Old 08-08-2019, 01:52 AM   #1191
Conman
Conman's Avatar
Drives: Red FRS
Originally Posted by Steveiam View Post
I was following your build thread and I thought everything got situated. Sorry to hear that happened. Are you thinking of rebuilding the block?
Thinking about it... What would be a good option with my set up? Is there a better option for E85... I see the Mazworks Sleeved Stg2 https://www.mazworx.com/store/p/488-...lock-FA20.aspx
The Full Blown stg3
http://fullblownmotorsports.com/full...ort-block-1465
and MAP
https://www.maperformance.com/produc...a20-ft86mss-s3
Dsport
https://clubdsport.com/fa20/
There is IAG and Crawford as well. I dunno
The advantage to Full blown is they are local and I could have them do the install
Conman is offline   Reply With Quote
Old 08-14-2019, 04:17 PM   #1192
Conman
Conman's Avatar
Drives: Red FRS
My engine shop recommended this engine. Any thoughts? https://www.rallysportdirect.com/par...ru-short-block
Old 08-14-2019, 06:08 PM   #1193
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
No reason to lower the compression, IMO. It will just make your turbo less responsive and introduce more lag, while requiring more boost pressure to make the same power you'd make at 12.5:1 with less boost. I dont think you're planning to buy a bigger turbo, so this also means your GT2860RS will struggle to hold those higher boost pressures required to make decent power with low compression.
Unless you are stuck with 91 octane fuel and you have no access to anything higher octane, I recommend a 12.5:1 block.
The Following User Says Thank You to ATL BRZ For This Useful Post:
Conman (08-14-2019)
Old 08-14-2019, 06:14 PM   #1194
Conman
Conman's Avatar
Drives: Red FRS
Should I look for a different shop? ... Also slightly worried because they say they dont know if they can tune it since they have never used ECUtek before. They mostly work on EJ engines and only tune with Cobb or OFT.
Old 08-14-2019, 06:20 PM   #1195
ATL BRZ
ATL BRZ's Avatar
Yes.
Big red flags. You should stick with HRI Tuning if possible. I would check and see if that shop would allow an experienced EcuTek tuner to tune your car with EcuTek on their dyno (HRI has done this before). If they don't, then seek an experienced EcuTek tuner elsewhere.
Conman (08-14-2019)
Old 08-14-2019, 06:29 PM   #1196
Conman
Conman's Avatar
Drives: Red FRS
Yes.
So then my only other option local is Full Blown; but I have been told to stay away from them ( they sounded not interested in working on any Turbo kit that wasn't their own) I've heard a couple bad stories ... How about nationwide if you were going to have anyone build an engine and install it in house who would you take your car to?
Old 08-14-2019, 06:38 PM   #1197
ATL BRZ
ATL BRZ's Avatar
If you're looking for a premium shop experience and a true professional, turn-key build and tune, I've only heard good things about these guys. https://nationalspeedinc.com/
They have cars shipped to them from all over the country.
Here's a BRZ build they completed recently. https://nationalspeedinc.com/2013-su...rz-shortblock/
Conman (08-14-2019)
Old 08-15-2019, 10:29 AM   #1198
WC-BRZ
Drives: Black BRZ
Speaking of short blocks, how is yours from Mazworx holding up? Already asked in your build thread, too
WC-BRZ is offline   Reply With Quote
Old 08-15-2019, 10:42 AM   #1199
ATL BRZ
ATL BRZ's Avatar
My bad. I responded in my build thread.
Old 08-15-2019, 12:04 PM   #1200
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I understand he is selling his car now, but check out this post from this thread.
I think a tuner could do boost by gear and progressive boost to reduce the risk of knock and preignition. They could also reduce the effective compression ratio below the static compression ratio with cam timing like the WRX does, but it might just be easier and safer to just use a lower compression motor. The detriments might not be that bad like the guy mentioned in the link. Like you said, if all he had was 91 and modest power goals like lower than 300whp then definitely he shouldn't lower compression. With E85, the risk diminishes, and he could hit his 400whp goals, but a lower compression motor would have more potential for more power later on, so I would advise reducing compression to at least 11:1, but closer to 10:1 would be ideal. The lower the compression ratio the more power potential the engine will have, but there obviously can be more lag.
Porsche 718 Cayman uses 9.5:1, the BMW S55 uses 10.2:1, the B58 uses 11:1, the Mercedes engine below uses 9:1, but because it does, the torque comes on higher in the rpms, but as you can see, they are running 30psi on pump gas, so the motor hits over 400hp. An Evo's compression ratio was 9:1 and most would agree that 500hp was closer to the limit on that motor before piston/rods were needed, but I don't know how the stock piston/rods compare to the FA20. Just something to think about.
https://carbuzz.com/news/mercedes-am...-making-416-hp
https://www.motortrend.com/news/amg-...r-engine-specs
Old 08-15-2019, 09:15 PM   #1201
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Does anybody have a link/part number for the oil restrictor in the V2 kit for a GTX2860R Gen 2?
Jesse36m3 is offline   Reply With Quote
Old 08-26-2019, 10:46 PM   #1202
Steveiam
Drives: 86
Is it possible for GTX2860 to make 300-350hp with 10:1 CR on 93 octane?
Steveiam is offline   Reply With Quote
Old 08-27-2019, 10:36 AM   #1203
Amputechture
Drives: 2014 BRZ
Yes
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
Old 08-27-2019, 10:36 AM   #1204
Amputechture
Drives: 2014 BRZ
Although lowering the compression ratio to stay at that power level would be retarded.
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
