to ASC to see all of this for myself and document it. I reached out and explained what we found and shared the photos- asking what could be done about it. He has not responded as of today, over two weeks later.
After talking things over with ASC, we agreed that the rotating assembly and short block were likely just fine since the miles on the engine were minimal and all at low RPMs with no boost, so there was minimal risk of bearing damage due to starvation. I'm just glad I took it to them when I did.
ASC finished up the reassembly this week with a new full engine gasket and seal kit, new intake cam sprocket, professional surface prep and sealant application that fully adheres to the factory service manual's specification. They also put in all new Supertech valve seals to make sure they were all seated correctly and would not leak as they did previously.
While I am very disappointed in the job that Mazworx did with the assembly of my engine and their apparent lack of responsibility for doing it so poorly, I am trying to stay positive and be grateful for the awesome work that Atlanta Speed Company did to get Melanie back in action! FINALLY!
They definitely treated her right and made sure she was squeaky clean again, and most importantly free of oil leaks and excessive sealant.
Driving her home for the first time in a long time was a real pleasure.
Still needs some tune tweaks, an oil change or two, and new front rotors before hitting the track again, but I'll get to those items as soon as I can. For now I'm just celebrating having it back in my hands with more confidence than ever.
The Following 14 Users Say Thank You to ATL BRZ For This Useful Post:
Dave-ROR (11-19-2019), Irace86.2.0 (12-02-2019), jcw99 (11-16-2019), Joveen (10-29-2019), lextrueno (11-07-2019), MCTeeJ (10-29-2019), mistople (10-31-2019), MrSkubi (10-30-2019), Pat (10-29-2019), Rosticles (11-01-2019), StraightOuttaCanadaEh (10-29-2019), Takumi788 (11-01-2019), TheStig85 (10-29-2019), weepel (08-03-2021)
Old 10-29-2019, 04:57 PM   #2119
Joveen
Joveen's Avatar
Drives: Bone stock
Wow man. Glad you have her back up and running. Your car inspires me. I guess I'll stay away from mazworx for an engine and just find a reputable engine builder locally or iag block.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
The Following User Says Thank You to Joveen For This Useful Post:
ATL BRZ (10-29-2019)
Old 11-01-2019, 12:26 AM   #2120
ATL BRZ
ATL BRZ's Avatar
A few nice shots with a good camera from southrnfresh_joe
Still waiting on a new pair of splitter rods after bending them by accident while loading the car on a trailer
The Following 5 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (11-02-2019), lextrueno (11-07-2019), MCTeeJ (11-01-2019), mistople (11-01-2019), tintumz22 (11-20-2019)
Old 11-01-2019, 01:06 PM   #2121
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Bummer to hear about the continued engine problems. Looks like it's in the right hands though.
mistople is offline   Reply With Quote
Old 11-14-2019, 11:11 AM   #2122
ATL BRZ
ATL BRZ's Avatar
Had an awesome time last week at The Retrofit Source installing a new pair of Morimoto full LED headlights and a pair of ModPod Mini LED arrays to use as DRLs and turn signals!
They just edited together a nice little video showcasing the lights!
[ame]https://www.youtube.com/watch?v=yUl6HOWl6po[/ame]
Haven't been able to do much night driving yet, but so far they have been an awesome upgrade!
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
TeutonicShift89 (11-22-2019), TheStig85 (11-14-2019)
Old 11-14-2019, 11:41 AM   #2123
Pat
Pat's Avatar
Drives: 2023 BRZ
Good stuff! I've had those headlights sitting in my basement for a couple weeks. I'll have them installed a couple weeks from now. How is the light output compared to OEM HIDs with bulbs that are several years old?
Did you have to do anything to adapt the electronics, or were they plug and play?
Old 11-14-2019, 11:48 AM   #2124
ATL BRZ
ATL BRZ's Avatar
You'll love them! The light output from what I've seen (which so far was just in the darkness of the TRS studio) was indeed superior to the OEM HIDs. The headlights are plug and play, but they obviously did some custom wiring for the ModPod Mini LEDs to make them function in those ways.
Pat (11-14-2019), TeutonicShift89 (11-22-2019)
Old 11-19-2019, 11:35 AM   #2125
ATL BRZ
ATL BRZ's Avatar
I did some night driving over the weekend and thought I'd share my thoughts with you! My first impressions at night were really good! The beam spread is much wider than OEM HIDs, and the output on dark roads was excellent, still superior to stock. I also like how quiet they are when parked. The OEM HIDs made a buzzing noise that wasn't bothersome, but noticeable compared to the silent operation of the LED projectors in the Morimotos.
The Following 3 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (11-20-2019), Pat (11-19-2019), TeutonicShift89 (11-22-2019)
Old 11-22-2019, 11:15 PM   #2126
TeutonicShift89
TeutonicShift89's Avatar
Drives: '13 LAVA - lightly modded
I think one criticism I've heard of the morimoto lights is that the LED daytime running strip is considerably dimmer and less visible in the day time than the factory boomerangs.
Any word on this?
Also, I thought HID had superior output than LED: https://www.ft86club.com/forums/show...&postcount=172
I like the 5yr warranty offered by the Retrofit Source. Definitely be the store I would get them from.
You are going to be condemned to live out the consequences of your taste - TM
TeutonicShift89 is offline   Reply With Quote
The Following User Says Thank You to TeutonicShift89 For This Useful Post:
Old 11-23-2019, 11:03 AM   #2127
ATL BRZ
ATL BRZ's Avatar
Any word on this?
You can see in my install pics that the Morimoto DRL strip is just as bright if not brighter than OEM. HID may have more raw output but the projectors have a lot to do with the amount of light that gets out and the spread of it. The Morimoto Projectors have a more consistent spread than oem and I find their overall performance to be better.
Old 11-30-2019, 04:27 PM   #2128
ATL BRZ
ATL BRZ's Avatar
Recently commissioned some vector art from a friend of mine, and it turned out awesome!
Now I can't decide which one to print and frame!
DocWalt (12-03-2019), MCTeeJ (12-02-2019)
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 04:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 01:46 PM
